Went with Rancho quicklift adjustable shocks and new rubber Cooper AT3 275/60r20, I thinkk I'm going to get 1/2 spacers.
Before
20140409_184036.jpgAfter, subtle, I know
11999282_10205302907308003_960325655_o.j
WendysOrBust your are pretty close 33.2x10.83 I believe.
here are a few more.
Edited by RvNikkor
  • Like 7
Man, again, that setup looks sooo good. You really sold me on the 275/70's. I'm looking to go with the same NV's but was gonna go with a 285/65 (~32.5"), the 275/70's look so much better though. I really wish they sold lug nuts the same color as the faux bead bolts on the nv. Zinc plated lug nuts would look tits with those wheels.
Yea, I am going to start the hunt to find some or just go black. But The contrast of the 3 different colors is pretty good looking to. I to almost went with the 285. But decided to go for it. the pictures don't do it justice. It makes a statement.
I recommend you see 275s in person before you shell out $1000 for them. It's a tall tire but not very wide. The 285s lacks .5" in height, but looks much beefier in width. You will notice the width of the 285/65 long before you will notice it's .5" shorter than the 275/70.
I have looked through this entire thread and am still kind of torn.
I would like to stick with 305-55-20XL Nitto Terra Grappler G2 tires because they give me the size I am looking for without being 10ply becuase I do not need that heavy duty of a tire and the extra weight.
The wheels I want only come in +6 offset. I have been trying to look at +0 offset with the 305's to get a good idea of how far they stick out since it is relatively close.
I would like them to just barely stick out. I have a 2" level, but will add the extra spacer to make it 2.5" if need be. Ideally I would be at about a +14-+18 offset, but like I said, the wheels I prefer only come in +6.
Does anybody have a down the side shot or pics with this set up of a 0 offset with 305-55-20's or +18 with the same size tire?
Thanks in advance for your help!
heres mine. RC 2.5 with 1.5 zone body lift. 305 55 20 nitto g2 with 0 offset. Had to add body lift because it was rubbing inner carpet and I wanted no rub.
Sent from my iPhone
using Tapatalk
Thank you sir, greatly appreciate it! The spacers certainly help a lot - great looking truck! I had the same tires as you on my truck (and sle wheels) and now have 275-60-20 Toyo Open Countrys. They are a little skinny for my liking so I am going to get a new wheel and tire package and sell what I currently have.
The 2 wheels I am looking at only come in 0mm and +6mm offset. I am torn on which one to go with (6mm is barely any difference than 0, just trying to pick a style at this point) and then the big decision is tires.
295-55-20 Toyo Open County AT2 - 60lbs (10-ply)
305-55-20XL Nitto Terra Grappler G2 - 51lbs (4-ply)
Due to the low offset id like to get the 295's since they're narrower but 10lbs a corner and being 10ply vs 4ply has me steering towards the Nittos, I just don't want them to stick out too far past the fenders.
Ahh, decisions decisions!
if u want no rub go with 295 on the 2.5 level kit. 305 will rub a little on 2.5 level
Stock 17's with Nitto Terra Grappler G2 285/75R17
Dude nice work!!! Looks great...... Finally someone willing to put more rubber on than rim....
Edited by chevy2tuff2006
I totally agree. But he will notice the price of the 285s being way more before anything else. At least I will, which is why I'm going 275/70
Sent from my SM-G920W8 using Tapatalk
Thank you kindly sir, have to say I'm very happy with it myself.
Thanks for your input, I checked BFGoodrich's website and the 275/70R18 is actually .7" taller than the 286/65R18. That is quite a bit, although you are right, the 275 does have a track width of 11' on an 8" wheel compared to the 285 of 11.5" on a 8.5" wheel.
http://www.bfgoodrichtires.com/tire-selector/category/off-road-tires/all-terrain-t-a-ko2/tire-details#techspecs
I still think the 275/70r18 is the way to go though. I've seen Higgs Boson's truck and his setup is similars to RvNikkor's except he's on the 285. Its not that much of a difference but the 275/70 does look taller and the width is just fine for me, after all the O.E Goodyears on the 20" wheels are already 11" wide
Some pictures for comparisons sake;
285/65r18 Toyo AT2 - Extreme
285/65r18 on Method Standards
275/70r18 BfGoodrich KO2
Again, not a crazy difference, both setups look great. Just a matter of personal choice. And unfortunately the Toyo AT2 does not come in the Extreme version for the 275/70, so the tire will look allot more tame, with less thread depth, and less aggressive side wall than the 285/65.
Edited by WendysOrBust
That white truck looks awesome with the 285s....big visual difference! Where is that one originally posted?
Edited by bcbz71
Thanks fuse, appreciate the insight!
Anyone running pro comp wheels on there truck not the tires but wheels. Trying to get a visual idea?
Sent from my SM-G900W8 using Tapatalk
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
