2014 Silverado Double Cab Z71
9" Mcgaughys
35x12.50 Toyos
22x12 American Force Blades
4.10 gears.
Hidden 42" light bar behind grill.
Led Cubes in Fogs
Hey I love the truck and especially the front end. What kind of grille is that and did it come colormatched?
Sent from my SM-G925V using Tapatalk
9" Mcgaughys
35x12.50 Toyos
4.10 gears.
Led Cubes in Fogs
who did your 4.10s and what are they, Yukons? Great looking truck!
New 2016 Summit White LTZ Z71.
Current Mods:
20% Tint
GM Black Bowties
Factory 22s w/Black Inserts
BakFlip G2 Bed Cover
LED Bed Lighting
Amp Research Power Steps
Z71 Side Emblems
Coming Soon:
GM Borla Exhaust
2" RC level
285/50/22 Nitto G2
Added the GM Borla Exhaust today. Great product. Great tone at startup and deep tone with acceleration but not too loud at cruising speeds. Sometimes you can't even hear it on the hwy. Exactly what I was looking for. Cold start sound clip below.
https://vimeo.com/172047927
I actually bought it from a guy on here. I don't know the brand.
I had 3.08s and my 35s destroyed my spider gears. So I upgraded. Yes it's Yukon gears and an Auburn locker.
You know there is a hook on your gas tank door so your gas cap doesnt have to hang on your fender.
I've never used that hook.. In 35k miles, not once used it.
nice job - I'll definitely need to do that...
I'm with ya, definitely on my to do list
2015 Silverado LTZ in Summit White. I've had it for about 3 weeks. Just blacked the bowties last night and plan on tinting the front windows soon!
What's everyone doing for floor mats?
Edited by H20fowler
9ed23d4a9d768117e8da71e018c160c5.jpgd91fabeab9a482b873e94ae40f7c4c72.jpgb416975610ef3e1fa6710c82dd6e4ae0.jpg
Stock, delivery day!
Here is after a few add-ons:
2015 2LZ. Summit White, ebony interior with Z71 badging (no wood grain!), RSE and Nav. Checked every box except 6.2... Buyers remorse on that, but MSRP was already $55K - rediculous-right?Intended to buy high country 3LZ, but my wife was thoroughly turned off on the saddle interior. Don't care for it much myself don't like the HC rims either!!! Got this guy as s year end deal so didn't have any 6.2's in the area with RSE which I wanted for trips with the offspring.
Added CK156 22" chrome wheels, Putco Locker Rails, Larado tonneau cover, GM splash guards, body color grille, 6,000k HID low beams and fogs (made a HUGE difference in lighting) and GM accessory step bars.
Plan to Diablo tune to wake this girl up a bit off the line (runs great at 3,000 rpm, but damn torque mngmt is neutering this rig off the line!
Also want to body color headlight bezels and both bumpers - love the mono white look.
Adding s supercharger isn't far out of the realm too, but that's a fat investment!
Great looking trucks all!
-Shawn
Sent from my iPhone 6s Plus using Tapatalk
2016 Sierra AT SLT, 275/65R20NittoG2, Amp Steps, CamLocker toolbox, RC 2.5
What's everyone doing for floor mats]
GM has some nice floor liners. Full coverage but more like a rubber than plastic as in a whether tech etc.
http://www.gm-trucks.com/forums/topic/184854-new-gmc-floor-mats-2016-these-are-real-nice/?hl=floor+mats
Edited by DAY11
My 2016 z71 4x4 with 4" BDS lift with fox coil overs and rears on custom factory wheels and 35" toyo rt's6d5366b6efc18b1e27b30544ef9eb1d3.jpg7c50b1976f779938251cc7f22062254a.jpg
What kind of MPGS?
