Thank you to the OP.
I did this 2 weeks ago in my truck and it made a huge difference, it even helped increase my mpg, haha.
i got rid of my slow throttle, google sprintbooster been using one for 2 years works as advertized
I have sprintbooster on my 2011 bmw x5 diesel and it works so good. On Red its like hair trigger, i keep it in green and off when wife drives it. She doesnt like the sensitive throttle lol
I miss driving that thing now that my truck is my daily, x5 is a beast and so much torque! (425ftlbs)
Thanks OP , after dropping two pieces of paint stick under the carpet I went in the shop and found a 1/4" aluminum puck from a hole saw. That was a little to thick but still managed to get it under the frame. Drove it right after and wow was that noticeable ! 19k of getting used to the flex really made it stand out haha.
Even after checking my pedal and not seeing any flex, I went ahead and added a piece of hard plastic underneath and I definitely saw a difference in throttle response. Anyone not seeing the flex, I recommend trying this fix anyway.
Has anyone upgraded their ignition coils? I saw a customer review from an Accel supercoil ignition pac(and wires) on a 2016 saying they noticed better throttle response.
I did this about 2 weeks ago and really didn't notice much difference just a bit but as I've been driving more I'm really liking the truck more.The take off nose dive is gone and I swear my mpg got better to,maybe it's relearning my drive habits.
Thanks OP[emoji106]
My gas peddle mount looks slighty different than yours, I have a plastic housing that runs outwards from that nut, and it is really hard for me to reach between where you stuffed the wood :(
2016
I was close to taking my new '17 in because it just didn't seem right off the line, to my surprise I went and looked at the pedal and she's a flexing. Fixing it tonight with a paint stick tonight, going to wrap it in black tape so it blends in.
Has anyone tried something like walnut, mahogany, or birch for a little class?
Oh, that's right; we've all graduated from that crap!
Stick it!
Well, I caught this thread and decided to take a looks see? Guess what? I am going to Lowes to buy some shit to fix my excessive pedal flex. Thanks to the OG poster on this one! So it looks easy to fix and the assembly itself looks decent too. It's just the cheap plastic bracket/holder that bolts onto the floor board/firewall etc.
The actual pedal assembly slides into the bracket and still way too much excessive side to side play even if it's affixed directly to the floor board properly? Oh, Well.. it's shit no doubt and nothing like the older vehicles at least I am not dealing with an ecoboost turbo problem.............
Did the "paint stick mod" this morning and the response is night and day different. Shimmed 2 paint stick widths in the plastic and no more issues at all.
We should name their thread " shimmin' the shakin' Silverado" lol..I do love my truck but if GM could just get off their ass and come up with a fix it would be near perfect.. Oh and new trans. tuning too. Am I asking too much here?
Sent from my E6810 using Tapatalk
I have adjustable pedals and it was joke with the play/flex. I removed the whole assembly down to the plastic mount that has bolts attached to it.
I placed 2qty 1/8" thick plastic washers 1.125" in diameter over the 3qty bolts and put pedal assembly back and tightened down. I then took a plastic shim like a wood shim yet plastic and cut it down. At this point I pried up plastic mount and squeezed caulk and shim behind.
Took truck for "Hot Lap" and this thing now has probably 100% better throttle response! The best and first MOD evey body should be doing! Thanks OP why didn't I open this thread 1yr ago?
    • Length/amount of data capture will be important to consider, sifting through 5 minutes of a data log can be enormous when it is stored in milliseconds. Being able to find the 'event' let alone decipher it.   Presumably the driver would notice something and hit a button to capture the 'window' of data. That window has to be large enough for the operator to recognize the event and react accordingly.    The data has to be able to be retrieved easily.   The data has to be able to be understood. Which is the biggest challenge, dealer techs won't even know what most of it is and would likely not even look at it if an owner brought it to them. Meaning the owner, the least educated/qualified, trying to understand it.    How will the data be presented? Could specific PIDs be selected and a timelapse graph be watched? How will a specific value be noted as abnormal? Additionally, a good data logger would be able to 'learn' normal values for a specific vehicle and flag abnormalities automatically. It could in theory watch parameters degrade over time and suggest maintenance as needed. (If the MAF reading begins tapering off for a given set of other readings - MAP, throttle position, Ambient, etc.. a flag to check air filter.) With the amount of data available, a device (really the vehicle rather than an additional accessory) should be able to do more than issue a DTC. It should be able to run the full diagnostic suite automatically and present a solution rather than a code. (It's not the 90's anymore). The technology is available for the vehicle to not just say "P0087", it should know low fuel pressure, check other PIDs to narrow down the problem itself, and determine if it is a lift pump, high pressure pump, regulator, leak in the fuel line, clogged filter, etc. Even if it can't narrow it down, it should be able to guide the user to the likely problems.   This would be a major problem for dealer service departments, which are the manufacturers customers it is in their collective best interest to NOT have this available to the consumer.   Further, if the owner is going to be the primary consumer of the data, it's got to be at a consumer price point vs. dealer only specialty tool price.   This group is more 'involved' in their vehicle than general public/consumer and will have knowledge, experience, needs and desires that are quite different from the market at large.
    • I put the prof up. If you read what I posted. You can see that housing, cars and income are in line with the era we were talking about. It’s harder in some places easier in others. Let’s agree to disagree and put this back on track, OK? We both are pretty stubborn and hard headed. But I bring receipts. If you wish I will not respond to you in the future.
    • Lets see if I can sum up two pages of nothing useful.    You want to refute your own governments data of the "Purchasing Power" Index FOR THE ENTIRE USA and its territories replacing it with the experience of a single family and its business and label that reality?  Then pound on that for a week hoping it will find traction?    Stan, I've told you several times. I don't do irrational. There are more people in the USA than your family.    I'm pretty sure this tread is so blown up. I'll give you a few days or months if need be to post yourself silent then I'll see if I can find enough parts of the train to reassemble it.
    • Facebook groups hate VSE, poor customer service; their responses to criticisms are pretty poor for a reputable company. I'm not a customer, haven't bought anything from them, but how they handle themselves on social media is a definite "No" for me.
    • $10,000 for a transmission?   Pretty sure I could buy all the parts, tools, and education to rebuild it myself for a quarter of that amount.   or swap it out with a new one...
