My tire size is 285/70/17. I did not recalibrate yet. I know the mpc difference and take that into account but my normal driving has dropped and I'm not pushing it
Mine dropped too. I have 275/70/18 so they're about the same height. Its the weight of the 10 ply tires mostly. Gearing is a little different, but in stop and go, the weight is the biggest thing. Mine dropped as well.
Only way to truly fix it is to go back to stock tires... NOT WORTH IT (in my opinion)
But you could get a custom tune from DiabLew, those seem to help a little bit.
Just dont let the dealership know you did it.
'16 Tungsten. 305/40/22 114v load rating on 22x9.5 Platinum Divine wheels. +25 offset.
(Sorry in advance if this happens to be a dumb question)
Why do people seem to fret slightly when going from a 45lb tire to, say, a 60lb tire? I understand that it would take more to turn the wheel because of the added weight, but in the grand scheme of things, that's only an extra 60 lbs of weight added as a total (15lbsx4wheels).
But that 60 lbs of added weight is next to nothing, considering when you are driving alone you alone are adding 130-200lbs to the truck by your own weight.... then if you have at least one passenger (wife/significant other/friend), there's another 100-150 usually added to that. So why do people fret about adding 60lbs of unsprung weight to their truck when they already add 200-300lbs by getting in the vehicle?
Again, I apologize if it sounds dumb, that just happened to run through my mind the other night. If somebody could set me straight, that'd be fantastic.
Doesn't every pound of un-sprung weight equate to something like 10 pounds of sprung weight?...so if that's true 60lbs would be a noticeable difference. I'm probably wrong with the conversion but don't thing it's 1 for 1.
The rotating weight of the tires is not equal to adding weight into the pickup.
If you drive around on stock tires, then put another set on that adds 15lbs per tire, it is a VERY noticeable difference in acceleration because the truck is having to turn that much more weight.
If you were to just add 60 lbs into the truck, you wouldn't even notice. Even adding a few people into the vehicle isnt as easily noticeable in regards to performance and acceleration.
I race mountain bikes and in bike racing, you notice a VERY large change in the handling characteristics, acceleration and overall performance of the bike as soon as you drop weight in your wheels/tires/drivetrain (any rotating mass on the bike) because of the energy it takes to rotate that weight.
So in competitive racing you see people spending more money upgrading wheels than you do on most of the other components, because its the smarter place to put your money.
Edited by tyrich88
Im running 305/65r 18 Nitto Terra Grapplers (33.58 x 12.30) on 18x9 Procomp series 32 wheels, 0 offset
3.5 RC lift and 1.5 zone BL and no rubbing what so ever
Edited by shoaf3152
I thought about trying to squeeze those onto my truck for my next set... not sure if they will fit with just a 2" level and stock wheels (maybe +18 offset wheels if I find a good deal on the ones i want)
Thanks for the info, my thought process was spinning the tires with the weight "over" the tires would be similar to having the weight "in" the tires.
That makes sense, I appreciate you explaining that to me.
So in essence, would that result in excessively accelerated wear/tear on powertrain components? Drive shaft and axles used to turn the wheels? I would think not, since there are a ton of people that add that kind of weight change, sometimes more than that, to their trucks, but perhaps they just don't care because they don't keep it long enough to matter? If you have info on this as well, that'd be fantastic.
It would make sense that it does put more wear on, because it takes more effort to get the wheels moving. But... its clearly not enough to matter. I've been running 10 ply tires for a long time and never had an issue. I know a lot of others on here run 10 ply tires as well and those heavier/wider tires weigh significantly more, so if it were to actually cause a problem that fast, you would hear about it.
Thanks for the information!
No rubbing at all
Do you think the 2" leveling is necessary, or could one get by with less or no leveling?
20" Chrome OEM Replicas 20X9 on 275/60R20 Nitto Terra Grappler G2. No level, no rub. 4a5ea113454eda33248d2fa3c67a3494.jpg
  • Like 4
Man those things aren't doing any good sitting there...Send them this way!
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
