Leveled with 305/50R20's
I run a leveling kit and a 3" body lift.
No problem getting 35" duratracks under it with no rubbing at al
Any more pics of the body lift I doesn't look bad at least from the pic any chance u get can pics of your gaps
Ps looks awesome
  • Replies 52
Front end leveled, 305/50r20 Nitto Trail Grapplers, Rockstar II 20x9 -12 offset
I really like the look of your truck. What level kit and what body lift are you using?
Sent from my SAMSUNG-SM-N910A using Tapatalk
It's a Performance acessories 3" body kit with the added gap guards
The leveling kit is just a cheap 2" aluminum spacer bought off Ebay that mounts on top of the strut
Here's mine with 305/50/20 Terra grapplers. I just have a 2" level though. There really not any taller than a 275/55/20 but the added width definitely improves the stance. Speedos still accurate too.
Langston,
How did you like the 305-50-20 setup with 0 offset? I would like to go with a more positive offset but the wheels I like only come in 0. I am thinking of going with a 0 offset, 295-55-20 or the 305-55-20xl Terra Grappler G2. Curious as to how far the wheels stuck out and if it rubbed?
I see that you changed your setup to 17" wheels which looks great. I am torn, as I am thinking of going with 18" Method's or the 20" lrgs. Which setup do you prefer overall after having both?
Thanks in advance!
  • 3 months later...
Thanks man. They stuck out about an inch. Wheels were actually Gear Alloy 726mb 20x9 with a 0 offset. I have since switched to some 17x8.5 +0 Method Racing NV305s on 285/70 Duratracs.
Hey do you think a 285/75/17 toyo open country mt would fit on the same set up you have? They claim it's a 34x11.5 I've got a 2 inch level and just ordered a zone 1.5 body lift.
Looks great! Any rubbing? What size level did u end up going with?
It should work if your offset is close to 0. I still had some room with these.
Perfect! I looked up my wheels, and according to their website, the 17x8.5 only comes in a 0 offset. Thanks!
  • 3 weeks later...
Any chance you could post some more pictures of your truck? Direct side on and rear would be awesome. I am contemplating this set-up. Thanks
  • 4 months later...
Do you have more pictures of your truck? Looks awesome!
305/50/20 with 20x9 +1 offset and 2.5 RC.
I went with this size because I wanted NO chance of rubbing and an accurate speedo. I think when comes time to replace them I might go with 295/55 so I get a bit taller or maybe 305/55 as I believe that MIGHT fit without having to trim. Overall I am very happy with the setup.
12898195_10101061154719576_3960643308796
12301735_10100974358744406_5930562015513
2016 tungsten metallic z71
2.5" rough country level
295/55r20 toyo at2
20x10 -24 offset moto metals
