vled LMZ led headlights
junkyardz
  • Replies 383
Finally on my way home. Can't wait to finally see these lights!!
So with these lights in Sierra's we lose the high beams?
Also, without sounding disrespectful, but Sawyer_Dowell, how come your truck is leaning back like that?
No, these lights still work with the high beams. lol i've got to change my pic. probably the 4th time ive gotten that. the reason for the squat is b/c i was on a hill and a had a little load in the bed of my truck. The truck still sits about a half inch to a inch higher in the rear on level ground. no squat to the truck.
Can yall post pics of how the bulb is oriented? Like, pull the bulb out of the housing and show how it looks after yall adjusted? I plan to do that with mine later after I adjust mine to how I think the cut off and output are the best that they can. It'll help take the guess work out for those who get these bulbs in the future.
I oriented my bulbs like the pics Jon A has on the other thread of his install. One of the "fins" on the base has an arrow. I pointed the arrow to the right for driver and had the adapter screwed all the way down toward the back of the bulb. From there I turned it about 2.5 turns until it was oriented like the photo in Jon's post. The screw that holds the adapter in is at about a 45 angle from the arrow to the bottom side of it fully screwed on. Once the 2.5 turns it will end up about where it is in Jons post. Once you get your hands on them it will make more sense. I think I pointed the passenger side arrow fin to the left as it was oriented opposite of the driver if I pointed it to the right.
-Skeet
haha ok cool.
So for the lights, I assume it's going to be the 9006 collar? And what temp are the DRL? I'd think 5000K LED's would be a closer match.
And the man to reach for the new covers is who again? Lol sorry, I've been reading like 3 different headlight threads at the same time and I got lost like it was Inception or something.
haha ok cool.
Yea you'll need the 9006 collar.
I went with the 5k and I think Mike did too, Sawyer may have got the brighter ones. It's a pretty close match to me, I'll try and get some good shots of them, but my only camera is the iPhone 6+ and the pics just turn out as a big blur of light all together haha.
For covers you'll need to search for member Jon A and send him a message.
-Skeet
haha ok cool.
Yes, 9006 collar. i got the 6000k but i was trying to match my Rigid fogs. but i would still suggest 6000k, i think they'll match better. Jon A is the member making the covers. just send him a PM
haha ok cool.
Driver side is the 6000k led passenger side is stock halogen bulb. hope that helps
Awesome, thanks a bunch guys!
-Skeet
Excellent, thanks buddy
I'll get some better pics tonight
Thanks man!
Pretty excited about these lights, I have been reading a bunch on all the lighting options on the sierras. I have an SLE, are these a plug and play job for the most part. Do i need to purchase anything other then the kit? Will they work with the SLE, I do not have the led running lights as im sure you all know. Lastly, is there any reason you chose these over the Lifetime LED's???
They are plug and play but I don't think anyone has found a solution for the ones without the LED DRL strips. As far as the lifetime LEDs, I've never even seen them lol. I figured about any LED is close to a lifetime haha!
-Skeet
I was just looking and the 5k is a very slightly brighter hue than the DRL but not much, I'd say it's your closest match.
-Skeet
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
    • This is for those over 70 years of age contemplating joint replacement surgery involving general anesthesia. Even some 55 yrs. ago when I took my pharmacology class the dangers of developing dementia in the elderly that had general anesthesia were beginning to be recognized. Over the years there has been some refinement in the cautionary warnings, avoid general anesthesia if possible if you've had close to 10 priors, especially over the age of 70 and/or a family history of dementia. I'm not including the twilight anesthesia induced by propofol often used in cytoscopies or colonscopies. Seriously think about seeing a neurologist and undergo cognitive testing before proceeding if any of those criteria apply to you. Spinal anesthesia may be an option in some cases. I'm in the above camp and although I could use a new right knee, I get fidgety according to a prior orthopedic surgeon when the bone saw spools up or maybe it was the smell of saw blade meeting bone, anyhow I may have one general anesthesia left in me which I will pocket for now and I'm choosing mind over mobility, anyway where did I leave my damn cane!
    • We understand your frustrations with your auto start/stop, fuel gauge and cruise control concerns since your latest update, @LarT-26. You mentioned getting repairs completed, however, have your concerns been resolved? If not, we would like to learn more so we may explore the best path of assistance moving forward alongside your local dealership. When you have a moment, please visit: https://s.gmc.com/support-request and complete the request form with all pertinent details. This will help us to better understand your concern and ensure that it is routed correctly. We will keep an eye out for your outreach.
