New Look, What Do You Think?
krdeal
I have been longing to change the all chrome look of my 2014 Iridium Silverado. I bought a gloss black grill from GM accessories and cut the egg crate grill out and went with a billet grill. The grill shell had to be painted to body match. I like a little bit of chrome in touches, but not all chrome or all paint. I have a set of GM LTZ Projector headlights that are going in next. I wanted to see if I liked the chrome around the headlights or to body match that as well. I don't mind the bumper so much being chrome, but the overall look is growing on me. I also went with a contrasting Chevy bowtie emblem in Topez Blue. What do you think?
I like the grill insert for sure. Kinda reminds me of the high country
Looks good! I'd color match the headlight bezels when ya put in the new lights and call the front done!
did you paint the bowtie in the grille or buy it? Is it hard to swap out? I want to paint mine white to match my trucks color.
Plastidip is your friend
There is a company that actually makes billet replacement bowties for the front and back that body matches the paint. Plastic dip is not an option if you want body match paint color. They actually have an option that I used that gives you a template to drill out the plastic rivets made into the factory bowties and you never have to use a tool except the drill! I drilled both of mine out and replaced them with billet body painted emblems that use 3m double sided tape. I had done this on my original grill and then I swapped the bowties when I had the grill out and could easily get to the mounting pins. The company site is: http://www.americanbrotherdesigns.com/
thanks, I'll check it out, I only have the one bowtie in the grille due to I took all other badges off the day I brought it home
I just checked them out and they only do black or chome
Krdeal - thanks for the web site , Now I had to pick a color for the interior knobs - RED or Topez Blue , Black truck ????
^^this!
Truck looks awesome!
Unfortunately the bowties are now only black or chrome. Only GMC are color matched.
That American Brothers is who the forum store on this website uses. I got my front GMC emblem in blue from here. The admin commented on my post that GM will not allow colors for the bowtie, only the GMC letters. It's a license issue, they legally cannot produce other colors.
    • Can it still be Assembled II?   Viscosity on the decline by various means. Heat on the rise making that worse. Engine RPM in the tank. Smaller motors with more boost trying to emulate an electric motor. Full torque, zero rpm. Then we will triple the OCI. Argh.    But wait....there is more. LSPI has pushed a shift from Ca to Mg and as that cost more PLUS the run to lower sulfur compounds the TBN is moving in the wrong direction for the increased OCI's demanded.    That not being enough to placate a demand for a parameter they can't measure the other sulfur bearing compounds are also under attack. That would be zinc and phosphorus sulfonate compounds. To some degree those are being replaced with boron esters and others, i.e. titanium ect. All of which have shorter service lives. And there there is the "Secrete Sauce" marketing for AW adds that 'Can't be detected by UOA's" but trust me because I (the blenders) never ever lie.    Spoiler alert; ALL additives are sacrificial! Smaller amounts of the old blended with less robust versions of the new do not equal longer service lives. So what are the blenders recommending? Wait for it.......   MOVING THE GOAL POSTS! OMG      Let's declare the long standing TAN/TBN crossover irrelevant and tell people that soot is a great 'graphite' based lubricant which can aid tribo films. Wait, what? Let's declare that the standards used for oxidation and nitration were to conservative and can be expanded. Let's tell them that because GDI fuel dilution, although being a VISCOSITY KILLER and an acid generator is actually okay because we have better base oils that limit viscosity failure limits. (Said knowing this is measured in fractions of a centipoise and in bases not commonly used in shelf oils)   Lying from the heart is not just the new normal but we have a public, a very young public, that is so ignorant of the facts and so sure of their "RESEARCH" into AI driven models base in regurgitated  instead of scientific research based unvarnished, peer reviewed FACTS that the incoming guard is loosing their grip on reality and the OEM's are tickled pink while the blends bend the knee.    You have an ever limited set of tools to work with. And sooner or later those will be taken from you as the API and the EPA strangle the last remaining fluids from the system. What you have left is your wits. If you care to use them.    At some point in the very near future it will not longer be possible to do "What is best for the machine", and be replaced with "The best you have access too". You WILL be rewarded with half the life and twice the cost. That isn't that hard to predict.
