Just got my truck set up to where I wanted it.  Bought my track last Dec and was completely stock until 3 weeks ago.  Took me forever to decide on the setup and I couldn't be happier.  Fuel Crush 20" wrapped with BFG 285/55/r20.  Did a 2.25 level in the front absolutely no rubbing and plenty of clearance.  Added Corsa Touring this weekend and Corsa performance intake.  System is awesome.  When Cruising there is no drone and quiet as stock, when you get on it it just sounds amazing.  Perfect system in my opinion.
Quick question, maybe someone can help. But my truck came stock with the chrome 20” rims and I’ve since sold those and got 20” fuel Mavericks. Anyways I’m looking at a new setup and the rims I want are 17”, would I be able to just slap them on? I remember reading somewhere that anything under an 18” won’t fit because of the brake rotors? Thanks!
I've always been under the impression that 17" is the smallest you can go. Many members on here have 17's.
This looks perfect, nicely done. Got any more pics? If I change my wheels I think I will go that tire size. The Corsa touring sounds killer. I did a Borla muffler swap that sounds great but could be a little louder.
Sent from my Pixel XL using Tapatalk
17" is the base size for these trucks. Unless you paid extra money for the brake upgrade I can't see why they won't fit.
On 12/1/2017 at 8:58 PM, Mazinger-Z said:
 New Tires set up. 285/70/17 with BFG KO2 AT. Fuels 17' -12 offset. Front 2.25 leveling kit.
Anymore pics...that looks really good.
Haven't posted a pic in a while... 275/60R20 Duratracs, MotoFab 2" with Hellwig 987 helper springs. 2d69413c38479ccb3730a9c478e72ca5.jpg
That is one sharp looking truck!
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
