Just trying to narrow down my chevy shake. But I have 60k Miles. Next step is a driveline balance. Anyway the u joints felt really gritty so didn't hurt to change them.
Sent from my Pixel XL using Tapatalk
Just saw a video on youtube where the guys axle hubs are not round and want to check that out next time I have a chance. Before that I've been thinking I'd take my shaft out and let PST check it for issues. Mine only shakes a little when my tires are not below the crazy stupid 10lb road force only needed for high end high speed cars before these trucks.
New Tires BFG KO2 275/65/R20 with level rub in reverse and hard turn though, not sure what I'm rubbing though, otherwise loving the look
Edited by jsb159
  • Like 6
you could always color the inside of your front tires with some chalk and then you could see where they are rubbing.
Installed my Tuffy under seat storage box. The dealership finally got my DQS tow mirrors mounted and working. I will verify full functionality of them tomorrow. I have a few more mod's that I have planned, but it's pretty cold outside (9*F), and my new garage does not have heat yet...
What leveling kit? 2" or 2.5"?
2.5"
when I got mine it had a leveling kit really don't like the look guess I will be taking it out
286a7b76835acfbf207791377782fcf4.jpge96c4ebb281fc1b8ef66e6ea93993f8c.jpg1ab4e70ef4eef65f0327fb35f0fb3659.jpg
$4 ebay LEDS
looks good.
  • Like 3
Brought her home yesterday, started making her my own today. Excuse the tint shop parking lot photos, it was freezing today, and I wasn't about to spend extra time outside looking for somewhere to get pretty pictures.
Before:
Before tint
After:
After tint
  • Like 5
$4 ebay LEDS
You got a link for the license plate lights and third brake light or the seller. I've searched eBay and want to get some LEDS. Thanks in advance.
Before:
After:
Nothing better than getting tint on the front windows first thing I did too, I also added a windshield visor and love it.
Edited by Lalibert
Link for 3rd brake light cargo and reverse.
http://m.ebay.com/itm/231660815249
License plate lights
http://m.ebay.com/itm/2-X-HID-White-T10-Side-Wedge-9-SMD-W5W-168-194-LED-Bulbs-For-License-Plate-Light-/251541386343?txnId=1974880070015
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
