Unfortunately you likely don’t have the wiring you need. There is a pass through nipple on your firewall boot specifically for passing upfitter wiring through. Stealing power from an unused accessory source like power seats, inverter power, ect. might be a viable option. Try to find an option that you don’t have and have no plans to upgrade to. You may be able to source power this way from a fused source.
Edited by TinkeringFox
Hi Guys,
I am impressed with some of your projects and your expertise.  I am not so comfortable figuring out how wires should be installed and really appreciate step-by-step instructions at the level of a 6th grader.  I recently upgraded my 2019 Silverado 1500  LD mirrors to towing mirrors with turn signals.  Got it done because of the help of Mr. Gamboa's harness and instructions. Highly recommended.
I would like to add a 30 inch LED light bar to the front of my truck.  I would like to use the GM 23145158 switch bank (stolen picture attached). Currently my stock switch bank has only "traction control" & "cargo lights."  I do not want to re-label the AUX switches, just want to wire a LED relayed wiring harness to AUX 1 to operate the LED bar.
I would appreciate hearing from you if you can get down to my level.
Selo
On 8/1/2017 at 9:29 PM, smcgillis10 said:
I'm seeing a lot of guys that want to add these switches are having some trouble.
To the guys with ONLY the dome light and traction control switches from the factory be interested in my building a kit for them that they only have to install it into there trucks?
Sent from my Pixel XL using Tapatalk
I’m so confused .. Yes I’m going to have to have you make Me some kind of wire  harness /  relay box .. I tried on my own but ended up drinking the whole 12 pack and said I need to buy something ..  2014 Silverado with the stock traction control/ cargo light .. upgraded to traction control cargo light and 4 aux .. already installed new switch and correct wires in slots 10-14 now what .. Please help
Here’s a relay box for the switch boards with “traction control, cab light, and 4x aux switches” has 5 spots for relays. the 5th relay with trigger with the high beams and Turn on the 2 relays I am using for front lighting.
So the wiring goes from the box to the lights that is the easy part for me. The part that I am having trouble with is from the relay box to the switch.
Which wires ... should be 4 wires on your relay box .. one for switch . One for light , and two powers  that’s  what I understand  I’m having a relay box made and when I have it in hand ill post pictures and maybe can explain it better ...
I’m thinking around the spares battery compartment .. 2014 Silverado .. email Smcgillis10  he is making mine, nothing wrong with supporting a fellow Chevy owner and yes that is where those tiny wires plug into I bought mine directly from Chevy a little pricey I think it’s slots 10-14 but you can double check it’s written somewhere on this thread
Edited by TimmyWeekend
More info
does anyone have the diagrams showing which fuses under hood need to be relocated / installed for this aux switches?
I have a 2016 2500HD WT that came with the switches, I bought the wire harness from GM and plugged it in under the parking brake and ran it out thru the firewall.
seems the GM upfitter website where the pic I need  is down?
thanks
thanks
The relays and fuses should go into the fuse block in the passenger side of the dash.
The switch control the ground side of a relay. You need to have the relay coil hooked to power and the switch will connect it to ground Turing it on.
So i know this is a month old or so but people are still gonna come here and take a look at how this stuff installs, as i did 3 months ago. got around to filling in that list of switches and P/Ns on Page 1. Best I could do, still have some missing... but i hope it helps somebody else when the see it. Cheers and thanks to everybody still on this page posting all the good information. for the record, the Bold dictates the large (wide) keys and regular shows keys that are short/skinny.
I also bought the auxiliary switches for my 2016 Chevy Silverado 1500. I hooked one wire from one of the switches up to the 86 terminal on the relay. The 85 terminal is connected to the positive post of the battery. When I flip all of the switches, nothing happens. Did this happen to you?
Edited by Hudson2000
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
    • Anyone install a a supercharger on your 6.6L L8T? Talk to me...
