All those that use e85!?
Slo281
Run E85 for 2-3 more tanks, then go back to E10. See if you still like E85.
I'll try it a few more times. seems the truck loves running on this stuff. I'm about a half a tank in and it's running good and I gave noticed the different engine sound u mentioned in the post above
I agree with pos vett
Care to elaborate ?
  • Replies 76
After a couple tanks, its more e85 content then your first tank of e85 since it still has regular e10 in it left over, and after running a couple tanks you'll be use to that feeling so if u swap to regular 87 or 89 then you'll notice how just the fuel change makes a decent difference, i imagine summer time weather will be even more drastic cuz e85 has a cooling effect as well like methonol injection. ..from what I've read at least
Lingenfelter test :Gas (E10) Rating 355/383 E85 Rating 380/416 Gas Dyno 302/332 E85 Dyno 321/355 Gas O to 60mph 7.5 E85 0 to 60 6.96 Gas 1/4 Mile 15.94/90.7 E85 1/4 Mile 15.51/93.5 "Taking advantage of the ’14 model’s Flex Fuel capabilities, LPE dumped in some E85 and repeated its tests. The on-board sensor read 65% ethanol content, with 1/8 tank of E10 diluting the mixture, when the dyno read 321hp and 355 lb-ft of torque. This certainly seems in line with GM’s 380hp crank horsepower rating when using E85 (355hp on gasoline) as well as the subsequent acceleration tests. The 0 to 60 dropped to 6.96-seconds and the 1/4-mile time was nearly a half-second improvement (15.51 at 93.5mph). LPE recorded an average of 18.9-degrees of timing (up from 17.2 on gasoline), and a reduction in intake air temperature (7-degrees average) and engine coolant temperature (3-degrees average) or http://www.lingenfelter.com/LPEforumfiles/showthread.php?2248-2014-1500-Silverado-with-5-3L-L83-engine-work-begins for more good e85 stuff
87 is 2.09 and e85 is 1.55. Even if e85 was the same price I'd run it. The truck seems to run so much better with e85. I just did a trip from Austin to new Orleans and back and averaged 16.5mpg and hit up to 19mpg during some stretches of highway. That was with a kayak on my bed rack creating extra drag and loaded down with camping/fishing gear and 20 extra gallons of fuel to get me between e85 stations.
On 87 my truck drops out of v4 mode with the slightest bump of the throttle. It's also not as responsive.
I don't know what the people at Valero are smoking but their e85 prices are stupid. Usually 10cents cheaper than 87. I never buy it from them.
Have not tried e85 yet but I guess I will after reading this. where I am the 87 and e85 are 2.09. My question is how low should my fuel level be to start using?
If you want the max effect, wait until the fuel level is as low as you're comfortable with. Otherwise, it doesn't matter, the PCM calibration will adjust accordingly almost right away.
Thanks
  • 3 weeks later...
I've become a big fan of E85 since getting my truck. It feels like it drives so well using it. I like the idea of it burning cleaner and cooler, producing more power, and that it's from the good ole USA (minus the politics behind it).
I just posted my entire mpg logs using it in another thread if anyone wants to see it is here:
http://www.gm-trucks.com/forums/topic/152976-2014-gas-mileage-mpg-topic/?p=1619068
Wish my 6.2L could run E85. Studies have shown E85 runs a lot cleaner than gas mixed with ethanol.
you can, you just need a tune for it.
It's not that easy. I believe there's also a different fuel pump and injectors and also a sensor to detect E85.
its that easy. no parts needed. i have done it to several cars. three of mine (including my C7) and 4 customers. like i said, you have to tune for it.
Im tuned for E85 and I love the extra power. I don't tow anything but E85+plus transmission tune = Fun. I do get about 1.5mpg worse than I do when I run 93. but WHO CARES! :-)
13-13.5mpg city on E85
14.5-15 on 93 octane
Does a C6 Z06 come with an ethanol sensor?
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
