So the 3 hole is enough to get a good grip to close them. The site recommends 4 hole for larger vehicles and trucks.
Thanks in advance.
I get plenty of grip with the three hole and find that sometimes I even use two fingers to close the doors. Really liking these more and more now that I've had them installed for a bit. Not sure if the four hole would be better but then again I'm very careful with my vehicles and the doors on these trucks are fairly easy to shut. I installed them low on the door because I am leveling with larger tires soon but I could see the four hole being beneficial if installed higher up. I don't think my pinky finger would be much use where I have them installed. I guess I would recommend four hole if you have concerns three is enough, that way if you need a full four finger grip it's available.
Installed a wireless charger in my front center seat console. Works great too! f426e035768a7b0fcdc07af361502155.jpg7970c5154bc58c33e146251b2edd96bc.jpg
Sent from my SM-G930V using Tapatalk
Do you have a link to that bull bar you have on the front of your truck? I like the look of it and want to check it out.
Thanks!
It went up alot in price, I got it for $200 in special
Go Rhino! (3171B) 3000 Series StepGuard Grille Guard https://www.amazon.com/dp/B00ICIZPZC/ref=cm_sw_r_cp_apa_5nOEybTG5H48N
2014 Silverado 2WT CC Summit White 4.3L V6
DROPKICK Edition
IG: egroj_legnar
https://m.youtube.com/user/jorgerangel159
Purchased and installed a cargo management system for the bed.
Don't let member Lalibert see this, he'll tell you that it doesn't look cool enough so you should buy a bed extender to accomplish the same thing while at the same time looking good to other people.
LOL - Truth be told, this is temporary. I figure a fun little Saturday project with by little guy will be to make a cardboard template, cut a 2x6 to fit, and throw some bedliner on it.
That said, this does the exact same thing. So until the weather warms up, and we have a weekend with absolutely nothing else to do, it'll stay put.
Finally pulled the front bowtie to plastidip the chrome trim black. Now it matches the tailgate bowtie.
I had originally dipped it while still on the truck but wasn't able to peel a clean edge on the outer part of the chrome trim. Removing the front bowtie was way easier than I previously thought.
Also, looking at ordering a BB autocal and airaid mit tonight. Eventually I would like to convert to E85 but that will have to wait. Can anyone confirm if BB can unlock the E85 tables?
I did the same with non pressure treated wood, and the rear, and front one covered in black line-x so it looks pretty.
    AidenVorpagel
    AidenVorpagel
  • Who's Online   3 Members, 0 Anonymous, 1,317 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
