vled LMZ led headlights
junkyardz
Has anyone used 3M gortex patches that TRS sells? I bought some to use on my modified caps and maybe the housing somewhere to hopefully let it breathe.
8101B480-7834-4628-B1A6-D0394A04B5E9_zps
I've never seen them, I'll have to look up how they work or whatever. I've got about 10 layers of gorilla tape over the hole in the cap for a temp fix until I could figure out a solid way to seal them as well as figure out mounting the ballasts (inside the cap or outside). Those may be exactly what I need!
-Skeet
  • Replies 383
I don't have them on me, but I think they are about a 1/2" hole that you drill to place them on. I was planning on modifying my factory covers with PVC caps and plastiwelding them in. I planned to put 2 of those patches on the new cap and then one somewhere else on the housing. I do plan to stuff everything inside the housing... ballast, wiring, and all. Hopefully it will allow some of the heat to vent and also hopefully keep them from fogging up from the inside.
Here is the link to the ones I bought.
http://www.theretrofitsource.com/accessories/goretex-patches-49881.html#.VQmt247F98E
Those look similar to what a set of recon led tail lights I used to own had on them. I never could figure out what the material in the holes were, just knew they were there to help vent the housings. I may dive in on some of these to give them a shot.
-Skeet
I think that is also used on stock fog housings, there is a smaller one in the back of them if you pop them off to see.
Just loke leather or skin, water particles can go out but not go in.
Since they let it breathe, it'll also allow heat to escape? I wonder how much the housing will be able to breath and release heat! It could help to remove heat so cooler air can get to the fan and therefore cool the LMZ more efficiently!
Btw, to your question about the best orientation and depth, I didn't find any particular depth to be more beneficial than another. Despite depth it seemed about the same but I found that putting the LEDs shooting side to side, gave the best overall light dispersal.
I'm looking forward to seeing how you think the HIDs compare to the LMZs in the FXR.
Edit: can cooler air be let in by these things Let cooler air flow in? Or just let hot air out?
Here's a few in the light. I realized how much of a pain this was going to be when I got into it. I have an extra FXR, so I just used that instead of going through all the BS to get the LMZ in and out. So, i'm just going to wait to put them in until Monday when the truck goes to the body shop.
I'm just waiting for dark to get some more pictures. The ones I took were with my iPhone, so the color temp is a little off. They are really close to the 4500k HIDs. I thought they would be a little whiter.
The bulbs were very tight going into the FXR housing, It's not really bad, just a really tight fit.
77E236C7-15DE-4F18-A391-AB0FCDDF45CF_zps
B79F9722-49BD-4CD5-BDCC-A12C136A874A_zps
F159BF21-8CC5-424D-911D-70251E2EFB98_zps
This is with the LMZ as far in as it goes, and the LEDs sitting side to side.
79E1FAFB-1354-4DB5-A313-3B6542932C28_zps
This is the LMZ with the collar screwed on 2.5 times, sitting side to side. Found this to have the best output.
CEEC77A2-FFBC-48E7-BC13-D0B1CC08E6B4_zps
This is my HID. XB35 4500k
56C45E09-7956-4DED-975B-D3E43AFBB3DF_zps
All these were of just a single light.
I do think the HIDs may have a slight advantage in brightness but I believe the LEDs spread the light better and are a little cleaner. It's kind of hard to tell in the pics, but the comparison is much closer in person. I'm hoping when I get my headlight update done, they will brighten up a little more.
It also looks like the HIDs had a bit more distance? Or were you using the extra FXR so the cut off was at different heights?
If the LMZs are this close to a 35W HID, then I very well could end up using the 50W HIDs I got originally for my FXRs. Although, I would really like to stay with a LED bulb [emoji19]
Led is a terrible choice for a projector
I actually agree with that after seeing the output. My VLED fogs are working better than stock halogen bulbs in the factory reflectors.
Projectors catches light from every direction like HIDs and Halogens would, LEDs are too directional. Lots of power wastes.
I tried to keep the cut off in the same spot, but yes i was using the spare FXR. Like I said, I think the HID his a slight advantage in distance, but the LED spreads the light a lot better.
The headlight update should brighten these up even more, correct? 11-30v are the specs on the LMZ ballast, so it should be brighter with more voltage? Or I'm I way off?
I'm going to get the headlights back out tonight, I was going to put an LED in one of the housings and see how it looked, also so I can see what brights look like. If you look at the cut off between the LED and HID, the HID seems brighter there but when I turn my brights on, they don't seem to have much light above the cut off with the shutter open. I'm curious to know if the LED will have good distance????
I will mess with them tonight and post back. I will get my d3200 out and take some pics, hopefully it will show the light a little better.
Doesnt matter what input voltage is, as long as within 11-30 is what the ballast can tolerate. They still output the same power to the actual bulb. Ballasts are more like power regulators. This is the same like HID ballasts.
So when I get the BCM flashed and new bulbs, when I swap the Volsa's out with these again, they won't change at all? Damn! I know at some point I'll retro some sort of assembly with hid, trucks still too new for me to really wanna cut them open right now lol. These are a great improvement for plug-n-play and reliability (so far).
-Skeet
    btm
    btm
  • Who's Online   1 Member, 0 Anonymous, 1,659 Guests (See full list)
    • Can ask that about a lot of places.   Holiday sells 91 for $1 over 87 octane. BP 93 is 80 cents. Amoco 93 is 80 cents Kwik Trips is $1.20 for 92 or whatever they have and $1 for the 91.   I know that this is not exactly same as what you are saying with the premium to premium debate of those two stations but why is there such a difference. Top Tier this and that, it's all BS. All the fuel comes from the same damn refinery, so give me a break.
    • Why does Mobil Premium cost 90 cents a gallon more than Shell Premium when their regular offerings are but pennies apart?
    • Was all the way down to $3.69 a gallon but then jumped back to $3.99 just because for some reason.   Diesel floats between $4.80's to $5.10ish a gallon. I even saw Diesel #1 for $6.09 today but nobody in there right mind even buys that in the summer.
    • Mine just keeps lagging or getting stuck on the reverse camera. When I turn off the truck, get out, and close the door it will still stay on. It’s very intermittent and I would not be able to duplicate the issue.
    • I was checking out fuel prices at my farm fuel retailer at their pumps and yes the farm price is a bit lower than the non dyed fuel and was glad to see that the regular farm gas price has dropped a lot from what it had been but what blew me away was the price of diesel as the spread now compared to before the prices went up earlier in the year, diesel was actually slightly lower than gas which was a switch from the theme the last number of years. However that sure isn't the theme lately and definitely not right now. The prices I will post are not from that retailer but just looking at gasbuddy for the main city in this area and instead of posting the lowest price someone found I will list the higher price ( and that may not be the highest price, just whatever someone posted on gasbuddy ).   So regular gas and there are a lot of stations listing the same price for regular is 1.68 a liter, premium 2.00 a liter. Diesel 2.03 a liter for a top price I saw on diesel.   Figures out to 6.36 a us gallon Canadian funds for regular and 7.68 for diesel. With the US exchange rate it would be 4.58 us for regular and 5.53 for diesel.    Thought I would figure that out to get a picture of what it settles out like compared to various US prices and its about the same as the current price in Fairbanks AK as Anchorage tends to be lower. So yes, these would be the prices and higher along the way on the Alaska highway where they know they have a captured market !, for fuel prices for those beginning the long drive back to the lower 48   The problem is our Canadian dollar and going to the states that have the high prices, boy do we pay then !
