I'm just curious. How many miles are on these tucks with the starting problems?
First time was last Friday and it had 25 miles. Second time was this morning and it had 83 miles.
Mine started the morning after I bought the truck with about 50 miles on it.
***maybe I should rephrase that***
Mine started ACTING UP the next morning after.
Edited by chelmer
So the next occurrence is expected at roughly 140 miles?
I am assuming the next time is below zero if this starter didn't fix the issue.
Picked up my 2014 Sierra Feb. 5 - was built Sept 2013 ..........I has not started on any day that I have owned it .......... I can fiddle with it, remote, in cab, lock, unlock and after many tries will start. Dealer removed starter and heated inside and reinstalled on my truck the next day ...........took it home and it would not start the next day. After 26 attempts to start today it started by remote on the 27th. Took to dealer after showing him this thread and he replaced the starter. We will see tomorrow morning. The Service Manger was being told by GM field engineers to NOT just replace the starter - try the bake out procedure. Well, I looked at the bad starter and all seals were intact as best I could tell. Valero may have assembled the starter in 80% relative humidity and 80 deg. F, which would lead to condensing moisture in the solenoid portion of the starter ........I can not see how the "baking" process would drive out condensing humidity. GM wants to handle owners on a case by case basis - I disagree and GM should issue a TSB as soon as GM and Valero bracket the offending production dates of the starters and trucks. 2013 Trucks have the same part number starter and have not had this problem that I know of .......... They will get to the bottom of this .........meantime, us cold weather frustrated owners and some good dealers are struggling with this problem ..........will post a start or no start tomorrow with a NEW starter ...........should be 10 deg. F or so ......
I do really like my truck, but it really should start for me to keep liking it ..........good thing I have other vehicles available.
Cut that stupid flapper out of the exhaust and call it a day. Now mine just doesn't like starting when it's been sitting for more than 5 hours in the cold. Making progress!
Add me to the list. Purchased 2014 Silverado Double Cab Z71 on a Wednesday. I live in Wisconsin. Temps have been -20 to 5 in the mornings. Friday truck wouldn't start. Towed back to dealer. They said battery had low charge so they charged it up and gave it back to me later that day. I wasn't convinced because the tow truck driver tried to jump start the truck with no luck. Saturday morning wouldn't start. Towed 2nd time to dealer. This time I was told battery failed testing. Replaced battery Monday and kept the vehicle until Wednesday. They said everything tested good for 2 days. I received the truck back on Wednesday. All good until Saturday afternoon. Towed a third time. They thought the truck had some sort of power draw. Dealer called me Monday and told me GM engineers were sending them a new starter to try. Starter was suppose to arrive today but it didn't come in. Will be delivered Thursday and installed. I will let you know if this fixes my truck.
well guys still no fix, my 2014 silverado was towed in for the 2nd time in 6 days
my service dept tech found one of the battery grounds going to the frame had undercoat under the cable, cleaned that off & it started right up. drove it home,
the next morning well you guessed it, no start no crank. the gm smart guys gave us a part # for a completly different starter,i should have this part by friday. if this works i will post the pt# for this new & improved starter. kinda bad when you work for a chevy dealer & your new truck keeps being towed to work every day !
At least you get a ride to work every day. I get stranded in the middle of nowhere when mine wont start haha
At least when you get yours started you can drive it. Several times now mine starts but drive does not engage. Have to run through the gears 3-4 times before it will grab and go.
LOL..... i still dont have a loaner truck, & i work for the dealer ! wait till they get my how was your
experiance card back ! they sold my trade in in 2 days so i cant drive that.
March of 13' I replaced battery on my 97' GMC down at Sears Auto Center in Florida. I've used Die Hard batteries forever the past 10 years while living in Florida and was able to get about 3 years out of them before they crapped out. The heat, etc. really takes it's toll on batteries in this region of the country.
