Yes, in the corners of the dash closest to windshield.
Edited by MotoMedic
I have a 2014 Silverado LTZ Double Cab with Bose Navigation and sub in the console. It looks just like the picture above, but I have no clue of the sizes of the speakers.
I have a 2014 silverado crew cab 2WT and I haven't opened that part but I do hear sound coming out of there.
Wicked Galaxy Note 3
It's a 3" speaker in there I replaced mine with a pair of 3 1/2s but it took some trimming and to get them to fit
Dash speaker is an odd size, about 2-3/4". I looked into putting 3-1/2" full range speakers in the dash, would require opening the hole to make them fit. You'd want to get a separate bass blocker, capacitor provided with the factory speaker is integral to the speaker. There are 2.75" speakers available. Know nothing about this product line, company called Powerbass has a S-275 2-3/4" dash replacement speaker listed for Chryslers. I will be looking into replacing my dash speakers further in the near future.
  • 6 months later...
Bringing this back to the top, call it "Dash Speakers Part II". Speakers in my '15 DC have started to crackle a little. To be fair, they are amplified and I did tend to listen to it a little bit on the loud side when the weather was nice and the windows were down. Had the truck little over 10 months and just odometer just turned 20k. I mentioned Powerbass S-275 in the reply above from back in May as a possibility.
Has anyone found a reasonably easy speaker to swap in?
Does anyone know how to remove the grill to get the dash speaker out, obviously without causing any damage? Thank you
I've been slowly doing my own system upgade and taking pictures along the way. I hope to creat a nice build list once I am finished. But to answer your question(s)... I know for the bose setup these are the speakers sizes:
Front Dash: 2.5" @ 3.2ohms (with bracket is about 2 3/4")
Front Door: 6x9" woofer @ 2ohms (bose)
Back Door: 5.25" spearker @ 3.5ohms (bose)
Subwoofer: 5.25" @ 1ohm (bose with bucket seats)
To remove the dash speakers you will need to remove the pillar covers/trim first on both sized. The passenger side will have two bolts for the "oh sh1t" handle. Then you can pry up the speaker grill. It is one piece going from both sides (connecting both speaker grills). Be sure to be mindful of the sensor for your automatic lights. the cable is short and if you forget you can break the connector for the wires.
  • Thanks 2
Is the dash speaker basically a tweeter? I'm wondering about doing front door component speakers and just routing the tweeter into the dash. Thoughts?
With the Bose setup, the dash speakers are acting as midranges and tweeters. The frequency range of the signal is different then that of the door speakers in that the door speakers are providing some of the lows and midrange, but the high frequencies are cutoff. Hope that makes sense.
Here are some pictures of an RTA reading of each of the three signals.
Dash Signal
Door Signal
Sub Signal
I am currently using a Mosconi 6to8V8 for my digital processing. I changed from the Audison Bit One simply for the ease of use and the controller. The really cool thing I have found with my processor is the fact I can sum the channels how I want. Realizing that the Bluetooth output and chimes are only on the left front dash speaker, I limit the use of that signal to exactly that of highs and am cautious to sum that channel to the other speakers in the system. Since my three way setups are mainly on the dash area, I keep that signal contained there and do not allow it to be passed to the doors or sub which will happen if you sum all channels using something like an Audiocontrol or like processor.
That being said, in my system, the dash speakers get the dash signal, the doors get the door signal, and the sub gets a mixture of the door and sub signal. At least that's the way I have it now. Still tuning, as the system is not yet completed. Progress can be seen on my build linked below.
I hope that helps.
