Oil change
I was at the dealer today getting an oil change and after I got home I checked the level and it showed being overfilled. My paperwork show that they put in 9 qts instead of 8.5 qts. Should I take it back and have them drain out that extra oil or is that nothing to worry about?
I'd take it back and make them get it right. It may or may not hurt your truck but the fact that they overfilled it is unacceptable IMO.
Can you drain it yourself? An extra half quart might not cause any problems, but I would be weary of driving it back to the dealership if it were to cause problems.
The better thing to do is pull half a quart out thru the dipstick using a vacuum pump. But you most likely don't have one of those...
If they are using bottles (we are at the moment) we give out 9 quarts because the half quart comes from the 9th bottle.
I had my oil changed last week. The paper work states 9 quarts were used. Mine is at the top full mark when I checked it. The extra 1/2 quart will not hurt anything now if they had put 10 in I would have taken mine back.
The last time I had mine changed at a dealer they only put 5 quarts in a 6 quart crankcase (2007 LTZ 5.3L). I figured it prolly wouldn't hurt anything since I noticed it the next day. However I decided if they were that incompetent I'd just change my on oil from then on...and I have
I don't think 1/2 qt is much to worry about. You could just drain a bit out, use it for general lube around the garage. I have done that myself. I prefer to change my own oil, but will take a free change when offered.
Agreed, 1/2 quart is nothing to worry about. And like newdude stated, they're probably using bottles and just charged GM for 9 quarts.
    • WOW, something we agreed on. I only bought at sticker twice. A 94 impala ss and an Acura intagra type r. Made money on the first. Still have the second.
    • I prefer new, but not without a deal. Historically I've bought severely aged new inventory, leftover model year, unpopular configuration kind of stuff that sits around on dealer lots until they just want it gone. $10k off MSRP kind of stuff on a mid-priced truck. That really, really helps knock down that first year depreciation. It also requires being somewhat flexible on colors and options. I wouldn't buy a 4 cylinder if I was looking for an 8 cylinder, but if I got blue paint instead of black, or a great deal was lacking a minor option, I'm willing to overlook those things for savings.   Used <> used. Condition and history are everything. If I'm buying used I'm looking for cream of the crop. The truck from the guy who religiously pampers it, and then decides a year later he wants newer and nicer. NOT the ex-rental vehicle, or the crew cab traded in by the family with 7 kids who like to throw food, and the oil only got changed when there was time long after the oil life monitor started alerting.
    • @Grumpy Bear the conclusion from your post about doubling engine life has me curious. Are we literally talking an expected life of 250,000 miles potentially becomes 500,000 miles with a step up in filtration for fresh oil at "the oil factory" when it's bottled? I know you said that's a single variable among many, but, that's significant if the implication extends that far into a real world use case. I would think the oil marketing folks would really eat that up and make it known.   Particles introduced during oil change is a fairly easy one to avoid, but probably not intuitive as one would think. I.e. using a clean funnel. But...what was it wiped with? Paper towel leaves behind little fibers. A solvent if not dried is not something one would want to introduce into their engine with clean oil. And, keeping the oil filler neck clean and free of buildup.. Look at some guys engine bays and they're an absolute mess. Some say that's better than the drawbacks of cleaning it. I'm not a buyer of that idea.   I've also wondered if "flooding" the top end of the engine with oil while filling is a bad idea. During normal lubrication the oil flows in a gutter back into the galleys. But if you flood the area you're potentially washing the top of the rockers, springs, and other areas which may not get much oil wash normally, and you're mixing all that into the new oil. I just don't have the patience to pour slowly. 😆
    • It was a bad pump, i had a dealer next day the pump. Gm part #86591535. Tools needed 10mm socket, pliers for hose clamps, 1/2gal of Dexcool. About 30mins to remove and install, pump located near oil filter on driver's side frame rail. I had a local mobile mechanic delete the code, he had a snap on scan tool. My scanner could not delete the code. I drove back home about 700 miles since then, and no check engine light. Hope this helps someone in the future in the same situation i was in. Thank you to all that helped me.
