Haha it's going to be a while before I get the truck done but I will definitely get some nice pics when it is. Wheels tires and Kings are on order but I am really trying to wait out the winter here before installing. Going King 3.0 front, 2.5 rear, Method NV's with Toyo RT in 295/70/17. Oh and Mazzulla upper arms.
That's gonna be sick.
Sent from my Nexus 6 using Tapatalk
Got a 3.5" lift with 305/55r/20 BFGoodrich KO2s on 20x10 rims with a -24 offset. They rub slightly at full lock backing out of my driveway.
Federal 33x12.5 couragia MT with actual factory specs (32.8 x 12.3)
No rubbing with 2.5 front top strut spacer only.
should i get these wheels? great price with new tires.
pics of wheels and truck for reference. do plan to change to new ridge grapplers.
If your in the market for 20s then go with the newer style IMO.
whats up guys. new to the forum and im trying to get your opinions on which route to go. im planning on doing a 2.5 rc lift the tires and rim im still deciding but i want something with a little bit of negative offset and wont rub or affect suspection and gears.. opinions?
20161218 144628
Here's some nicer photos of my new setup, specs are as follows:
20x9 +0 XD820 Grenade
305/55/20 BFGoodrich KO2
Ziptied back side of front fenderwells back
NO RUBBING at all, in any direction at full lock
2.5" Pro Comp leveling kit - No changes to rear suspension from stock
let me know if you have any questions! I absolutely love the way it looks!
Do you happen to know what the Back Spacing is on these?
Yes, it's a 5" backspacing -- it's the only option for these wheels at 20x9 +0 with the bolt pattern for this truck. Let me know if you have any other questions!
My setup is similar to the one above. I almost went with the deep red as well but I have a hard time not buying white trucks.
20X9 LRG Gamer wheels +18 Offset.
305/55R20 BFGs
It has been an amazing truck so far and the 6.2L really moves with the 33's.
12963919 10156786921050284 8331116308181213805 N
LRG Wheels
2016 1500
14333179 10157465186910284 3606309088261069469 N
Great look and color combo.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
