I'm all for doing the impossible, but my objection is from another angle- Is the magnetic ride suspension really that much better? If when buying my truck it was offered as a $2000 option I probably would laugh in my salesman's face, probably same result for under a grand.
That's one of the things I said in another post. But even then, I also wonder if magnetic ride makes as much of a difference on a truck as it does in a car. I know in a car you feel the bumps more since it's stiffer suspension and is also less suspension travel I could be wrong, but I don't think mag ride makes as much of a difference in a full size truck. Also what happens if someone lifts the truck, would it even work like it's supposed to.
If the OP has money to burn any not just sell the outdated 2014 and get a 2015+ with all the bells and whistles plus the magnetic ride control?
Speaking of which, does anyone know the part numbers so I can retrofit tc, stability control, electronic brake distribution, and a 6 speed to my 2000 Silverado?
Totally worth it to upgrade the 2000. It's perfectly spec'd. Lol.
How is this thread still going?
The short answer to the OP's question is YES.
If you have the money, you can probably pay to have your truck retrofitted with a refurbished NASA Rocketdyne RS-25 and send it into orbit.
Let the OP spend his money however he chooses. There's already people on this forum that have put 50k into their 50k trucks, no one tries to talk them out of it because they want to see the finished product/something they will never do. I say, let this guy do the same.
Edited by bladz1454
Not sure why you would want any of those things. The traction control and tranny seem to be complained about a lot on here, lol.
I think you missed the sarcasm in the posters voice.
Feels like GMFS up in here...
Not enough f*ggot calling and g*y bro stuff to be considered GMFS quality.
I've never had that problem there. :dunno:
How would the best/smoothest aftermarket shocks compare for ride quality and price?
What ones are the best?
Edited by EXSlider400
I think a nice set of Bilsteins and airbags would be pretty decent.
Ive seen Koni shocks for trucks but has anyone ever used them? I can't even find real reviews. I wonder how they compare to the mid level Bilstein's or non-coilover Fox's?
Check with some vette forums. I know I heard people asking the same question there a few years ago when the c6's came out with mag-ride. I'm sure if someone figured it out it would be there. At least a starting point for you to see if its possible. Since they've been out longer there's been more time for people to try things. It was a fairly popular request a few years ago. Not sure if anyone actually did it but its worth looking into. On the trucks its so new theres not gonna be much info out there yet but on other models that have had it there may be more. Just a thought.
The only other part the OP is missing is the BCM programming. You cant go into the dealer now on the 2014+ trucks and say "please program my BCM to do XYZ" like you could on the previous generation trucks. The dealer has to put in your VIN which has to match the VIN in the other modules and then they flash the software that GM has on file for your VIN for that module.
So how do you please on getting around that part?
    • So speaking of oil consumption with my L8T as I just changed the oil yesterday and made the switch over to Amsoil SS 0W-40 from the Mobil 1  5W-30 Truck and SUV I just dropped out. 2900 miles on that oil as well as  68 hours on that oil ( so used to equipment with an hour meter and that becomes valuable information to compare with others as well ). Once again the oil use was so very little, I am going to say it dropped under 1/16 of an inch on the dipstick. No towing was done and this interval was from early spring until now.    One interesting item to note is that going by the 5 quart jugs I was using before from Mobil, it was showing that I was putting in 8 US quarts to bring it to full if not slightly over the full mark according to their jug markings. Granted I did allow more drain time this time and in part because the engine oil was only lukewarm as I started it and let it idle and not for long enough to get the oil itself hot ( the engine was up to operating temp ). The oil in that state just seemed to take forever for it to drip out but not only at the drain plug but at the oil filter housing as well, perhaps I had never quite gotten all the oil out before and I could have still waited longer but as it was I waited well over 3 hours. I think next time if I have the time I will do an experiment by dropping the oil and lets say leave the pan under it for 15 minutes, then switch to another pail and let it drip out overnight and measure how much more oil comes out. So this time and yes I ended up getting it just over the full mark as I was