Fuel 20x9 +1 D625 Vandal's with 285/55R20 Nitto Ridge Grapplers
Man love those wheels!! Thats the same setup I would go with - what price did you throw down on the setup?
$4600 for wheels tires and sensors.
I got a little creative with some Midnight Silver and Dark Argent wheel paint. Tires are Wrangler Fortitude.
Looks good! Nice way to dress up the stock wheels. Colors look good too. I've seen this done twice before. One was a blue truck and one was red. The bright blue looked bad and the red wasn't much better.
However I think with the Earth tones of your truck it looks so much better.
Here's the ol rig. MO970 20x9 0 offset with 295/55 ridge grapsbbdbc4f31ee63049fb73148b3ef85d1d.jpg
Sent from my SAMSUNG-SM-G935A using Tapatalk
2017 Sierra SLT Premium Pkg.
Im running Fuel 20x10 Hostage with Terra Grappler 305/ 55 / 20
Stock rear blocks and Rancho Quick LIft 2” Struts in front
Looks great! What offset are the wheels? Any rubbing?
-12 offset , the shop that installed the wheels removed the inner fender liner and trimmed the sheet metal seam on inside fender . So far i have not any rubbing at all.
Looking to buy some summer tires. I have a 2" level kit, I do not want to have to trim anything. Found a good deal on some 33x12.5 RBP tires. Anybody have any insight on RBP? Are the loud and will they last 40k+ miles if I rotate?
Rims are 20x10 with a -12 offset. Still haven't decided if I want chrome or black and chrome
On 3/2/2018 at 7:36 AM, Bushleaguechew said:
Carpet or metal? I’ve got the same wheels and couldn’t fit 295/70/17 without hitting the cab mount on the driver side. My fronts raised 3”
 Trimmed some metal behind the carpet and pushed the carpet back to cover where trimmed. It looks good and hasn’t rubbed a bit.
On 11/8/2017 at 9:25 AM, Chevyrida254 said:
Nice truck man tire and wheel setup look good where did you get your headlights at ?
What kind and how much level?
On 11/8/2017 at 8:16 AM, Clutch Bo said:
leveling kit and 24's and 35's
Update. Took my blocks out and installed white oracle wheel lights
On 4/30/2017 at 4:22 PM, bcbz71 said:
Freakin' awesome look for a non-lifted truck. Good job.
I assume 18" stockers on a 2.5 level. True? Any issues with that width rubbing on the UCAs or Swaybar?
Edit: I zoomed in and saw they are 17s but at stock offset, they would have the same issues as 18s.
Slap some mud grapps on there:loser:
On ‎12‎/‎1‎/‎2017 at 8:58 PM, Mazinger-Z said:
 New Tires set up. 285/70/17 with BFG KO2 AT. Fuels 17' -12 offset. Front 2.25 leveling kit.
Do you have any rubbing with this set up?
Original plans for the truck or to get some Factory black 20s or 22s. I guess there are those opportunities where you're at the right place at the right time. I stumbled across these brand new 24 inch KMC rims and tires from a guy that was in a tight spot and needed some money so I picked them up for just over 1k. Bigger then I'm use to but I think it really goes well on the truck with the leveling kit. 2272eff24d1f8b48c25197da16a8b47a.jpg2327e3b0b31b241d221e9c3811416720.jpg
Sent from my VS988 using Tapatalk
It's always kinda nice to have friends in low places!
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
