Sold it on eBay about 2 months ago now and paid off some student loans. Then I sold my 2013 Passat TDI (commuter car) back to VW. So last Monday I purchased a new 2017 Passat R Line as my daily driver. Kind of funny because a little after I sold my truck I also bought a 900lbs liberty safe. Guess what I needed to movie it...a truck lol. I'm eye balling one of these 2017 ZR2's but I only want one if it has the 8 speed with the diesel.
Sent from my SM-G930V using Tapatalk
have you seen Chevy Rocky Ridge K2 truck ? it looks sweet , it won't fit in by garage
Another diode in and now my fog light mod is set. I will love this at night when I unlock and it all lights up around my truck.https://vimeo.com/201216184
Have you thought about using a diode to have your puddles on the dome lamp circuit? That's what I've done. Now they turn on/off with the dome lamp switch too.
BTW - I love your grille! I am on the lookout for one!
Edited by pgamboa
  • Like 3
I don't like them at all. They use cheap lifts and basic changes but charge an arm and a leg. The company SCA is actually just a few miles from my office in Birmingham, AL. I'd rather get a deal on a nice LTZ and use the money save to put towards mods.
Hmmm interesting! Trying to understand the benefits of it. Enlighten me please lol
Nothing much different except they stay on a little longer and controllable with the lamp. Toyed with the idea of making the puddles blink with the Turn Signals :).
I still haven't had a chance to pick up a diode yet for my puddles.... been a busy week. Good news is I saw the plug under my steering wheel for the heated wheel, so I can do that eventually. Lol
Dude I've never had a heated wheel until this truck, I haven't worn any gloves going on 3 winters now lol!
Sent from my kayak
Sent from my kayak
The heated steering wheel is great!
Nice! When I did my heated steering wheel mod, I had no idea I needed that 2 pin connector (must have missed that detail in the thread). It was a nice find though when I did.
I hear ya man, loans are rough. I've got a little under 4 years left to free myself from them. I think my next one will be a diesel too, that diesel brothers show has me wanting one bad haha!
Sent from my kayak
Sent from my kayak
Yeah loans suck especially when they're private and out of state. Luckily though I've had a plan and by this May I will have paid off all of my private student loans within one year of graduating. Then I'll only have my low interest federal student loans left to pay. I'll tell you what though it's nice actually having money to save and breathing room.
As far as a diesel truck goes, I say hell yes! The only big downside I see is they are a lot more expensive to repair when they break (engine wise).
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
