Desperately need tow mirrors. Can't believe they even make 2500's with dl3's.
Here's mine, nothing special. Just need tow mirrors as well.
Love the look of the midnight edition, makes me wish I went to the other dealer and got that instead. 485960c8339a6b34185c9d2fae3edc75.jpg
  • Like 3
Very nice truck! What are you suspension mods? Looks taller than stock.
Thank you!
Just the RCX 3.5" "lift"
Wish I went bigger though. Already looking into at least their 5"
First Tow in 2017 CHevy 2500 LT after Upgrading from 2016 GMC 1500 SLT
What kind of camper? Looks like a Palomino Solarie? That's what we have.
No doubt! I really, really need to get some tow mirrors.
WOW!! Very nice.
2016 Stelth Evo made by Forest River...they make the Solarie also
Removed running boards and installed Magnum rack
Did you do anything special to get the tool box to fit with the magnum rack? I have a regular cab with the magnum rack and need a tool box to store truck stuff without filling up the cab.
I had to move the toolbox an inch and a half to the back of the truck to clear the lid when open. If your toolbox has a recessed hinge you may not have to move the toolbox back. The Weatherguard toolbox fits between the base angles of the rack with a quarter inch to spare. My toolbox is an older version that doesn't have the recessed hinge, I think the new ones are recessed but you should check. It took a bit of adjusting but I was able to get the Magnum rack, Access roll up cover and the toolbox to play nice together. Just the 1-1/2" gap in front of the toolbox.
Excellent. I will look for recessed hinges.
Did you utilize the stake pocket mounting bolts to mount the toolbox?
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
