quise2024 Posted December 11, 2016 Posted December 11, 2016 (edited) Ok all done now Black Rhino Everest 20x9 +15 Goodyear Wrangler Duratrac 275/60R20 Zone Offroad 2" Level (front only) Edited December 11, 2016 by quise2024 1
asalinasz39 Posted December 13, 2016 Posted December 13, 2016 Just ordered 33 12.50 r20 federal couragia mt from Walmart for $755 shipped to my home. Sent from my iPhone using Tapatalk 1
Sierra Jon Posted December 13, 2016 Posted December 13, 2016 For those that changed sizes... What are you running for psi? Still going by the factory recommendation? Sent from my Nexus 6 using Tapatalk
asalinasz39 Posted December 13, 2016 Posted December 13, 2016 (edited) For those that changed sizes... What are you running for psi? Still going by the factory recommendation? Sent from my Nexus 6 using Tapatalk I just finished doing some reading on this topic and discovered that for load E rating tires have a higher max psi and should be run at min 50 psi compared to the 35 factory tire specs Sent from my iPhone using Tapatalk Edited December 13, 2016 by asalinasz39
Sierra Jon Posted December 13, 2016 Posted December 13, 2016 I just finished doing some reading on this topic and discovered that for load E rating tires have a higher max psi and should be run at min 50 psi compared to the 35 factory tire specs Sent from my iPhone using Tapatalk Good point! I didn't go load E this time around. Sent from my Nexus 6 using Tapatalk
Waaazooo Posted December 13, 2016 Posted December 13, 2016 Wheels came in last week, tires arriving today looking to get them put on this afternoon What are they? I want them! Sent from my iPhone using Tapatalk
quise2024 Posted December 13, 2016 Posted December 13, 2016 What are they? I want them! Sent from my iPhone using Tapatalk Black Rhino Everest. I ordered them discounttiredirect, they price match along with free shipping. Sent from my SAMSUNG-SM-N910A using Tapatalk 1
abominable z71 Posted December 13, 2016 Posted December 13, 2016 For those that changed sizes... What are you running for psi? Still going by the factory recommendation? Sent from my Nexus 6 using Tapatalk There is a chart or formula offered by each tire manufacture, or you can email them they will tell you the recommended pressure. Toyo recommends 42 psi in a 285 65 18 E to match the factory P275 55 20 good years. The math depends on the factory load rating and whichever tire you replace it with, for example 305 55 20 E would not have the same recommended pressure as a 285 65 18 E because they have different load ranges regardless of both being E the 285 is a 125 at 80 psi while the 305 is a 121 at 65 PSI. The link below is from Toyo but most manufactures have somehting similar. https://toyotires-1524598101.netdna-ssl.com/media/1541/application_of_load_inflation_tables_20151020.pdf
Donstar Posted December 14, 2016 Posted December 14, 2016 (edited) So it was past time to do something to my girl. She needed new tires anyway...so why not go bigger? RC 2" leveling kit Firestone Destination A/T 285/70/R17 (up front the stock 255/70R17) No rubbing or clearance issues and she looks so much better. I like the looks of both versions of your truck. The first picture is with a 2" level and 255's, correct? I decided to stay with stock size on my new tires (255/70r17). I far prefer the looks of the larger sizes but could not justify any differences in costs, performance or ease of access. Ironically this tire size would have been considered a larger size upgrade less than ten years ago! I still have a 1.5" front leveling kit that needs to be installed. Now that I have committed to a few more years of the 255's, I was wondering if this level kit would enhance the looks or make it worse. I would appreciate comments or pictures from those that have kept the 255/70r17 tire size. Edited December 14, 2016 by Donstar
Tactical Swede Posted December 14, 2016 Posted December 14, 2016 I like the looks of both versions of your truck. The first picture is with a 2" level and 255's, correct?Thanks. The first pic is completely stock. The second is the 2" level and bigger tires.
tyrich88 Posted December 14, 2016 Posted December 14, 2016 Here's some nicer photos of my new setup, specs are as follows: 20x9 +0 XD820 Grenade 305/55/20 BFGoodrich KO2 Ziptied back side of front fenderwells back NO RUBBING at all, in any direction at full lock 2.5" Pro Comp leveling kit - No changes to rear suspension from stock let me know if you have any questions! I absolutely love the way it looks! Looks awesome!!! Love the wheels and tires! 1
89stroker Posted December 14, 2016 Posted December 14, 2016 Here's some nicer photos of my new setup, specs are as follows: 20x9 +0 XD820 Grenade 305/55/20 BFGoodrich KO2 Ziptied back side of front fenderwells back NO RUBBING at all, in any direction at full lock 2.5" Pro Comp leveling kit - No changes to rear suspension from stock let me know if you have any questions! I absolutely love the way it looks! Any pics of how you zip tied the fender liner back to fit these? Your tires come out to almost the exact same size as I am wanting to run on 0 offset wheels as well. I will be going 295/70/17 on 0 offset methods. 3
CaptainMcFunk Posted December 14, 2016 Posted December 14, 2016 Any pics of how you zip tied the fender liner back to fit these? Your tires come out to almost the exact same size as I am wanting to run on 0 offset wheels as well. I will be going 295/70/17 on 0 offset methods. Sure, I can get a picture as soon as I get off work here in about 2 hours or so
tyrich88 Posted December 14, 2016 Posted December 14, 2016 Any pics of how you zip tied the fender liner back to fit these? Your tires come out to almost the exact same size as I am wanting to run on 0 offset wheels as well. I will be going 295/70/17 on 0 offset methods. OOOOO post pics of that one! I'm a sucker for Method wheels
89stroker Posted December 14, 2016 Posted December 14, 2016 OOOOO post pics of that one! I'm a sucker for Method wheels Haha it's going to be a while before I get the truck done but I will definitely get some nice pics when it is. Wheels tires and Kings are on order but I am really trying to wait out the winter here before installing. Going King 3.0 front, 2.5 rear, Method NV's with Toyo RT in 295/70/17. Oh and Mazzulla upper arms. 2
Register a new accountSign in
