Protecting receiver hitch from rust
toolmiser
I've got a new silverado with the factory receiver hitch. I know it's painted, but what can be done to keep it looking nice thru the years? Waxing it doesn't seem like a good option- it probably wouldn't wipe off well and would look bad if it didn't. I only occasionally use the hitch, but on my old truck (2001) it was looking pretty tired, and the rest of the truck still looked good. Thanks for all ideas. I don't normally leave the bar in it either.
I've only seen surface rust on hitches, never rust that goes through the metal itself. So I wouldn't worry too much about it. A hitch isn't made to look good. If you look they just try to hide it from view instead of trying to make it look good.
wax it, when it gets rusty sand and put a fresh coat of paint, heck you could even just brush it on.
There are numerous anti-rust products on the market from simple WD-40 to Boeshield T-9 to marine grease to Rust-Olenum.
A good powder coat will hold up nicely. My bumper has held up great. I see a lot of painted ones that are really rusty. For durability powder coat can't be beat. I'm planning on having my hitch done eventually.
I spray mine down with white lithium WD40 and it sticks well and will last for a month probably longer, but I spray it on usually when I wash it. Weird but works good for me!
I personally haven't done anything to mine except use it and forget about it. I typically always have a hitch in the receiver but I'm not worried about the appearance of it in the least.
Toolmiser, like you, I don't like the looks of harmless surface rust anywhere on my vehicles and that includes the hitch. I traded in an 05 Trailblazer on my 2014 Silverado. About once a year or so I used to mask off my receiver hitch or maybe even just use a handheld piece of cardboard and touch it up with gloss black Rustoleum. To me, it makes a vehicle look better without the surface rust showing. It may also be one of the reasons that I received what I consider top dollar on a trade-in for my Trailblazer.
My 11 was getting rusty at the welds, hit it with rustoleum looks good as new
We have a stinger in ours 9 months out of the year ... used to pull our travel trailer on weekends and vacation. Since there is always metal grinding on metal, there is no way to keep it from a bit of rust. What seems to work very well, however is the spray on bed liner on the stinger and outside of the receiver. All that really shows any use / rust is the interior of the receiver and that is quickly taken care of with a spray can just before winter hits..
    • I hope to high heaven this is wrong. My Chevy farm trucks frame is lasting way longer than a newer Nissan Titan XD I got for a steal, and it only pulls trailers. A decade younger and it's frame is already way rustier than the waxed Chevy I drive across longs and ditches. Also, hasn't Ford been having tones of troubles with rusted frames?
    • Batteries don’t always show signs of a few years ago my vehicle started fine in the morning and took me to work. After work the battery was completely dead and I needed a jump. No, I didn’t leave anything on and the battery was only a couple months old. It was replaced under warranty.
    • AFM is confirmed in the Corvette engine, so I'm assuming the higher volume trucks will get it as well
    • If his battery was that bad I would think it would have been showing signs before this that were ignored. Stinks that it happened the way it did in rush hour traffic, but this seems like a pretty fringe scenario. I don't mind it that bad and never turn it off. The only slight annoyance for me is the slight delay between brake to gas, but I have gotten used to it and figure if it can save a little gas why not.
    • That is a good correction. I think “severity” was probably the wrong word for what I meant. What I really mean is closer to event priority, relevance, and actionability — not “this code is severe” or “replace this part.” I agree that a truck can have a lot of trivial or historical communication codes, and if the product starts pushing alerts for every stored or low-value event, people will ignore it very quickly. So the alert logic would need to be filtered. For example, I would not want a random old communication code to generate a push notification by itself. A useful alert would probably need to be based on things like: - new vs historical - active vs stored - repeated vs one-time - duration of the event - whether it happened near the driver-marked symptom - whether it happened together with voltage drop, reset, bus-off, misfire, oil-pressure change, etc. - whether the same pattern repeats under similar conditions So instead of saying “severity,” maybe the product should organize events by affected system and priority. For example: Misfire event: Show misfire counts / roughness first, then fuel trims, RPM/load, DFM/AFM state if available, coolant/oil temp, voltage, and related DTCs. Oil-pressure event: Show oil pressure first, but only in context — RPM, load, oil temperature, coolant temperature, DFM/AFM state if available, voltage, and baseline comparison. Communication event: Show which module/network/message dropped, whether voltage dropped, whether the recorder reset, whether it was active or historical, and whether it repeated. Voltage/reset event: Show battery voltage, crank/wake/sleep state, module reset, communication dropouts, and what came back online first. That also solves the display-order problem you mentioned. The main report should not always show the same fixed list first. It should show the system that appears abnormal first, and then the supporting values for that system. I also agree that the truck already has an oil pressure gauge and MIL. The point would not be to duplicate those. The value would be in showing what else was happening before and after the warning or symptom. For example, if the MIL comes on for a misfire, the truck already told the driver there is a problem. The useful part would be: - which cylinder or bank looked abnormal first - whether it happened after an AFM/DFM transition - whether fuel trims were already moving - whether oil pressure or voltage changed at the same time - whether the same pattern happened previously without a MIL On the OBD port point, I think you may be right for a consumer-facing version. OBD is much easier for the average owner: - easier install - easier removal - inside the cabin - easier phone connection - easier data download - easier to include a pass-through port for another scanner OBD is also the right place for DTCs, freeze frame, VIN, calibration information, Mode 6, and normal scan-tool parameters. The reason I was looking at ECM-side recording is that some events may be gone by the time someone plugs in a scanner, and some powertrain-side network evidence may not be available the same way through the DLC. But I agree that if an OBD-based version can capture enough useful evidence for most owners, that is probably the cleaner consumer product. Maybe the split is: - OBD/DLC version for most consumers - ECM-side version only if it proves it adds evidence that the OBD version cannot get - shop/pro version if deeper powertrain-side event evidence is actually useful So I would not want to force the inline approach if the OBD workflow solves most of the real-world problem. Your last point is probably the key product requirement: the report should be specific to the system showing the abnormality. Not “here are 50 parameters.” More like: “Misfire-related event detected. Here are the misfire/fuel/DFM/context values.” or “Oil-pressure-related event detected. Here is oil pressure compared with RPM/load/temp/baseline.” or “Communication event detected. Here is what dropped, when, and whether voltage/reset happened first.” That is a much better way to think about the report.
