Got em on. They rub the mudflap a little at 3/4 turn forward, not at all full lock. Rub A LOT 3/4-full in reverse.
Black Rhino Everest 20x9 +15
Goodyear Wrangler Duratrac 275/60R20
Will have a zone 2" level put on Saturday
My Duratracs (same size) still rub after the level... The tread is huge on these things...
I'm planning on trimming the carpet, just haven't done it yet since it's so minor.
Sent from my Nexus 6 using Tapatalk
Yeah tread is a lot bigger than i thought it was gonna be. I like them though so far, only drove a total of maybe 20 minutes on them.
Im actually in the clear on the carpet, its the mudflap im rubbing but its not that mad in drive but reverse is another story, so loud. If the level isnt enough i see where i can just unscrew those flaps and should solve it
Sent from my SAMSUNG-SM-N910A using Tapatalk
What its sounding like inside in reverse. Not sure if i can pull forward into this spot in the garage or not but luckily tomorrow is the weekend so no work and level is being put on.
We'll see how it goes monday
[Video]https://youtu.be/IPFPdp2eAnM
Edited by quise2024
My 2016 2 wheel drive. Installed Motofab 2" spacers, 18x9 zero offset Pro Comp Rockwells with 275/70-18 bfg at's today. No rubbing at all
Edited by JKey
  • Like 3
Looks really good!
Don't trim the carpet liner! Drill two small holes and use zip ties and pull the liner back to the frame. I have 205/60/20 duratracs with level and this fixed the rubbing issues for mine
Honestly I don't know why but I can't bring myself to put zip ties on my truck haha
I'd only have to trim it 2"... It barely rubs.
Welp, wheels and tires came in today, but one of the wheels was damaged by FedEx...looks like I have to wait a couple more days to get them on!!! UGH!
Finally got them on! This is the only picture that I have, but there is no rubbing once I zip tied back the fender wells, more pics to come
Sent from my ZTE A2017U using Tapatalk
  • Like 4
Nitto Trail Grapplers. 285/65 Also installed 2.5 inch level/front only.
Just barely even with fender.
looks good
Here's some nicer photos of my new setup, specs are as follows:
20x9 +0 XD820 Grenade
305/55/20 BFGoodrich KO2
Ziptied back side of front fenderwells back
NO RUBBING at all, in any direction at full lock
2.5" Pro Comp leveling kit - No changes to rear suspension from stock
let me know if you have any questions! I absolutely love the way it looks!
  • Like 5
Mine was rubbing the mudflap not the liner. After the level it was clear of the mudflap except for slightest bit on the 3/4 but nothing like the little it was before. But i actually just took the mudflaps off completely vs cutting a piece off the inner corner.
Edited by quise2024
So it was past time to do something to my girl. She needed new tires anyway...so why not go bigger?
RC 2" leveling kit
Firestone Destination A/T
285/70/R17 (up front the stock 255/70R17)
No rubbing or clearance issues and she looks so much better.
    ncleg
    ncleg
  • Who's Online   6 Members, 0 Anonymous, 746 Guests (See full list)
    • I have a Retrax pro that I first had on my 2020 chevy and transferred it to my current GMC.  It stays in the garage most of the time, so hard for me to judge it's long term weather resistance.  It still works perfectly, been very durable.  It doesn't see oil patch usage, but it's not a mall queen.  It keeps most things mostly dry (small leaks) and the security of it is enough to slow someone down but not keep them out for long.  I would buy one again, it works for me.
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
    • The recall is for exactly this issue - those drain holes combined with the limited environmental capability of the tailgate electronics card inside the tailgate were a problem. The “safety issue” was the potential for the tailgate to spontaneously open, but all kinds of tailgate misbehavior can occur from water contamination of that control card.    There is no real fix yet. The initial recall just disabled the tailgate. Later, when parts became available, they would replace bad parts with new parts of the same bad design. My dealer is going nuts because the few times I let them get their hands on my truck, my tailgate is off due to a slide-in camper installation. They really want to cut my tailgate wires, but I won’t give them the chance. I will let them get their dirty hands on it when a real fix (redesign) is available.  My tailgate, which works just fine with sealant plugging the drain holes, will remain safe in a dry storage crate until then.
    • Yes your absolutely right, I been looking at the 4 inch BDS one and it acutely states you can use the stock 20’s just not the 17’s or 18’s, I also didn’t realize that with my 275/60r20 stock wheels I’m already running 33 inch diameter wheel setup lol so I can just run my stock wheels and tires atleast to start.
    • I would expect that to be lift-kit dependent.  If the kit has interference issues w stock wheels, then the kit/manufacturer should indicate that somewhere.
