I need to access to a module that is apparently behind the back seat as well. Haven't looked into it yet though...
It's just like on the older NBS trucks. You remove the seat and cut a little bit off the tabs that hold the seat back to the cab. When you fold the seat bottom up, the top half raises slightly and lifts out of the hook on the cab so it can be folded down for access.
Cool idea, just not for me. I have my kids in the backseat, so I won't jeopardize any safety from the seat.
Catch can installed and led lights
Sent from my LG-H810 using Tapatalk
Sooo not trying to be a dick but you do know your tailgate handle doesn't come close to matching the rest of your truck right? And for the vinyl Avery gloss white matches best...
Edited by Abearclaw
I know. I have the original handle that I will be sanding down and repainting to match. This one was shot with too much pearl.
I'll have more time when I go on my PCS leave to work on the truck more. Like doing my undercarriage before I move to the Midwest.
Edited by pamaguin
Got my Borla split rear "Touring" exhaust on......had the bro hook the truck up to HP Tuners and adjust for tire size and turn AFM off. Man what a difference now ....feels like a brand new truck!
Took the Sierra out for a warm up run then did a fluid check, oil good, transmission fluid good. After that I disconnected the battery for about 15 minutes for relearn. Found it odd that I had to cycle the drivers side window upon turning on the key. Took it out for a spirited run, and only hope it gets better with time/miles.
fold down? More info please.
So what I did was to remove the backseat entirely I did this so that I could install some be quiet brown bread against the rear wall and the floor in the process of doing so however I also cut the metal tabs that hold the back seat to the rear wall in half this now allows the seats to both fold up and the upper part 2 full down how upload a video here in a bit and fortunately it takes a while to upload
Here is a quick picture of the rear clips that I cut in half https://goo.gl/photos/uFFMUdJg2iomqTEx9
Picked this up on craigslist the other day new for $40.
Decided I wanted some color so ordered some vinyl and gave it a go this morning. Took two tries on the front but looks good. Rear was one shot. Not entirely happy with it as it does not seem to want to stick out at the edges. Looks good for now but I will likely peel it up if it doesnt peel itself.
You could try post heating it to help activate the adhesive and some edge seal
Used a heat gun when doing it. What do you mean by post heating?
Essentially what I did - Cut approximate size, removed backing, applied with 'thumb' pressure, heat with gun and pushed out all wrinkles, cut the edges, used vinyl tool to push down edges. Did the cutting and pushing all with the heatgun.
Tough to say if I used enough heat, maybe it just needed more or if I used too much. Certainly with a few more tries I would get it and I have plenty of vinyl but it was starting to get a bit windy.
Color matched the Z71 grill emblem.
AB5097A7-CAC3-498A-A206-76E495441C53_zps
0C18C369-586C-4B42-AF8E-FA77F3D5516B_zps
C1B66082-5A47-4759-BF83-2CB1A06CA4DE_zps
Painted my running board gap fillers with spray can bedliner.
7B1BEE16-959E-4050-B0C6-624AB8A458C7_zps
50B8D3D5-2BCE-428E-BFBB-E24DE2225A74_zps
  • Like 3
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
