All those that use e85!?
Slo281
Is the feeling of the trucks change in hp significant enough to make up for fuel loss? I really like the idea of getting 380 hp for something as simple as running different fuel so to all those running it or who have ran it, post your reviews and thoughts.
  • Replies 76
It really comes down to how much cheaper E85 is. I haven't crunched the #s but I believe 85 has to be about $1 cheaper to equal out. I could be wrong though, just what I think I remember from another post. There's actually not any E85 around where I live, I would ahve to go over an hour away to get some so I won't even get to at least try it.
HP difference isn't really all that much but the high compression engine really likes E85 and feels very "snappy" for lack of a better word. Be prepared for significant MPG loss. Its not really worth it to run E85 in the winter due to MPG loss. BUT... Run a tank or two of E85, drive in M5, and use tow haul mode. Like a totally different truck lol. Shake and bake :driving:
Oh yeah don't forget to turn off the TC and Stabilatrack during those burnouts!
I've been running it for well over a year now. I lost about 2 to 2.5 mpg. Got 18.5 on the highway running 80 to 85 mph. The truck is definitely more fun to drive. The throttle response is a lot better, and it feels like it accelerates much better even at partial throttle.. It's obviously worth it to me. I figure I lose about 15% on mileage so if gas is $2.25 E85 would have to be $1.91 to break even. These truck run better on premium so that might be the gas you want to compare the price to. The boost in performance has got to be worth something too. A lot of guys here don't seem to want to consider that though. You will see most negative comments on E-85 from guys who haven't run it. I do. I like it.
I've been using way more E85 than Premium in my 5.3L FFV truck and, like others have said, the engine runs differently; it also has a different sound. Response to throttle input is sharper.
Regarding fuel consumption rate, it is lower than using premium, which is expected. Personally, I want larger power output, I have very little care about fuel consumption rate as long as the higher consumption rate is commensurate to higher power output. Whether it's 4 mpg or 40 mpg, I could not care any less.
Now, for those who are watching the mpg very closely, keep in mind that the fuel price itself fluctuates. When comparing prices, it's best to use percentage over an absolute difference. The fuel consumption rate is only linear with the percentage and when comparing cost, using a 20-25% factor would predict a better cost estimate over, say, $1/gal price difference.
I agree with most, I use only E 85 locally. On a trip I use premium grade gas when I can't get E85.
I hate ethanol, here in PA you have to buy it , in TN where they do have real gas my truck runs better and the mpg's are a lot more
I use E85 most of the time. Where I live there are 3 Valero stations that have it. Right now where I fill up regular unleaded is $2.15 a gallon and E85 is $1.99. Less mpg than gas, but not enough for me to make a difference. I do feel more "pep" when using the E85. Makes me feel good supporting the American farmer, I grew up in central Illinois farm country (corn and soybeans as far as the eye could see). Would rather spend my money on American corn than Middle East oil.
I run e85 almost exclusively, big difference in the way the truck drives. Way more fun. Here the gas prices as of today are 2.10 for 87 and 1.73 for e85. Now that the warmer weather has arrived, my 50 mile avg usually hovers around 15.5mpg on e85.
I tried one tank and my truck was significantly more enjoyable to drive. The truck accelerated and drove much better the motor and transmission even seemed to work more efficiently together. I would have continued to run it if I hadn't been in a rush and low on fuel forcing me to get 87.
I wish it was that cheap here in tucson, gas is 2.07 and e85 is like 2.39, im getting about 18mpg doing mostly Highway compared to 23 on 89 octane. Cost is more but it runs Better, cleaner and helps me roast them tires that much easier
I haven't ran E85 since last fall but when I did I lost about 2-3 MPG highway which I didn't think was too bad. Especially when I bought it for $0.89 a gallon at a station in Alexandria, MN. I can monitor timing and KR with my ScanGauge. When cruising in V4 mode, I normally pick up KR with gas but with E85 it's basically gone.
Running my first tank, engine sounds a bit different and I do feel a difference. It's not a ridiculous difference but the truck is a little quicke and hard to keep my foot off the pedal. Downside is e85 where I live is 2 cents cheaper than regular fuel. With the mpg lost probably won't continue to run it from a financial standpoint.
Run E85 for 2-3 more tanks, then go back to E10. See if you still like E85.
    • 2020 2500 HD...I had some trouble getting the key into the ignition switch but went in fine after applying some extra effort. Since then, the door chimes when open when the key is out of the ignition. Also, when I lock the doors with the switch on the arm rest, the driver door locks but then unlocks. (I can lock everything fine with the fob) The message on the little screen displays the "Engine Hours"...kinda weird.   I'm guessing something happened to the ignition switch and it thinks the key is still in there. I unplugged the batteries for 20 minutes, no change. There are a number of videos on YouTube but nothing I can find that address this specific issue. Ideas appreciated, thank you.