Edited by Strykers_Inc
Dash and front door speakers are fed from the same wiring off the head unit ( at least on the non-Bose systems). These speakers get the full frequency range with the dash speaker getting a low frequency cut via a capacitor (what I would assume is at 500hz, 6db roll-off). Higher frequencies in the door speakers just roll off due to speaker design. When I added the amplifier, running the front speakers with 80hz, 12db high pass filter really cleaned them up. Removing that amount of bass tightened up the mid bass a lot and cleaned up the midrange. Pair of 8" subs added to the rear doors filled in the bottom end nicely. Playing with crossover points makes all the difference. Could be wrong but I don't think the non-Bose dash speakers have the same high end response as the dash speakers in the Bose system. I did have a loner with the factory Bose in it, I do believe it had better high end. Might be worth the swap to pick up a set of factory dash speakers from the Bose system for comparison. 3.2ohms at the dash would not be the best for standard head unit, but would work with an aftermarket amp that is stable to 2 ohms.
    • A little girl said her prayers every night before bed and she asked G d to watch after each person she loved. One night she forgot to pray for her babysitter and her babysitter died. A few days later she forgot to pray for someone else and they died. The next night she forgot to pray for her dad. The next morning her dad was terrified. A bus almost crashed into him. He almost fell off a fifty foot ladder and almost wrecked on the way home. When he arrived home, he said I had a terrible day. His wife replied, “You think you had a bad day? My aerobics teacher died during class.
    • Nice! I had one here, once. The car dealer I used to haul for stopped by with it. That was over 10 years ago now. Those are SUPER rare these days, especially up here! Never even see them at car shows anymore.   https://postimg.cc/0rvcNZ1W
    • I remember watching one of the auctions on TV. It just happened that they had two little red express trucks. My brother bought one new in 1979, still has it. So I hung on to watch them cross. The retro redone example brought more bids and went for more money than the original one did. My brother has redone his 3 times and raced it. He’s now in the process of making more tame for cruising.
    • I always upgraded the suspension and steering components - bushings and ball joints, and had older cars that I could out-corner ANY modern car with. I used to be able to take my '78 Cutlass on off-ramps at stupid speeds and make the sharp MA corners without even squealing the tires. So much fun. My '72 El Camino must've had work done by the previous owner, since that thing seemed to handle even better than the '78.   I think the suspension & steering on the '72 was much more advanced than the '64, so that probably just made a good system even better.   I'm the same way with vehicles. I hate having to worry about the paint on my '93 W250 Cummins. I'm not used to that, lol.   https://postimg.cc/mzKr55sY
    • BEAUTIFUL!! That a Cutlass F85? Or 442? My side-ID skills are lacking thanks to failing memory, lol. Love that color & year, too!   Yeah I was never big on entering my own stuff, but I always liked seeing what everyone had, the rare models, and what's been modified. That was always fun. These days I have barely enough time to do what needs to be done at home.    Oddly enough, here in MA there are more car shows than ever in history! You'd think up here it would be dead, but it's bigger than EVER!          Took the 940 for its maiden voyage with the carburetor. At first I couldn't get out of the yard! This originally had the "Bosch" system (our other 940 has Regina - single fuel pump in fuel tank, and space-age-looking ignition coil on driver's fender) - that has dual fuel pumps. One in the tank, and one under the center left of the vehicle. I had unplugged the external one thinking I wouldn't need it with the carburetor ... but the way I have the pressure regulator hooked up, 90% of the fuel volume is going back to the fuel tank, so cranked all the way down, the regulator is only supplying a hair above 3.5 PSI to the carb. Turns out the in-tank pump (15 PSI alone, instead of 45) couldn't handle the load. Plugged it back in and went for a rip. Ran great!   Throttle response is always amazing with carburetors. ZERO delay that no FI system can reproduce. Also fires up in half the crank rotations as before. Low end power was DRAMATICALLY improved. There was an ongoing lean issue with the FI that I got tired of figuring out, so this is a MASSIVE improvement! Above 50 MPH on hills it feels SUPER weak, though. This is more than likely due to the timing not being advanced enough by the computer, since it believes there are multiple failures. I can live with that through the winter. Will keep me from passing slowpokes where I shouldn't and getting speeding tickets at least. 😁
