Uggghhhhhh this is by far my fav truck on this forum at the moment.
Thanks! now if I could only keep it clean...
Well got my tires and wheels and leveling kit on. 35x12.5r20 toyo r/t and 20x9 +20 fuel coupler wheels. Fabtech 4 inch, comes with 5 year 60k warranty. Basically a glorified leveling kit, turned down to 3 inch. Still had to do some minor fender well trimming.
Why does mine have running lites above cab? Must be rare. Possibly a collectors item? Lol! post-148235-0-28193400-1487971958_thumb.jpg
Edited by jt metal
Here is my new 2017 6.0 I just picked her up on Saturday traded in my 2015 GMC Carbon 22 Crew cab for this as I bought a new house and needed a new plow truck. The new fisher HD2 plow is going on Wednesday and I've put on an extang tonneau cover and have a LineX liner going in Tuesday. Going to have to wait till summer I think for some new tires and wheels (I do run a tire store after all) she needs something a little fatter than the skinny 245/75/17 on her now. So far I'm loving having a 2500.
Why does mine have running lites above cab? Must be rare. Possibly a collectors item? Lol! IMG_20170224_145934-640x380.jpg
I wish mine had the cab lights. The dealership didn't have a duramax with cab lights, and wouldn't install them. I was pretty bummed and didn't want to wait 4 months for a special order.
Just bought a 2016 2500hd Denali with the 6.0! Last 2016 3/4 Denali on the lot so I got a GREAT DEAL! Can't wait to get some wheels/tires and add some more pics! Let me know what you guys have done, leveling kit, wheels/tires and any other ideas. post-144024-0-69315000-1488002846.png
Took delivery of a 2017 2500 LT CC 6.0 standard bed that is replacing a 2014 1500 LT CC 5.3 short bed. I didn't realize how annoying the transmission really was in the 1500 until driving the 2500.
  • Like 3
BE glad, I wouldn't trust lites added after the fact. Just me......
Edited by jt metal
Here's mine this past week starting a 1000 mile round trip haul. First tow of the TT. Took me 10k miles before I finally got to take it out and see what she could do. Man it os soooooo much better pulling with the duramax than my poor little 5.3 before it.
  • Like 7
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
