Does it sling the excess product all over the side of your truck?
yes it does. It takes a day or so for the dirt to expose the dots everywhere but hell yes it slings!!! Your best bet is to drive it for a good while and let it sling and then detail spray wipe the sides of your truck after while it's still pretty clean so it isn't covered in spots in a day or two.
Been slowly piecing this together.
Stock head unit.
O gauge power wire to the back
8 gauge to the Amps.
JL Audio fix 82
JL Audio TwK D8
JL Audio HD 600/4 for the mids and tweets
JL Audio HD 750/1 on subs
JL Audio Stealthbox.
Still undecided on what I'll put in for mids and tweets.attachicon.gifIMG_0098.JPGattachicon.gifIMG_0099.JPG
Remote bass knob
Seats back in.
Nice man! I'm a big fan of JL. I was going to put in a TW3 in a custom box but I have the Bose and it's pretty decent... Decent enough to not put priority on the sub I guess. Now I'm jealous. Haha
What sub is in the stealth box?
Sent from my Nexus 6 using Tapatalk
Finally replaced the cabin air filter with the k&n version. This is the original one and had a tad over 45k.
E1835E27-53BE-41D3-B60D-FECA95C4082B_zps
I love my JL audio 12".
I think the stealthboxes have the tw3 series shallow subs.
Sent from my SM-G950U using Tapatalk
2d947019ab42dc69c15656454b61ccbc.jpegb50718b4a46932b06747a35ca1b7f08b.jpeg just purchased 37s on some 24 inch snowflakes and a 3.25 body lift to add on to my 7 inch suspension lift 2a45f3eb54dee67cc7043fb501542e06.jpg
  • Like 4
Nice!!
I see that now , but yeah will be 37s just haven't got the actual tires in yet, lol
Nice! I replaced mine recently as well with a K&N. It's definitely dirty but not too bad for 45k miles
Hauled this home.
JD Z345M Zero Turn.
If I had known how much fun mowing could be, I would have bought one of these years ago!
  • Like 5
Hauled this home.
JD Z345M Zero Turn.
Does it have a cup holder for your beer?
  • Like 3
That is the key to make it fun. Lol
Hauled this home.
JD Z345M Zero Turn.
Agreed ! I have a Zero turn Exmark, between mowing the lawn and washing the truck is my quiet time ! Lol.
Let the striping begin !
Edited by Bmz72
  • Like 3
I would never have bought it without a cup-holder..... :cheers:
Edited by Luster
  • Like 4
Thanks!! I really couldn't see how it wouldn't. You just saved me a little cash.
Swapped out front - GM Floor Liners for Husky X-Act Contours.
I know there are tons of video on the Husky X-Act and the GM Liner, but I couldn't find any on a side by side comparison.
So I made one :)
https://youtu.be/a-KQHsGJxXw
Edited by pgamboa
  • Like 9
    ChristopherDobson
    ChristopherDobson
  • Who's Online   1 Member, 0 Anonymous, 1,347 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
