vled LMZ led headlights
junkyardz
mike- Thanks for the info about the narrow beam pattern. the only reason i wanted to try it was bc my high beams don't put as much light down on the road as i would like. they shoot pretty high, but i think that may be bc of my lift. my low beams are fantastic though. especially with the rigid fogs. is there a way to adjust the headlight down??
I read somewhere on a thread that there are some screws that allow for some up/down adjustments; I can't remember if it was on silvys or sierras or both though. I'm sure someone can chime in on this.
According to this post, you can adjust left/right a little as well:
I did some playing around this evening. I have always felt that if this lamp assembly had a wide adjustment, the only major complaint we would have is the poor reach-out-and-touch ability while the light is on "high beam."
In my case, when on my rural two lane road, with its shoulder on each side, I had hardly any illumination of the oncoming lane (left lane) and its left shoulder. When turning onto a road on the left side--no street light--I turn into absolute darkness. You city boys just don't understand. It is as if you close your eyes.
We need a wide/lateral adjustment.
There is one! Well, settle down.... The mounting tabs have a bit of wiggle room. All you do is loosen the bolt going through the tab, and play around. There is about 1/4" of adjustment. Below is an image from the manual of the BACK side of the $800.00 lamp (!!!!) assembly. Loosen the PIVOT and the WIDE bolts. Just loosen.... Remember, this is an $800.00 lamp assembly. Be careful of cheap plastic designs.
The WIDE BOLT, move the assembly via a slight tug toward the front of the car. You are pulling. It will come at you about a 1/4". Tighten the WIDE bolt, tighten the PIVOT bolt.
I wish I had before and after photos, but I don't. However, let me tell you what I now have. There is an apparent improvement. Instead of a dark left/oncoming lane, it is now illuminated and the left shoulder is now somewhat illuminated. Before I did this, only the lane I was in and the shoulder to right was illuminated, as if I had a burned out drivers side bulb.
My left road that I turn into, into total darkness, is now illuminated just enough that I can see it and comfortably enter the road. There is now enough spillage across all the driving lanes. I now have at least what I call a minimal wide.
-Skeet
  • Replies 383
-Skeet
Adjustment up and down is controlled by a screw on the top of the headlight. Pop the hood and look at the top of the headlight. You'll see a plastic screw (can use a Philips screwdriver or Alan key. No need to remove any parts. Just pop the hood and you can see the screw through the cover that spans across both headlights.
Keep in mind you want to set the height based upon the cutoff of your low beams. After that the high beams will go where they go and there's not much you can do about it. If I remember correctly the SAE spec for lights at our height is the cuttoff being 2" lower than the height of the center of the projector at 25 feet.
Yeah my 6000k are pretty much pure white. Maybe a slight hint of blue but not much.
I'm needing some help with adjusting the lights. I screwed the collar all the way to the back then unscrewed it about 3.5 times. The driver side flare pattern flares up on the outside so I guess that not perfectly horizontal. But this is what I got. Notice the two dots above the cutoff, how is that corrected?
Were you able to reduce the flare on the driver's side? Mine do this somewhat on both sides, but not that bad. You can see your drivers side is much worse than the passenger's. You may try clocking it a little bit left or right and if that doesn't work you could flip it 180 and see if that helps. I don't think some degree of this is an issue as it's far enough to the side it isn't going to bother oncoming traffic or anything, but yours does look a bit excessive.
It's funny you mention the two dots. I had forgotten about those! IIRC some adjustments to the bulb would reduce/eliminate them but not without screwing up the beam pattern. I decided the beam pattern was most important and those dots are just a side effect of having a larger light source than the projectors are designed for.
They are dim and shine up into the sky so you don't notice them in the real world at all. Like I said, until I saw your pic I had completely forgotten about them!
i never notice the dots anymore so im not too worried about them. i may try flipping the light to see if that flare goes away. luckily its on the driver side where its much easier to access! The lights are great the way they are but i was just looking to fine tune them to get them perfect. The flare doesn't cause any problems with the way that the light is distributed in my opinion. So glad we found these lmz's though! couldn't be happier with them! And also thanks to you! for making the covers happen! :thumbs:
Big props to Jon A for making the covers, without him this would not have been an easy mod.
I've got a slight flare on my driver side too almost identical to yours Sawyer. Until the weather lets up, mine are staying as is.
-Skeet
My VLED LMZ setup arrived as well as a set of Jon A's headlight caps!
Temps are dropping to single digits and below, so these will have to wait to be installed... damn!
So it sounds like the 5000k are the best match to the DRL's. Will they also match Rigid D2's?
Just to be clear, we should be ordering a set of 9006's for our Sierras?
9006 collar ---> yes
5000K match LED DRLs? ---> yes
5000K match D2's ---> no
I had D2's in my fogs recently and they didn't match the DRLs. So sadly you'll have to pick and choose which one you want your LMZs to match with. I don't think 6000K will get you any better of a match to the D2's (I could be wrong though so no one quote me on this! Well, you can quote this post, just don't go around saying "well Mike said ______" haha) but here's a comparison of the 5000K LMZs to the rigid DOTs. It's the most accurate picture I've been able to take so far but it's still not 110% accurate. The DOT pods are more of a pure white with a slight slight blue hue to it whereas the 5000K LMZs are a natural white
Direct comparison:
E42ED073-30C1-46C8-9C89-0FCF7A763191_zps
Output comparison:
268A08DF-77FB-4F8D-B9DE-D58A8D59721B_zps
Thanks for the reply. I have the JW Speaker LED high/lows in my Peterbilt and using a set of D2's for driving lights, they seem to match perfectly. I prefer a pure white but the little bit of blue that these have doesn't bother me.
Maybe the 5000's are the way to go, as long as they aren't a soft/yellowish white like I would expect from a 4000k.
I received them Thursday but couldn't decide if I wanted to install without the extended bulb cover from Jon A (printer not working).
Yesterday, I went ahead and installed them, following Jon A & Mikes instructions for bulb orientation and I was blown away!! Definitely an upgrade from halogens and comparable to HIDs. The bulbs low beams are amazing but they lack a bit in distance with the highs. This is my opinion when comparing them to my g37's oem HIDs which I know has a better projector.
Overall, I am extremely satisfied with the results. It just sucks that we have to pay for something that should already be in our vehicles when they leave the factory.
Almost a perfect match with my Vleds fog lights and DRL!!
Direct comparison:
Output comparison:
Is rigid using Epistar LEDs now? That color is very similar to an epistar led bar I have.
Looks like the Vled LMZ are the way to go with the Sierra headlights. Which 5000k variant should be considered? Their sit lists a 45w and a 25w version.
Haven't noticed the 25w, we are all running 45w.
-Skeet
I'm sure the 25w would work but they're only 3000 lumens. Go with the 45w
    Sothpaw27
    Sothpaw27
  • Who's Online   2 Members, 0 Anonymous, 472 Guests (See full list)
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
