On 23/11/2018 at 11:28 PM, bbarde2 said:
Updated Pics and some more detail:
  • The only area that had the factory wax blown off was where the high pressure car wash could directly hit the frame, just under the rockers.
  • I went under the truck and checked everything else - the underside was surprisingly well coated with FF. It "stayed" decently.
  • I sprayed another pint of FF on the exposed frame and more of the underbody.
  • If you look at the pic I posted earlier the bare metal was beading water. What is interesting about this is that the FF was applied over the waxy factory undercoating. This waxy undercoating was blown off by high pressure car washing yet the water was beading on the bare metal. This means that the FF did wick its way to the metal and was protecting it somewhat.
This 2016 GM truck had rust on most of the welds and most sharp edges. It spent one winter in the NE with heavily salted roads. The weld rust is due to having really shitty wax undercoating from the factory that is pretty easily removed by normal washing and harsh winter conditions. Yes, welds rust.  These rusty areas have not grown since application of FF. So I think that FF does work but it will need to be re-applied. Mostly it makes me feel like I have done something to protect the truck against the horrible salty roads. We will see in about a year how it looks.
Got a good coat on there.
I think FF can work well for folks that do limited winter driving.  I do a fair bit of winter driving & I found it couldn't handle a whole winter of steady splashing and spray from wet salty roads, especially on certain parts of the truck. It does need re-applying, or at least in my case that's what I found.
  • 3 months later...
  • 5 months later...
On 11/19/2018 at 8:44 PM, bbarde2 said:
2016 Silverado + Fluid Film application about a month ago + a few car washes + a few days of salted snowy roads. It definitely softens the factory 2016 undercoating. I am going to apply in those spots again.
Did you use the areosol cans or from gallon can with the required spray equipment?
Just found this topic...
Bought a 2014 truck with 39k on it from new mexico in March ..... Has never seen snow or salt , frame looked flawless.
Brought the truck back to Michigan (home of salt and shit roads) had it professionally fluid filmed immediately when I arrived in Michigan.
I have noticed the fluid film has attacked the factory undercoating and it will actually wipe off with my finger , leaving bare metal under it .
I hope to not drive the truck in the winter , but I am concerned about rusting while the truck sits outside in my driveway during the winter months .
So surprisingly few people have chimed in here.
I've got a 2014 GMC Sierra 6.2 CC SLT Max Tow
I never used fluid film and in 2016 realized they don't make american cars like the others I've owned. The rust was gross. I live in Michigan and understood why so many trucks are rusted out in 10 years.
I FF'd the shit out of my truck and the wax definitely peeled where I poked at it but otherwise it was just stick goop that worked to prevent rust. IF anything, untouched, the FF extended the life though also softened the wax.
In 2017 I used a chisel, elbow grease, and brake cleaner and super degreaser by meguiars out of a pressure washer to remove the FF and the wax coat. Then I rust converted it (plexoyl or something, blue/white spray cans) and coated it 3x with flat black enamel paint (rustoleum). After that had dried 100% (it was summer) I put a thick layer of FF on and touch it up 2x a year. This has stopped ALL rust and has worked great. Don't need to wash it - at first this was shady feeling but seriously. The FF - left to it's own - will coat your shit and work. If you have to, for peace of mind, touch it up and  thicken it up at will.
DEFINITELY 100% without question - spray this shit in your rocker panels, in your doors, on your hinges, and in your cab corners. It will keep them from rotting out from the inside. If you get it on the rubber weather strips they'll warp a little but they are cheap and easy to repair if you don't care to apply with caution. When I bore scoped mine in 2016 there was lots of specs of rust forming which have not changed since I started blasting FF in there. Greasy yep. Smelly, yep. But that goes away after a few days and no one looks inside your doors. Definitely not in your rocker panels.
I just did the same on my 2020 and got the same result. Is it giving you any issue so far or do you just keep re applying
Any update? How’s the truck holding up I just applied on my 2020 Silverado
The general consensus is get the Daubart chemical factory stuff and just touch up as needed. I've used NH Oil Undercoating and it slightly softened the coating up but seems to provide another layer of protection. Avoid high pressure under carriage washed they'll just blow off the frame wax.
Edited by Lsgun1
I was doing NH OIL as well. It was inexpensive, but required annual re-application and it forces you to avoid automated car washes. I hadn't thoroughly washed the truck in over 3 years (not good in New England). Anyway, I got introduced to Wax-Oyl this past summer and so far, so good...been on a few months and have gone through numerous automagic undercarriagee washes with no negative results. While it's not 100% solid (I.e., like paint and the like), it clings to the frame and various parts well enough that you have to really get at it with a scraper to penetrate/remove it. The 2 obvious differences between them are (a) cost and (b) coverage. Wax-Oyl is 3x the cost ($750 vs $250) to apply and requires maintenance every 2-3 years ($180-250). Also, Wax-Oyl is only applied to key areas of the undercarriage whereas NH OIL covers everything. At first I didn't care about the overspray of the NH OIL, but then I started working underneath the truck and man, that stuff is nasty and it sucks when trying to work on stuff it's been applied to.
Just did some touchup under mine today.  I used Nox-Rust for the first time and will have to take a look how it dried.  Previously was just using whatever flat black primer I had laying around.  My frame looks great.  It's a 2018 but gets driven in all weather and pressure washed underneath regularly.  That Fluid Film may be good stuff but if I applied that and melted off the factory wax like the pictures I'd puke!
Yeah I just washed all of it off took a lot more wax off and now a lot of bare metal frame is showing. Taking it to go get undercoated on Thursday. Guy says he can fix it so we shall see. Paying him $800 plus $90 to touch up once a year
What did you do to remedy this? Did you just spray all the bare spots again. I put fluid film on my 2020 2500 and have the same issue. Bring it to a place to get undercoating that way I get their 10 year warranty that comes with it.
I've sprayed my frame with a DIY oil/solvent/vaseline solution, and so far (in my third Canadian winter) no loss of factory undercoating.
Not sure it's a big loss if you do lose the OEM coating.   The coating on my truck was bleeding rust right through it, especially around the frame welds, when the truck was brand new.
I'll take my periodic oil sprays, thanks, and the less it costs the better.    It's supposed to be cheap insurance after all.
    DM22
    DM22
  • Who's Online   4 Members, 1 Anonymous, 1,856 Guests (See full list)
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