    • Based on what I can tell, yes.   As for updating it, its a mixed bag.  Updates do fix a lot of issues, but occasionally can create some oddities.  They do more good than harm though overall.     Here's what the most current one does and a  V171 Improvements Important: Improvements will vary by model, build configuration, system, and sales region. Not all vehicles have all features. OnStar and Wi-Fi may not work after remote start CarPlay may not automatically reconnect Part of the Driver Attention messaging screen may be in English even though the language is set to something else XM may not work After a dead 12V the radio may set to Arabic at each startup Bluetooth contacts might not be able to sync with the vehicle During an OTA the 12V battery may drain Customer might see a screen telling them to return to the dealer After changing the Wi-Fi SSID or password a device may not disconnect If a device is connected on the 2.4Ghz band, nothing will connect to the 5Ghz one, which could show as slow Wi-Fi speeds Customers might have noticed Wi-Fi dropping in certain areas and reconnecting later Customer might see the top of the screen blinking during Android Auto Android Auto may not connect CarPlay audio might momentarily cut out The "Add Phone" button may be grayed out The radio may not start up   V167 Most Notable Improvements:   Outside Air Temperature is incorrect. -You may see a popup message for Engine Shift. (Corvette Only) After changing the exhaust sound they get a popup that "mode change not applied", even though it was. -When changing volume, the volume bar is for Traffic instead of Audio. -(Corvette Only) Improvements to the placement of buttons and text. -If the customer receives the message "Apple CarPlay Could not connect", the cursor might move in the opposite direction than expected when using the control knob. -Android Auto automatically starts playing their music, even though they have turned that off in settings. -Intermittently they have a red OnStar LED with no OnStar function and/or no audio. -The minimum length of the Wi-Fi password was increased to 12 characters. -The popup message "Driver Attention Check, check your mirrors or Super Cruise will shut down" may not have come up on the display when it should have. -Startup animation added for 20th anniversary of the V-Series on Cadillacs. -The Navigation app received location improvements when going under long underpasses. -In the Navigation app there are filters for charging points that the vehicle cannot use.   V164 Most Notable Improvements Most notable improvements contained in this release may include: Apps Intermittently, an “SD Card Removed” message will pop up in the Navigation app. While in the audio app, the radio may stop working. Trailer Tire Pressure sensors may not be learned in the Trailer app. Not being able to return to the home screen while in the Camera app. After an ignition cycle, the radio might go to a black screen or stop working if using Sirius XM. Spotify icon truncated on Audio app.   SXM When changing power modes with the ignition switch, the HVAC pop up might appear. During startup, the radio will show the brand splash screen then go blank. Receiving a confirmation pop-up when changing drive modes. A “Return to Dealer” message may appear on the radio screen. SuperCruise setting toggle may not work. System After an ignition cycle, the radio might go black or stop working if using Sirius XM (SXM). Settings When performing a factory reset, the radio may stop working. After performing a factory reset, the radio may stop working when trying to switch users. When trying to go into the Language section quickly after startup, the radio may stop working. Projection Wireless CarPlay cannot be connected after unpairing another wireless Android Auto device. When the Android Auto screen comes up to connect wirelessly, the screen may freeze if the Cancel button is pressed. Removed the Apple CarPlay Cannot Connect screen when a device fails to pair during the autoconnect process. CarPlay information may not show up in the audio app. Near Field Communications (NFC) chime may be heard when NFC does not work. The Cannot Connect screen does not pop up after the first connection on wireless CarPlay fails. Apple CarPlay is now functional in Guam. Over the Air (OTA) When a software update is cancelled, the downloading logo may still be displayed. Energy When using the Energy app, the radio may stop working. When plugging in the vehicle, the display might show “Now” instead of “Charging Upon Plug In.” Instrument Cluster Voice recognition can be started while on an OnStar or phone call. When downloading contacts, there is a progress bar and circles on the Recents page of the cluster. The temperature on the cluster and the display may be different. After receiving and ending a call on the secondary paired phone, the cluster may get stuck on the phone menu. Bluetooth Intermittent Bluetooth connection loss.
    • Looking for help troubleshooting a metallic like front end rattle. Figured I’d see if anyone had thoughts before I schedule an appointment with the dealer.   The rattle is fairly loud and occurs primarily when the front driver side wheel hits a bump, even fairly minor road seams. Sometimes does it when the passenger hits a bump but I don’t believe when the rear hits. Rattle still occurs when foot is pressing brake peddle so I think that rules out the caliper rattle I’ve read about. I’ve also checked the running boards and they are tight.   Most noticeable at slow speeds.    Any insight is appreciated.
    • We try to make cruise the coast. It’s where our favorite casino is. I only want to spectate. Never took a car. Always had one to take. I belonged to a club once. Even when I used to drag raced. It was during test and tune. Probably because I’m not a night owl, party person.
    • We had a pretty big cars and coffee in Indy this past weekend.  Pretty much anything and everything was there.