experimenting with trying to get the level to the add mark after I had run it and then waited some and then added a bit and waited for a certain amount of time for it to settle to the add mark. I very well may not have waited long enough for that experiment but I got to the add mark, then dumped in a full quart and waited some and checked and then waited some more and it crept up more ... and then finally oops, it was slightly over full some hours later when it really had settled all it would. I find this engine sure takes time for the last bit of oil that gets poured in to finally make its way into the crank case. I can only guess at how much too much I added as per maybe a 1/10th of a quart. I had poured in 8.5 quarts going by the quart containers as per 8 quarts and 16 us ounces. I was shocked at how much this was off compared to the prior oil changes and if those larger jugs and they are not marked accurately enough or they contain slightly more than what they say, or the drain time factor made that much of a difference. But I know on this forum there have been others who have said they have put well over 8 quarts in their L8T and now I have also going by the Amsoil true quart containers. Its a confusing convoluted mess up here in Canada with some oil manufactures packaging is in true US quarts, some is also in true US quarts containers on an even number of quarts but also marked in liters which becomes the odd ball volume of a fractional amount of liters. Then there is the Liters only containers, no US markings as its a true metric container and only measured in Liters to an even number of Liters. But remember we used to have Imperial Gallons and Imperial quarts as well !.
    • Holy smokes. Clearly not a deal on that truck. I just mean in general, matte or painted trim is becoming more normative than chrome, but I know the Black Optics packages on various vehicles are being sold as uplevel trims. They look really good, but sheesh. It's just paint and plastic.
    • I Wouldn't Know Where to Begin    Oh I know where I would begin but I'm just one of over eight billion people on this rock. Eight billion versions of where the goal post is. How large it should be. How far to kick from. What ball is the right ball. Elevation. Age.....are you getting the point? It isn't about disagreeing with one individual. It's about agreeing only with one individual. One's self.   Agreement comes when multiple people hold the same point already. THAT is the goal of an education. Building the Social Contract. That thing that allows us to all read this sentence. We've agreed on the alphabet and how to arrange those letters into words we agree upon whose meanings hold true for everyone entering into that contract. Those words arranged into a sentence form an idea and several sentences strung together in a paragraph convey an argument for or against or inform the reader of a state, condition or perhaps reveal a things nature. Paint a word picture. Make oneself known.    This contract is not limited to words although they are often explained by words. Things like numbers and their usefulness. Physics, Chemistry, Medicine, Music, Art and so on.    The frequency of middle C (C4) is 261.63 Hz is a first principle. We build on that to make music we all can enjoy even if we all can not compose or play. You don't have to master it to make it enjoyable and useful.    So why is the Beginning so difficult? Why is agreement so elusive?   Everyone "Signs" the contract (when receiving that education in obtaining it)  but fewer and fewer in this world have any intention of living by that contract. They find exploiting that contract more advantageous. Disruption. With intent. Without intent. In Ignorance. In your face. With a double dog dare you. With a hold my beer. In resistance to that contract and in spite how it looks on us. It permeates the very air we breath.    In this way the contract is subject to advantage. Abide by it when it serves you, disregard it when it doesn't. Unpredictable and self-serving. Corrosive.....Toxic........   It says a lot about a persons character to disregard the contract, the truth, first principles. None of it good.        ********************************************************   https://medicine.yale.edu/news-article/character-vs-personality-who-we-are-and-who-we-aspire-to-be/   Just an interesting article.
    • It costs $5,250 for the Yukon Nightfall option (black wheels, emblems and illuminated black GMC grill badge). What a "deal".
    • I keep getting the above error message on my 25 Sierra.  If I reset the infotainment unit (via the phone hang up button) it will work again for a day or 2.   But I dont want to do have to reset  all the time. Works fine in my 2023 Corvette. On both vehicles I connect wirelessly.   I have a Google Pixel 10 Pro XL, phone is up to date.  Any Ideas.  See attached
