That's the problem with VIN based ordering.  I had a similar issue when I ordered my parts.  However, I declined to give them my VIN and they actually held the order to verify it.  I informed them that I knew those where the parts I wanted and to release the order.  I suppose this is a useful back check if you're not trying to change something, but it's annoying if you are.
I used a different site, GMpartsnow.com, but it looks like they use the same system.  I would guess the heated wheel clock spring is cheaper because they are a higher volume item.  I doubt they sell many nonheated units.  I can't verify your wheel part number because mine was different, black with red stitching.
I suggest you call the folks you ordered from and explain what you're doing and let them help you verify you part numbers.
I usually order from GMPartsDirect.com and have never had to enter a VIN.  I ordered these steering components from CheapestGMParts.com, and VIN was optional, so I entered it, and the sales department just wanted to verify that I wanted these parts since they don't "match" my VIN. I confirmed I wanted what I originally ordered and they have now processed it.
Makes sense on the volume vs. price thing with the clock springs.
When I place my orders with these online sites (and I place many - lol)... I think when they see my orders, they probably say “eh, it’s Phil. I wonder what he’s up to now. No VIN - Release the order”. LOL.
Apparently the 1500 trucks have 2 plugs for the airbag and the 2500/3500s have just 1 plug and are different clock springs. I see looking up part numbers there is a different part number for the steering wheel for the 1500 vs 2500/3500 for the same color/options (Silverado black w/heat w/o crash 1500= 84222909 / 2500= 84222916). Would that be because of different airbag? Would think the wheel itself would be same and just different bag and clock spring but want to make sure I get the correct one for my 2500 when looking on ebay for used wheels if the 1500 would work or not. Maybe the 1500 wheel has the space provisions for the 2 plugs?
Yes.  The 1500 vs 2500 airbags have been different  with the 1 plug 2500 and 2 plug 1500 since at least 03.
Stick with the same platform that your truck has.  The airbag system is nothing that I would risk trying a different part to see if it fits.
On 1/28/2018 at 8:17 PM, pgamboa said:
Here is a How-To Video on this.  Tinkering Fox did really well with this how-to.
Thank you, made the install a breeze.
I wish I had this video before I did my install. It would've saved me some issues with removing and running the cables as well as removing the lower panel.
I had no idea the tilt lever pulled off like that.
I have the 2017 base Sierra  w/ elevation pkg so steering wheel is non leather and only have cruise controls.  Really miss the leather wheel so I’m curious if there is a higher trim level that has the leather with only cruise controls?  Is it possible to easily swap them to get the leather?
On 4/5/2017 at 2:48 PM, Justin101714 said:
Okay, I decided to install the harness at least and check for power and ground. Got it all set up, running factory with the factory fuse. I have power and ground at the small 2 pin connector just like it's supposed to. All I have to do now is install my airbag coil and steering wheel and I'll be good to go! emoji1417.png
Two clips hold the fuse panel in, you have to hold them down and pull the panel outward.
There are 4 clips surrounding the connector. You'll have to undo the clips and move the CPA downward about 1/8 inch. It stops by itself to another set of stops, DO NOT go past those stops.
I chose to install thicker gauge wire because it's a battery positive circuit.
The X203 connector above the BCM.
So on the X51L the blue face of that block slides down a bit to allow insertion, correct?
How is a terminal inserted into the X203?
On 12/23/2014 at 6:22 AM, Doobs41378 said:
I have one, never use it as it gets too hot for my liking. I would not opt for it in the future.
I do use mine, but not for long because like you said, It gets toasty. Might be meant for intermittent use only?
The blue lock slides upward towards the connector face. You only need to move it to the first stop position. X203 just pushes straight in. Look at the orientation of the existing terminals to get a good idea
Thank you. On both locations, I assume that connectors can only be inserted one way?
In most cases, yes. Can only be inserted one way. When you see a terminal that has tangs on both sides, they can be inserted either way. When you see a tang on one side, that usually means it can be inserted only one way.
I haven't looked yet, but I assume that X203 block disconnects (unplugs) before you try to push that wire into an empty terminal location?
I’ve never seen just leather with cruise. The LT and above have leather with radio controls/cruise.
    DaleB
    DaleB
  • Who's Online   2 Members, 0 Anonymous, 1,290 Guests (See full list)
    • Common Sense Assembly   Your driveline is forgiving of the occasional mistake. It will even often forgive the random serious blunder. But it will not forgive a continuous bad habit.      What? Not everything needs to be a five thousand word essay.
    • We drove about 15 minute east today to visit a friend and saw a steep increase in price in the same county. About 50 cents a gallon steepper.
    • Sure about that? A degree wheel and a dial indicator would lower your degree of assurance in that statement. 😉    It why we have offset keys and dialable timing sprockets. Just say'n.... I've built a few and have never seen one "On the money".
    • I will admit I haven't experimented much with pressure drops beyond the numbers I put in and part of that is that the numbers I used are fairly low and then found out it would trigger regardless at that 35 psi. Having said that I had tried before had changed the placard pressures and being that I have a 1 ton set to 80 on the placard for the rear I believe it triggered close to 60, the front I don't recall now for sure but thought maybe it could get close to 45 from that factory 60 placard pressure. So I never did figure out if it was a number of psi from placard pressure to the alarm or a percentage of the total placard number as some figured it was like a 25% drop from placard pressure would trigger it. So as to try and answer your question, I believe I set the placard pressure on the front to 47 or so and while I run the front tires at 40, they have dipped below that some if its colder and I haven't put "winter air" in yet and never once have had the front alarm go off. I would say that the answer your looking for is no, that if you set your placard pressure to 45, you have a certain amount of room to drop below that pressure before the alarm will go off.    The pressures you decide to run in your truck, that ends up being what makes sense to you based on what your carrying in your truck or if towing, then have to bump them back up to something that will carry the load in the rear and the fronts typically left at the same pressure. It all comes down to that chart I put the link to and using an accurate roadside scale to be your guide, both unloaded and then loaded to know your minimum safe pressures.    I just wish GM would allow a person to change the readings for the tire pressures to the English system of pounds as I have to look at that goofy metric reading that will never ever jive in my head and will go over and change it just to figure out what they are if need be and then change it back.
    • That part I understand, that the dealer can do it. But I'm not understanding why updates that were available to the truck since it left the factory, or the dealership originally, would not still be available to it without dealer intervention.   I'm thinking along the lines of recalls. They stay available until they are completed, regardless of whether they are in warranty or not, or in the hands of the original owner or not. Why not updates as well, especially since some of those can be safety related also?
