28 minutes ago, revrnd said:
Is the Alaskan Edition a Sask' dealer option? I've seen Cheyenne & Kodiak 'packages' here in Ontario.
No it’s on the Chevrolet website as one of there limited edition models, so it’s North America wide.
My 2017 2500HD Z71 SLT
-Fully loaded-only difference from a Denali is the decal, lol. Def gotta upgrade the rubber B4 winter.
Edited by hydroguy
And the seats (10 way vs 12 way), and the dash display.
Gorgeous truck.
Picked it up 10 days ago, traded '17 NHT 6.2
Hooked onto the travel trailer and headed to fla.
1600mi on it, what a great truck.
Where abouts are you staying in Florida?
Sharp truck!!!
11 hours ago, SierraHD17 said:
Here is my bucket of bolts.  It's a 2017 2500HD gas pot..... and probably about the weirdest optioned SLE ever made.  I'm good with it though!
what makes it so unusual?
Sharp truck!!!
Port Orange
4 hours ago, steinb3rg said:
Chasing elk in Colorado.
Nice! I'm jealous! I've been out there camping/4-wheeling many times, but my work schedule hasn't allowed me to do any hunting. What part of the state?
We are in Gunnison until this coming Friday trying to get it done. Talk about a learning curve coming from below sea level in LA. Seen a couple but nothing close enough to get to yet.
Plenty cool truck picture opportunities though.
Seems like its always dark or snowing when I get a chance to snap a picture of my truck.  Just did a quick 1300km road trip on the weekend and she ran like a champ.  Definitely likes the fuel, but you gotta pay to play.
C2ED2ACB-6ED6-428F-88AA-EA9B4F912815_zps
FAD0342E-BAD0-4123-8CE2-6DF9888E41D8_zps
1691711C-99A3-4BE0-9CE0-AF32D81BE7C1_zps
Awesome! That's a beautiful area! I've ridden 4-wheelers all around the national forest NE of Gunnison in the summer time. Good luck with the hunt! I'm sure the snow makes hiking even more of a challenge!
On 11/6/2017 at 9:34 AM, SierraHD17 said:
Choice of options.
I'm intrigued...
I want an SLE with a tow package, preferred equipment group, Bose, and carpet delete. Leather would be nice, but not sure I want to spend the $$.
Love your color. I think your pic made me decide on Blue vs. Red!
    AidenVorpagel
    AidenVorpagel
  • Who's Online   1 Member, 0 Anonymous, 1,000 Guests (See full list)
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
