Was the steering wheel hard to remove?
Not hard at all. Air bag was a bit tricky until I got the knack of it. I used my phone camera on selfie setting so I could see what I was doing from behind the wheel.
I have my wheel and clock spring. Just so I understand... the clock spring will have a connector that plugs into a loom under the dash by the BCM?
Yes. The plug is already there taped to the harness. If you remove the kick panel under the steering column it's straight in front of you.
3B917BFE-8C9B-4B5F-B458-9432AD8859F5_zps
AE8542E4-6386-4F34-A013-684B5E14FA9B_zps
4BC1D148-9BE9-4437-8637-72B07A0D8B19_zps
5F5D30D8-8558-42A0-8561-3CBDACA7240A_zps
Thanks to all that have contributed to this thread. The photos and descriptions helped tremendously.
I did the swap today and all is well. I have a 2016 LT, CCSB truck and swap was pretty straight forward. Took about 1.5 hours. Probably would have taken an hour had I not reinstalled the same wheel.
Removing the airbag wasn't as hard as I thought once I found the square hole. LOL. I used the front facing camera of my iPhone to guide me. The flat head to pry it off goes toward to the top of the square hole and you pry the pin downward (so screwdriver upwards). Once the airbag was off, I worked on wheel removal. This uses spark plug socket. Wheel took a little muscle to pull off so make sure you disconnect the connector to the clock spring.
The retaining clip to remove the clock spring was a PITA.
Running the harnesses down to their location was a breeze.
This bar is what you are prying on to remove.
Retainer clip holding the clock spring in.
Edited by pgamboa
  • Like 4
Yep. Once you get that booger retainer clip off, it slides right out. You have to make sure harness zip tie is cut off and disconnected down below so you have slack to pull the clock spring out.
Still trying it figure out how to reinstall the upper/lower column plastic shroud thing. Just isn't lining up.
Any tips on reinstalling the upper/lower shroud would be great. LOL. Thing just isn't lining up.
Anyone who has installed a heated wheel, does it only heat up on the upper portion only? Also doesn't seem very warm.
Reading this thread may allow me to buy a lower level truck and not have to spend so much on a Lutz model or Slit. I can have my cloth seats and heated wheel and like it!
I did the same swap and after plugging in it wouldn't work. Did you have to do any programming?
I did not have to reprogram anything. All worked fine as is.
Took a bit of finagling but mine just popped back together.
My whole wheel gets warm. Not hot like my previous vehicle did tho ( 2008 Pathfinder)
No programming required. Just make sure you have the (2) Connections for the clockspring below like in the the photos.
Do you think it was worth the money and effort for this? I know you said yours just got a little warm and not hot.
It's weird. When I first installed it, only the upper half came on. Eventually, the bottom half got warm. Overall, im happy with it. Seems like it gets warm, stops, then gets warm again.
Trying to locate a clock spring, the number posted on this thread doesn't seem to match my truck. 2014 GMC Sierra 1500 SLE the part #I come up with is 23193462 ; 22989630 anyone else able to confirm this?
Cheers
    • Starting at 17 running parts for my father’s construction business to haul our equipment. Eventually doing shows, sales and training after purchase. I drove a minimum of 50K miles a year. Half hauling something. After retiring 30K miles a year to the last 2 years 15K miles a year. 2/3rds highway driving. The major contribution to fatigue for me is from anticipation and awareness. I just don’t relax. Too many idiots on the road. There’s two kinds. The group that never leave the left lane tied together afraid to let anyone in doing 80. They’re mostly on weekends. Then the left lane sleepers usually next to a tractor trailer not advancing. Eventually the tractor trailer will drift over the sleeper will wake up. The train moves and the tailgaters who are usually mad as hell. You definitely don’t want to mix with them. The tail wagging bumper puller’s with under powered trucks are holding the tractor trailer up. That bunch are dangerous. I usually pace ahead all that. Unless there’s a gap when I can chill and let the speeders pass. I tried all different types of driving. I stay to the right except to pass, it’s the law that’s getting in forced more now because of road rage. I was so happy when my wife didn’t want to do the camping life. I had enough of pulling for work. The family has a bus and fifth wheel. I haven’t driven either one since retiring. No thanks.
    • Yesterday a suggested youtube video thumbnail caught my attention so I watched through it and it was a bunch of short clips someone gathered together of people pulling trailers, a lot of them were bumper pull holiday trailers and a pickup or suv pulling it. a few fifth wheels as well, some motorhome crashes also. The tail wagging the dog theme was quite evident in numerous self inflicted accidents that took out vehicles around them sometimes in the process as the unit finally swung around and flipped over in the middle of the highway. Or the other classic which literally could be called "I forgot the trailer was back there" in passing another vehicle on a multi lane one way freeway and then cutting back in line before the back of the rv trailer had passed the front of the passed vehicle and often in front of a tractor trailer and that never ended well. Or the wide kick out swing of the rear of a long travel trailer as they have so much overhang behind the axles and the trailer smashes into the side of vehicles in the next lane over ( typically sharp turns in city driving ). It makes one leery for good reason to be near an RV trailer after watching a video like that and be it on the highway, in town, or at a gas station where that rear end comes swinging around due to the fuel station being so cramped and not intended for larger trailers. I wonder how many officers have heard those words though "I forgot it was back there" as they investigate the accident LOL.
    • $5.10 for regular at the Kroger   It's been 6 months... is this the "new normal" ?
    • Just because a person can buy a travel trailer or a motorhome doesn't mean they can drive it properly. My observation during my RVing years.
    • The cure for facism. https://imgur.com/gallery/cure-fascism-9DH3bHs
