Newb in North Dakota
carock1001
I just bought a 2015 Sierra 1500 and am in the bitter cold of Minot, ND. It averages -20 in the winter, I only drive about 3/4 mile to work, so my truck NEVER reaches optimum temps. I have an engine block heater, but my work doesn't have plug ins. I have been considering getting a winter grill cover (like you see on diesel engines) to help the truck warm up faster.
I have never seen this done on a gas engine before, would installing a grill cover increase the longevity of the truck or just be a waste of $50. I've read that gas engines only need 30sec to warm up, but I'm not sure that is referring to temps as low as what I see here.
Any advise is helpful.
I'm also in Minot. I've never added any type of grill cover or plugged in the block heater at work and haven't had any issues. I usually just remote start and let it run for 10-15 minutes before leaving to warm up the truck.
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
