Fortunately for me, the shocks I bought from a member here had the springs already installed. So I didn't need to rent a spring compressor. It was fairly easy doing it the first time.
3 bolts on the top, 2 bolts on the bottom. Then two more bolts (sorry, I don't know the names of the parts those two bolts were [emoji23]). The axle came down some, pulled the whole assembly off. Took me about 3 hours. No video because I was running out of daylight. But I took some pictures so I knew how it went back. LMAO... just in case.
Luck you and the setup looks nice. Yes, I will need to get a spring compressor.
I watched many videos and the spring compressor doesn't look bad. I was ready to tackle that if i had to. The hardest part was pushing the axle down to get the spring/shock back in. Was shy of 1/8" clearance. The retainer nut also got in the way. Didn't have a pry bar so had to use the force, pushing the axel down to get it to finally clear.
those arent stock rims right?... some of the best rims i've seen!
Yes they're replicas and 26s
Installed Bilstein 5100s all the way around today! Purchased from @gnarlon. Thank you!
Special thanks to: @Justin101714, @cbrsilv15, @jesus953555, @alexantics for helping me get through it. Never done anything like this before and glad I was able to turn some wrenches and hammer some knuckles! [emoji23]. Off for alignment tomorrow morning!
Thanks to this forum for the wealth of knowledge it can provide. On to Illuminated Door Handles! [emoji15]
Great job brother!! Looks killer!! I like it. How's the ride feel better??
Here is a picture of her new bedroom.....28376b80f6f5329a6fc2ee7879a72974.jpg
Sent from my LG-H820 using Tapatalk
Nice, tell me about the floor. I'm about a month away from doing mine, and still undecided...
Thanks. I used the Rustuleom Rocksolid. Bought 1 2.5 garage kit but that was not enough and had to run back to Lowe's to pick up another kit to finish it up.
what size is the garage, I just had mine built, it's 56'x34', the floor is smooth enough, you could roller skate on it...
Don't know the measurements but it is a 2 car garage.
Catch me offline, I'd like to know why you went that route, ease of application and such, that is of you don't mind answering some questions. If not, it's ok. I've been asking a few of my friends as well.
Maybe its the picture, but your two car garage appears twice as big as my two car garage!
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
