Unfortunately you likely don’t have the wiring you need. There is a pass through nipple on your firewall boot specifically for passing upfitter wiring through. Stealing power from an unused accessory source like power seats, inverter power, ect. might be a viable option. Try to find an option that you don’t have and have no plans to upgrade to. You may be able to source power this way from a fused source.
Edited by TinkeringFox
Hi Guys,
I am impressed with some of your projects and your expertise.  I am not so comfortable figuring out how wires should be installed and really appreciate step-by-step instructions at the level of a 6th grader.  I recently upgraded my 2019 Silverado 1500  LD mirrors to towing mirrors with turn signals.  Got it done because of the help of Mr. Gamboa's harness and instructions. Highly recommended.
I would like to add a 30 inch LED light bar to the front of my truck.  I would like to use the GM 23145158 switch bank (stolen picture attached). Currently my stock switch bank has only "traction control" & "cargo lights."  I do not want to re-label the AUX switches, just want to wire a LED relayed wiring harness to AUX 1 to operate the LED bar.
I would appreciate hearing from you if you can get down to my level.
Selo
On 8/1/2017 at 9:29 PM, smcgillis10 said:
I'm seeing a lot of guys that want to add these switches are having some trouble.
To the guys with ONLY the dome light and traction control switches from the factory be interested in my building a kit for them that they only have to install it into there trucks?
Sent from my Pixel XL using Tapatalk
I’m so confused .. Yes I’m going to have to have you make Me some kind of wire  harness /  relay box .. I tried on my own but ended up drinking the whole 12 pack and said I need to buy something ..  2014 Silverado with the stock traction control/ cargo light .. upgraded to traction control cargo light and 4 aux .. already installed new switch and correct wires in slots 10-14 now what .. Please help
Here’s a relay box for the switch boards with “traction control, cab light, and 4x aux switches” has 5 spots for relays. the 5th relay with trigger with the high beams and Turn on the 2 relays I am using for front lighting.
So the wiring goes from the box to the lights that is the easy part for me. The part that I am having trouble with is from the relay box to the switch.
Which wires ... should be 4 wires on your relay box .. one for switch . One for light , and two powers  that’s  what I understand  I’m having a relay box made and when I have it in hand ill post pictures and maybe can explain it better ...
I’m thinking around the spares battery compartment .. 2014 Silverado .. email Smcgillis10  he is making mine, nothing wrong with supporting a fellow Chevy owner and yes that is where those tiny wires plug into I bought mine directly from Chevy a little pricey I think it’s slots 10-14 but you can double check it’s written somewhere on this thread
Edited by TimmyWeekend
More info
does anyone have the diagrams showing which fuses under hood need to be relocated / installed for this aux switches?
I have a 2016 2500HD WT that came with the switches, I bought the wire harness from GM and plugged it in under the parking brake and ran it out thru the firewall.
seems the GM upfitter website where the pic I need  is down?
thanks
thanks
The relays and fuses should go into the fuse block in the passenger side of the dash.
The switch control the ground side of a relay. You need to have the relay coil hooked to power and the switch will connect it to ground Turing it on.
So i know this is a month old or so but people are still gonna come here and take a look at how this stuff installs, as i did 3 months ago. got around to filling in that list of switches and P/Ns on Page 1. Best I could do, still have some missing... but i hope it helps somebody else when the see it. Cheers and thanks to everybody still on this page posting all the good information. for the record, the Bold dictates the large (wide) keys and regular shows keys that are short/skinny.
I also bought the auxiliary switches for my 2016 Chevy Silverado 1500. I hooked one wire from one of the switches up to the 86 terminal on the relay. The 85 terminal is connected to the positive post of the battery. When I flip all of the switches, nothing happens. Did this happen to you?
Edited by Hudson2000
    • You can find PF63 and PF63F filters on Amazon https://www.amazon.com/ACDelco-PF63-GM-Original-Equipment/dp/B09RHSDX81/ref=sr_1_1?crid=4OQX91JYDO1T&dib=eyJ2IjoiMSJ9.YeKFFwDlEvIq8NtpzDXKZOYPE9Wb7dOhD81-cFJvM0UmP0YfeDVQ2KBAKGcPO4qEk_XMyhnRTBxTOGs7NPx8_zQMSeHZQp2ioF-ygHilLtuPs9irwf0K_rmLcWZogdRQrqidMUXW-LDj6d18aYD_ef7p4XBz25hp_LY0T_cl3tAmR8BoI48O854GOLinHwWJVGVhHAXuh1mhk7yVDbemx_TFNK-o53cBpdZJesAYu3U.7eKSD6sp5m7HKQHl8QuhX4E2_SoJAxuJDXosdcBDqzY&dib_tag=se&keywords=pf63%2Bacdelco%2Boil%2Bfilter&qid=1787057919&sprefix=pf63%2Caps%2C159&sr=8-1   https://www.amazon.com/ACDelco-PF63F-Filter-Assembly/dp/B004SIUREE/ref=sr_1_14?dib=eyJ2IjoiMSJ9._0V3idoBxN_3zdTkN3NoGAMq7e2ppPolmaO9ULwdFauE4HoFZHTYwbRycKmVkEy3ZWxFVHKrT9shU_yT821_pSLNmO4koGvxSS0zHK1bdoGEpIu2v9pV3Wz1kuSNXJBD9oau4SkVDh9-Xk1TTxbwDgvG7Y9L_nfeDhpYnQwF1SRz5JPvYzDZxu7PDW2xhYgJm_BWgHia9L0Yw3A8p9FgqVvORS7U7zq6Uh-SnZbPj5JRS-7rI1S5_R_4z4_QBQXwOWBbHdj26igibYN0JcABpgTRyuqNvoA3igX9mzi1F-Y.Nhnl9Y2T9htYr47bKYSdQ96qHIhjqeLcpD0nyIIszfk&dib_tag=se&qid=1787058550&refinements=p_123%3A213202&rnid=85457740011&s=automotive&sr=1-14&srs=21393605011
    • I have a 2000 Silverado 1500 LS, whenever I put it into reverse and also in drive it clunks, the truck also feels sluggish when driving. Any advice/ideas ?
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
