Why is that? If I buy them i plan on going with the third setting and am curious why you would go with the highest instead. I figure you will achieve better ride on the third setting instead of the highest
I spoke at length with bilstein engineers they claim ride difference is negligible. I can go into further details if you'd like. I've also drove a truck set on 2nd to highest and my truck set on max height. Myself and the guy who owns the truck not on max agree there is no noticeable difference in ride quality
Sent from my SAMSUNG-SM-N920A using Tapatalk
Installed the Bilstein 5100's on the rear today. Firmer ride and the rear stays more planted. Much improved. Next on the to do list is the fronts. I will be replacing the front RC level /lift with the Bilstein's.
Oh no, sorry to here of the install troubles. So, lets first check the part number to make sure you got the right shocks. Are they factory upper mounts, or aftermarket like Monroe?
5100s all the way around. 1st or 2nd setting only on the front.
I have since found out the problem. So i called bilstein and the tech asked me if I have a denali with the magentic auto ride. I said yes i have a denali but didnt know about the magneride. He went on the say that bilstein currently does not have anything compatible with that system at the moment.
So i opted for the rough country 2.5" leveling kit that as the small bracket to extend the sensor rod. (I wanted the suspensionMAXX kit but with CAD exchange rate and shipping, would have been way too much)
Ill be sure to post some pics when its done
Edited by Mg1221
I just spent the past two hours reading ALL 60 pages in this thread and I am still nowhere nearer to making a decision.
I am not partial to keeping or removing the 1" front spacer. I want the best, most controlled ride possible.
My opinions are this:
COA #1: Keep 1" front spacer and install 5100's at stock height setting
COA #2: Remove 1" front spacer and install 5100's at third height setting
A 1" spacer is really nothing to begin with so I shouldn't have any issues. However, the higher the 5100 height setting, it appears the firmer the ride is - this is why I am partial to COA #1. However, with the 5100's being slightly longer than stock shocks, there might be suspension geometry issues adding them to my 1" spacer (albeit the issue seems minimal).
I am installing these shocks because my stock ride sucks and I have the most uncontrollable 'porpoising' while towing.
Final suggestion?
Final suggestion?
Bilstein highly suggest no other type of level blocks on front end. Probably in this thread I already stated this but just in case I'll say it again. I spoke at length with bilstein engineers regarding the front height setting and ride quality. They stated ride quality between the setting is negligible. This is why the highest setting doesn't quite lvl the truck (less than 1/2 inch off) because any higher setting would begin to deminish ride quality. I also was lucky enough to ride in a truck on the 2nd to highest setting and it rides no different than mine on max. Put your mind at ease quit taking all us internet certified mechanics as fact and call bilstein yourself they are awesome.
With that being said the ride is amazing. Worth every penny to get ride of the bouncy bouncy crap ranchos. Live near so IN come on by let's go for a ride.
Just got the 5100's on all 4 corners, front set at max height. Big improvement in looks, and the ride is better in every way compared to the Ranchos. Truck had 32K miles and the rear Ranchos were toast for the second time.
Thanks for the continued orders everyone!!
Be sure to check here for the latest Bilstein shock deals - http://www.gm-trucks.com/forums/topic/197020-set-of-4-bilstein-5100s-under-350-delivered/
Final suggestion?
Option 2 :)
Just installed my 5100s on my 2015 Chevy 1500. I did the rears a few weeks back and finally did the fronts today. I installed them on the highest setting. Took me a while on the first side but the second was pretty fast. I took it for a drive and it's great. Firmed up the front but in a good way. My wife was complaining about how the front end felt since we've had the truck. Took it down some rough gravel roads, bumps, train tracks and am very happy with them. Going to get it aligned Saturday morning. It felt good but I know with any front end work to get it checked. Now to get my air springs and compressor installed on the rear. Just trying to decide on what to go with.post-168486-0-83098300-1493342784_thumb.jpg
Edited by spartantx117
Just installed my 5100s on my 2015 Chevy 1500. I did the rears a few weeks back and finally did the fronts today. I installed them on the highest setting. Took me a while on the first side but the second was pretty fast. I took it for a drive and it's great. Firmed up the front but in a good way. My wife was complaining about how the front end felt since we've had the truck. Took it down some rough gravel roads, bumps, train tracks and am very happy with them. Going to get it aligned Saturday morning. It felt good but I know with any front end work to get it checked. Now to get my air springs and compressor installed on the rear. Just trying to decide on what to go with.attachicon.gifIMG_611.jpg
What spring compressor did you use on the front and how did it go? Ive had no issues with compressing car springs with auto zones ones but second guessing using those on the truck coils.
I used the spring compressor from Autozone. I'll be honest I was really hesitant and a little worried but they worked well enough. Without my compressor to pull them in I don't know that I could have done it though.
if you just wanna level out the truck go 5100's...just installed them,gained 2 inches and seems to ride smoother..but if you gotta off road maybe 6112 the way to go..found them on Amazon for just under a Hundo apieve.
Rental compressors should work fine on these, the spring rate isnt as high as some cars. You could always bring the parts to a mechanic shop, shouldn't be more than $50 to assemble new shocks.
6112s are not out yet, few more months.
Bilstein front, rear, and complete sets with GMTrucks discount - http://www.gm-trucks.com/forums/topic/197020-set-of-4-bilstein-5100s-under-350-delivered/
I installed my 1500's 16000 miles ago, highest setting. No complaints!
Thanks MRT!
Edited by Bwoodkid
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
    • Anyone install a a supercharger on your 6.6L L8T? Talk to me...
