22" Magnaflow.....
Luster
I had the 22" Magnaflow put on my new '14 soon after I bought it. I had the same muffler on my '13 and loved the sound.
As soon as I picked up the truck from the muffler shop, I immediately went back and had them remove the resonator and the "flapper valve"... didn't help much. Still WAY too quiet for my taste.
It still sounds almost stock!
Question..... How many miles will it take for the muffler to "burn in" and get a little more volume to it?
(In only have about 500 miles on the Magnaflow)
Or possibly the smaller Magnaflow would be better???
  • Replies 45
If you plan on removing 3rd cat, do that first before changing muffler, it will help a little and burn in May take a couple thousand miles.
Had To Tell You But You Probably Gonna Need To Get A Smaller Muffler. Get A 18" Magnaflow. You Be Happier With it.
14" Magnaflow on mine with third cat delete, couldn't be happier!
Well there you go. Can't beat these guys with first hand experience
OK, from the responses, maybe I should go with the 18" or the 14"... I really would like to get this right this time. I've already been to the shop twice... third time's a charm?! :fingersx:
Is this their 3" or 3.5" muffler?
3" muffler...
3" muffler...
If YouWant It LOuD Go With 14. I Like My 18. I Like Loud On My Hotrod Not My Truck. Plus When I Put Headers On My Truck It's Gona Be Loud.
Yes The So Called "Third Cat" Needs To Go Also.
Ok pretty good advice. Loud is not my goal here, just a very nice deep rumble that gets ferocious at WOT. I know what you mean about your hotrod... I've got an LS3 Corvette with Billy Boats and it's LOUD!
Thanks! Bill
With the third cat delete it's not obnoxiously loud, deeper, throatier sounds is more like it.
Mike
Mike
:thumbs:
3" muffler...
Why you didn't go 3.5"? That's the diameter of the piping. And is the case 22" or total length??
Its not really a drastic change. But it will get a bit louder. It will be gradual, so you wont really notice the difference. Over the course of 2-3k miles it should break in nicely.
    • For a limited time, retail accounts receive a free fender cover (G2803) with their order of $750 or more when they use code FENDER926 at checkout. The promotion runs through Sept. 8, 2026. Own a business and want to apply for a retail account?  Apply here. https://www.amsoil.com/business-opportunities/sell-in-your-store/?zo=521390
    • Thanks for that, yes just because I could I measured what came out just to give me some guidance although I already knew to expect it to take at least 9.5 to just throwing in the whole 10 quarts off the shot and doing a one and done heat cycle to drop out the excess to get to the proper level. I don't recall exactly now what I measured that came out but was less than I put back in, I knew I spilled some on the garage floor but the main part was that I was thrilled in the discovery I did not have to touch my exhaust to flex it down. The gasket manipulating is a pain of course to create that clearance to take the pan out and put back in but its all very doable if one is careful and not forcing the gasket to flex too much. From the quote I got at a transmission shop of 900.00 here in Canada ( never asked at the dealer what they charge ) I saved 700.00 doing it myself after paying for the supplies so that to me paid very good wages !, and I knew what fluid was put in and that I had changed the filter and that the level is correct without any doubts.
    • I do have one of the AFM diasable box, using it for last 1.5 years.
    • I found a setup that lets me open the cover partway with racks installed, using side-rail-mounted systems for easy access.
    • Typically its said and I agree so far that the engine oil drain plug oring is not required to be changed out unless you see some damage happening to the oring as apparently the oring lasts well. The dealer I have been getting a few parts from never even stocked the oring but instead stocked the whole drain plug that comes with a new oring which for the dealer is easier because they just throw in a new drain plug if there was any question about damage on it as well and charge the customer accordingly but again only if it is needed.    Also a hint about the drain plug oring to help it last vs a risk of causing damage to it, after its been removed and wiped off or washed off ( that is a whole other topic about some solvents damaging orings because some solvent types do ) to make sure to relube the oring with a bit of new oil so that it won't "grip" on the sealing surface of the pan and needlessly stress out the oring. Its no different than putting some oil on the sealing ring of the engine oil filter. So I just grabbed a new drain plug to have on hand although more recently bought just the oring as well but as its special it costs half the price of the drain plug ... !   Since you mentioned the hate to be empty handed theme, I am not sure what you have in the way of filter removal tools as I like using the exact sized for the filter steel 1" wide band with side to side swivel handle filter removal tool, and it can be used to snug up the filter without risk of damaging a filter as well ( its probably a lisle brand I have ). The drain plug hex size is 15mm and I always like using a 6 point socket if I have a choice and with this truck I've been using just a 3/8 ratchet that has a fairly long handle. Do you have a funnel that will work to pour oil in as that is definitely the short coming bastard part about the design with that fill port on the valve cover on such an angle that no normal funnel will even work. There are adapters and things on the market that will set into or screw into that fill port, I didn't want to deal with US shipping as that is all I was seeing at the time so caved and bought a Lisle brand multi vehicle fit adapter funnel kit and it really works well but there are much less expensive adapters out there that work in conjunction with an off the shelf funnel that would do the job also. Now that I have it, I like how it works and works so slick with the shape of the Amsoil 1 quart containers I have now switched over to. Whatever you do, have a funnel system of some sort as you will be swearing if you dropped the oil and then realize you have nothing to properly pour new oil in without spilling it all over the engine !.     Other comments, quite a bit of oil flows out down the filter when its cracked loose due to the housing above the filter so let it dribble down the filter until it slacks off flow and then remove the filter to create less possible mess. It seems these engines can sit for quite a while and drip and if you have time let it sit there and drip out of the engine as much as it wants. Also a good time to grease the 9 zerks on the front end, that's my typical practice anyway to grease the suspension and steering each time I change the oil. And remember to reset the oil change minder ( not something I am used to doing with older vehicles and equipment ).