I told the guy at Sears I was moving up to Chicago in a few weeks and he stated....."oh boy, this new battery is not going to last you very long". He explained that in warmer climates, the sulfuric acid/water solution is different depending on what regions of the country you live in. In warmer climates the solution is weaker so the battery does not get too hot internally. Likewise, when you purchase a battery in regions of the country where it's much colder, the solution is stronger as this allows for maximum CCA and since it's so cold, internal heat build up is not a major factor.
I can assume there is some truth to this. Just wondering if GM is installing the correct battery based on region of the country these trucks are being shipped to.
I've thought about replacing my battery, but I think that is GM's job, not mine. I haven't looked at the battery to see what the CCA are, but it cranks fine anyway, it just doesn't like starting.
    • Replace the fuel pump with an OEM AC-Delco.
    • Hello, first time posting here. I have an 03 Chevy 1500HD with the 6 liter gas engine. The truck ran fine until the fuel pump died on me and had to get it towed. Replaced the fuel pump with a precision pump from O’rileys and changed the fuel filter while I was there. The truck will run and drive now but it wants to idle around 500 rpm when in drive and it tries to stall if you touch the gas. It drives fine though, just doesn’t want to idle. Put a fuel pressure gauge on the rail and only have 50 psi. I guess these trucks should have 55-62 psi to run right. I thought the regulator might be the issue because when I would unplug the vacuum hose it jumped to 56 psi. Replaced the regulator and no change. The only thing I can think of is that I was sold a faulty fuel pump. Any help would be appreciated because I’d rather not have to take the bed off again if I don’t have too. Thank you!
    • I've been wrenching on GM trucks for 17 years. And I need to get something off my chest because it's been weighing on me for a long time. After all that time, all those motors, all those people standing in my bay, I've figured out there are really only two kinds of owners. The ones who already know about this. And the ones who are about to find out the hard way. A guy came into my shop a few weeks back in a 2018 Silverado 5.3. Sharp guy, maybe 35. Knew his truck cold. He'd been on the forums, read the threads, done his homework. He only rolled in so I could double-check a little module he'd already plugged in himself. Wanted a second set of eyes on it. Ten minutes, in and out, drove off happy. Two days later, a completely different story walked through the same door. Older fella this time, in a 2016 Sierra. Gorgeous truck, clearly babied, not a scratch on it. Wedding ring. Looked like a guy who took care of his stuff. He was in because his engine had started knocking on the way to work. And by the time I got the valve cover off, I already knew it was too late. Lifter collapsed. Cylinder 5. Camshaft chewed up. The whole top end shot. Same kind of truck. Same motor. Same roads, probably the same dealer. The only thing separating those two men was information. I've been at this since 2008, and I've worked on everything GM puts out. Silverados. Sierras. Tahoes. Yukons. Suburbans. Escalades. The 5.3 and the 6.2. Doesn't matter which badge is on the tailgate. They all carry the same problem. So here's the information one of those guys had and the other one didn't. It's called Active Fuel Management. AFM. GM started building it into their V6s and V8s back in 2007 to squeeze out a little better mileage on the highway. Maybe a mile or two a gallon. All to hit government fuel economy numbers. The way it works, the motor quietly shuts down half its cylinders when you're just cruising along. And the little lifters that pull that off have a tiny pin inside them that's constantly clicking in and out. Lock, unlock, lock, unlock. Hundreds of times a drive. Thousands of times a week. Eventually one of those pins wears through. The lifter drops. And it starts grinding the camshaft down like a chisel on butter. And what nobody tells you is that the shudder you feel around 40 or 50 mph? That's the system cycling. Every single time. Here's what really gets me. The pre-2007 trucks, the ones without AFM, they're bulletproof. I've got customers still daily driving them with 260,000 miles on the odometer. Not a problem in the world. GM took a perfectly good motor that would have lasted a lifetime and bolted this system onto it. And it is wrecking engines that should have run forever. The guys who hang around the forums already know all of this. So do the techs. They handled this years ago. They didn't sit around waiting for the dealership to mail them a warning letter, because that letter is never coming. It's the guys who figured somebody would've told them who end up on