So I am torn.....help me decide. I will be upgrading to either a 20X9 or a 20X10 in the next few months. I plan on running 295/55r20 Ridge Grapplers.
The 20X9 are 0 offset
The 20X10 are -19 Offset
I have a 2" Front Level Only
Will both of these work or is it safer to go with the 0 offset 20x9.
Also, help me decide on wheels. I want hostile sprockets but can't decide between black or chrome. I plan on eventually color matching the bumpers and grille if that makes a difference.
I have also considered Moto Metal 962s as well in either chrome or black.
i would definitely go chrome. The x10 will look MUCH better but you may have a hard time clearing them
You think just maybe zip tie carpet or am I going to have to trim metal? Or will they rub on sway bar?
Trim metal
definitely won't rub on the sway bar as for trimming it's gonna be a crap shoot but I think you'll need to zip tie carpet at the VERY least.
My dad ran 305/55 on 20x9 with a 2" level and rubbed slightly at full lock. You'll be a little higher, tire a little smaller, but the wheel is wider
Even with the 33x12.50?
The 305/70/17 is almost a 34" tire, that will rub for sure on just a leveled truck.
The 33x12.5 is a good choice. Chances are you'll rub a little though on full lock because of the width.
Interesting. This is making me lean towards the 20X9 then
Thanks for the info. This has me leaning toward the 20X9. But the 20X10 would look so much better lol. Maybe add a 1.5" Body lift? Lol
then it'd definitely work
even with just a 2.5" leveling kit it may clear with minor trimming. Look at the customoffsets.com gallery
Matt id go with the blade cut color. It's got your black and some machining best of both worlds on the chrome or black choice
Sent from my SM-G930W8 using Tapatalk
I agree, I went with black wheels with machine blades and it looks great on a dark color truck!
Sent from my LG-H918 using Tapatalk
I'm willing to make some trimming. I don't want 295/70r17s because I'm afraid they'll look too skinny compared to the 305s. The 305/65r17 just seems too short on these trucks.
Damn, this is making me lean toward the 20X9 then with 0 Offset
Thanks for the info
I have a 0 offset wheel wrapped in 285/70r17 and it rubs the liner. I test fit a 295 and it rubbed the body mount.
I have this setup as well, 2" RC Level. No rub at all.
