vled LMZ led headlights
junkyardz
I swapped bulbs, and since the old drivers side bulb lit up in the passenger side, I knew it was the bulb, not the ballast.
  • Replies 383
I use a particular brand of led headlights that has everything built into the bulb itself. Plug n play, and cheaper
How much is cheaper? I see your bulbs posted in the led head/fog thread were 3000 lumens each vs 4500 these have. Kind of like the design of those bulbs you posted though! I am thinking about getting a set of yours for my fogs.
-Skeet
I retail my bulbs for $85.99 a set for most bulb sizes
I saved your facebook page, probably be giving you a call during regular business hours!!
-Skeet
I'm ended up trying out the JDM Astar H11s 4th gen from a few post back. They're actually rated at 2000 lumens ea so plenty bright enough as a low beam. I did have to grind the big tab down a little in order to get the bulb oriented horizontally. I've had them for about 2 weeks now and so far I'm actually pretty impressed with them for $80. Everything fits under the stock cap as well. This is the only pic I have with them. Kinda tough to get one that really shows the color they put out. They're probably pretty close to 5000k hid with just a hint of blue.
What kind of cutoff or glare do you get in these with stock halogen housings?
It's definitely not as clean as a halogen but I haven't been flashed at all and I've driven several times at night.
Just wanted to say that I am very happy with VLEDS and their customer service. They had a replacement bulb out to me in a matter of day after following their easy warranty claim
has anyone installed these LED 9012 replacements with the copper mesh as the heat sync rather than the cooling fans? Wondering if these will all fit inside the stock dust cap or would I be better off buying the extended versions I saw on here somewhere?post-139159-0-99723800-1428004153.jpgpost-139159-0-46890800-1428004142_thumb.jpg
has anyone installed these LED 9012 replacements with the copper mesh as the heat sync rather than the cooling fans? Wondering if these will all fit inside the stock dust cap or would I be better off buying the extended versions I saw on here somewhere?attachicon.gif9012-LED-HL-3S.jpgattachicon.gif9012-LED-HL-2.jpg
I honestly think they are really bad design, non aluminum housing already reduced the heat dissipation rate, and it is "heat sink" not "heat sync" lol. The heat sink design does not look adequate, even the LMZ heat sink without fan will out perform those feather design.
The black housing will absorb some light output too, not much, but not the most efficient way designing something.
Aluminum housing is probably the best so far, it dissipates heat and also reflects the scattered light back to the headlight housing.
I installed my replacement bulb only to have the passenger side go out now!! It goes on, but the leds at the tip are not lighting up
Looks fine to me :D JK
Your offset looks almost too far back though, you should use a caliper and compare the offset from the o-ring to the filament from the original bulb to the LMZ's, exactly what I have done, perfect beam pattern!
I'm going to do that since I have to take them out again anyway.
this may give you a better clarity on what I meant
http://www.gm-trucks.com/forums/topic/157013-what-have-you-done-to-your-k2-today/page-191?do=findComment&comment=1591128
I have also noticed all the aftermarket LED bulbs' o-ring "ring" that they sit in is shallow, so it is why they are harder to stay in the socket.
Awesome, thanks for the info
  • 4 weeks later...
    • Hey thanks yall for the info. It apparently was the key fob - the "reserve" key fob works just fine. Yall were all over it. Great input! JRD
    • I just bought one of these.   https://www.topdon.us/collections/diagnostic-tools/products/artidiag-pro   Yeah, it`s got a cable. $250/year after 2 years. Do I want more? Yep. But, I`m not working any more and can`t afford a whirlpool in my tool box.
    • Why don't I have a good scanner? I've always wanted one when I've needed one.   My latest reading says I don't need to do a relearn on the ckp sensor on a 1995 with OBD 1.5. The relearn is prescribed for the later-model 1995's which shipped with actual OBD II when GM completed the transition in prep for the 1996 MY. I need to confirm that. Did you know forums are disappearing? Knuckleheads on Facebook... it's not the same. It's just not.   So, scanners. Again, shooting myself in the foot for having eBayed my Snap On MT2500 "brick" with all the adapters. Not that I couldn't buy another but those are getting quite old, and mine wasn't new enough to work on 2000's vehicles.   Damn it (as I'm scanning my email between paragraphs here). Did you know there's a 2000 Jimmy 2-door on BaT that's ending this morning? It's local. I want it. 14k miles. Absolutely beautiful.   Back to scanners. MT2500's are old. Solus, now that could be a contender. There's a ~2008 Verus with a system error that's basically new in box for cheap. Hmm...I'm not sure about a scanner that runs an archaic version of windows (95 or CE, I can't tell).   I want the ability to reset and rotate TPMS, test individual modules, bleed ABS, electronic parking brake controls for servicing brakes, relearn procedures and other bidirectional controls.   Snap On does an MT2600. It's a new model as of last year, marketed as their "entry" scanner. Entry? Only where $1900 gets you through the doorway plus, I'm guessing, $1000/year if you wish to keep it current. So goes scan tools actually designed for production environments. Want decent products with excellent support, you pay for it.   Everyone is raving about Autels and TopDons and Foxconns and all these newer brands that are selling the $500 "prosumer" scanners for backyard hacks like me. They're tempting...honestly. Updates are cheaper, base prices are remarkably cheaper... And you get to deal with bugs and translation whoopsies and, well, just don't use it on anything expensive, OK? Having a dealer replace an ECU because it needs to be re-imaged after an adventure in scanning is no joke. But I think most people are getting by OK with these units.   eBay on a scratch-and-sniff pro-model oldie, a shiny new TopDon, or???   God dang it, I can't stop looking at this Jimmy. I'm ready! I'll Bring The TRailer! It's beautiful.
    • I removed the OE running boards.  It looked so much better.  I wish I took them off a long time ago.     I had to put something back on for my wife.  I wanted Westin Sure Grip Running Boards but they are very pricey, like $600 plus.  I was going to go with the Ionic 41's like I had on the 2019 Silverado but went with Westin Outlaw Drop Steps instead, about $200 cheaper.  They are sturdy and functional but not super crazy about the look, but it works.
    • It's all a crock of 💩
