+1 on the K02s.
I'm using them as snow shoes that won't melt on my annual drive to Florida and provide traction through the Appalachians. And that lake effect snow that NY and PA gets!
The K02s are each over 10lbs heavier than the Continental LX20s and one can feel it. Very slight hum heard if one listens closely with the radio off. No flat spotting, even with recent -6°F weather. Haven't had the opportunity to run them in deep snow yet, and can't wait to do so!
As per the vibration / buffeting issue thread, I did have to work with my dealer to road force balance them to under GMs 15lbs spec for a buffeting free drive. Got them to 12lb, 10lb, 10lb and 8lb.
Sensitive to vibrations, these new trucks are!
How did you like the continental lx20's?? I will need new tires this spring and so far they look like candidates. Most of my use will be on road with dirt trails and light snow thrown in once every blue moon. The reviews i have read have been very positive.
IIRC the 265/70/17 come in at about $137.
I would not buy them again. The fact that my dealer had to replace 6 to eliminate the buffeting (see 'Yukon noise in cabin' thread) is the primary reason. In fact, I also have a post in that thread where I collected customer feedback from various sites - it's not very good on many different vehicles. I'll be replacing the Continentals with Michelin's first chance I get.
Since my last post here, I've had a chance to drive the KO2s in the snow. They're amazing! Excellent traction. I just finished a 1500 mile drive to Florida on them and got 18.2mpg averaging 69mph. At ~10lbs heavier per tire, there is a slight penalty over the Continentals.
Stock picture before I get the RC 2.5 leveling kit and 285/65r20s installed on Friday. Deciding if I want the step bars and valance off or not.
Edited by kgillean
Swapped my Cooper Discoverer AT3's for BFG AT KO2's a few months back. Best decision I made. The KO2 is better all around in every condition. Dry, wet, snow, etc.
Tires fit perfect. I will take some pictures and try to answer some of the measurement questions from above tomorrow.
any rubbing I was looking at this size and I also seen the 305/55/20 on stock wheels and looked good any pics of yours? Edited by Steeks
Sorry, been busy with work. There is minor rubbing on the liner inside the wheel well. Refer to page 7 of this thread for pictures of the area. It takes one zip tie on each side to tie it back to the frame. I will work on pictures tomorrow.
They aren't cheap though. I paid 430 a tire.
Also, here is another reference to them fitting:
http://www.gm-trucks.com/forums/topic/156030-has-anyone-tried-2856520s-under-a-leveled-2014-yet/page-2
Edited by kgillean
Hey guys I just got a new set of BFG AT KO2 275-60-20 on my 2014 Crew Cab. What do you think?
Truck looks awesome. I used this/your pic here to go get my tires; however, after I had them mounted and drove them a bit, in person I felt like they looked smaller than what you have. Luckily I was able to take them back and swap for the taller 275/65, and have been pleased since.
Just had 275/65/18's installed and love them. No life and not even close to rubbing full lock. Can't wait to get to try the off road
Ok will try this again. Just installed 275/65/18 KO2s on my 2016 Z71. Lots of clearance with no rubbing issues. Great ride and very minimal road noise at 70 mph or for that matter at any speed. Look great and will post pics when I get it cleaned up. Rained all day after install.
Got my truck Saturday. Swapped out the GY SRA's for Stock size KO2's.
Wow! It's amazing how much better that looks, even in the stock size! :thumbs:
    • Thanks to the convenience of Amazon, I was able to get a few things done to the truck today.  I installed Carquest Premium oil and air filters with five quarts of Mobil1 High Mileage 10-30 along with a quart of Pennzoil Platinum 5w-30 I already had.  The latch for the flip up center console lid was broken so I replaced it along with the power mirror switch.  I found my push retainer assortment this morning and reattached the plastic under the bumper and it was only held on with a few screws and retainers.  Then I programmed a new remote keyless entry fob so I can lock my dog in the truck when I take her out with me (I've got to keep the air going for her since it's been in the 100s).  Finally, I ordered some LED interior bulbs and replaced the reading lamps.  The front lights are working fine while one of the back lights only works intermittently and the other not at all.   While under the truck, I found the source of at least one of the noises: the sway bar links need replacing.  I ordered a set of Suspension Dudes links with Code Red bushings.  Never heard of them, but they're made in the USA and have decent reviews.  While making yet another Amazon order, I went ahead and added a set of front tow hooks.  I went with red, since that's the color of the sway bar link and bushings and it should look decent enough on a black and chrome truck.  Speaking of which, it doesn't bug me much, but the passenger side mirror has a chrome cap while the driver side doesn't, so eventually I'll make them match one way or another.  Oh, and I ordered a $20 TPMS reset tool.  No idea if it will do anything for my sensors but it was cheap and will work for the Ford Transit Connect as well.     For tradition's sake, I ordered a new oil change wrench.  I kept the Snap-On 9/16"x15mm GM wrench I bought when I was 18 in the 2006 GMC from the time I bought that truck until the truck was lost.  While I was tempted, there's no need to spend $80 for a new SO wrench, or even $50 with shipping for a used one on Ebay.  I just bought a Duratech 15mm extra-long ratcheting wrench to do the job as needed.  It works, and if I like that wrench enough, I'll buy the set.