my lift. And I want to be clear, because this part matters. Maintenance has nothing to do with it. I've torn down motors with barely 30,000 miles on the clock. I pulled apart a Tahoe last summer with 24,000 on it. Practically a brand new truck. Owner had it less than a year. Spotless oil. Best synthetic money can buy, changed early every time. Made no difference. I've seen guys with full dealer records, every interval stamped. Made no difference. The oil changes were never the problem. The pin was. And no amount of babying that truck stops that pin from cycling every single time you drive. That's the part that eats at me. These are good motors. Take the AFM out of the equation and a 5.3 or a 6.2 will run 300,000 miles and never blink. So a few years ago I started telling every single owner who comes through my doors the exact same thing the smart guys already knew. Get yourself a FullForce disabler. It plugs right into the port under your dash. Couple of seconds and you're done. It just tells the computer to leave every cylinder running, full time. No more cycling. No more beating those lifters back and forth every time you turn the key. It doesn't reprogram anything. Doesn't touch your tune. And unplug it before a dealer visit and there's absolutely zero trace it was ever installed. I've had customers come back at 40,000, 60,000, 80,000 miles after I put one in. Zero issues. The trucks run smoother. And the lifters aren't getting beaten to death every single drive. I won't sit here and tell you it's magic. A lifter that's already damaged is a lifter that's already damaged, and this won't un-ring that bell. But it takes away the one thing causing all that wear in the first place. That's the whole game. You don't need a five-thousand-dollar delete. You don't need an expensive tune. You don't need to tear anything apart. You just need to stop the cycling. I'm not writing this for any company. I'm writing it because I'm tired of watching the guys who didn't know pay four and five figures for it. I'm tired of being the guy who has to break the news. I'm tired of knowing that the guys who did know fixed the whole thing for the price of a tank of gas, and the only difference was that somebody told them first. If you drive a Silverado, Sierra, Tahoe, Yukon, Suburban, or Escalade from 2007 or newer with a V6 or V8, you've got AFM. You've got those lifters, and they're cycling every single time you drive. So be the guy who already knew. Not the one I'm scraping metal out of next month. EDIT: A bunch of folks asked, so here it is. The one I put my faith in is FullForce. This is where to find it: https://www.tryfullforce.com/products/fullforce™-afm-dfm-disabler They back it with a 60-day guarantee too. I've handed out more than I can count and not one's ever come back to me. Not one. See less
    • Thanks for following along. I'm not author material, my tenses are all over the place and an editor would have a heck of a time cleaning up after me. Reading and writing is still a fun pastime though.   My new scanner came in yesterday, wow, where the heck has this thing been?! It connects right up to the Blazer, there's all kinds of bidirectional tests like EGR activation and percentage, toggle the fuel pump relay, EVAP purge valve, IAC control, AC relay, reset the transmission's adaptive learning, toggle shift solenoids and TCC lockup, and I can reset fuel trims with the click of a button...all things I could have used over the last 60 days!   It's also telling me there is a stored code in the ABS module for front left wheel sensor open and something about the brake switch. The ABS dash light works. It illuminates normally during the self-test at key on/ start and that's it. I cleared the codes and will see if they set when I take it out later. That, and I'm going to get (hopefully) real data on timing and cam ******. The PID's are there.   I connected the tool to my truck...holy smokes. Newer vehicles make early OBDII vehicles look like 8-bit, pixelated, early Nintendo stuff. This? This is like wearing 3D virtual reality goggles playing one of those elaborate, cinematic video games with seasons and plots in comparison. There are SO MANY modules and SO MANY tests and SO MUCH data. There's a scanner sequence for filling the coolant...   End of the day, it's a tool with way more power than I need, but the versatility to do old and new is there (and I need an adapter to connect it to my OBDI Camaro). It will allow me to do the first pass of diagnosis when out-of-warranty vehicles need help, and it will enable more DIY maintenance like brake system bleeding, ABS bleed, etc. I probably over-bought here, but, mission is accomplished.   Enjoy your Sunday...I need to shut this machine down and go get ready for the week ahead.
    • Not that I've read, after all the issues they've had in the past I'm pretty sure they learned their lesson.
