Why isn't this the default mode for these trucks????? Seems like all good stuff to me:
1) The transmission is more responsive and consistent than in normal mode.
2) Transmission wear is reduced
3) break wear may be reduced
4) Seems like fuel economy is even better. No firm #'s yet, but watching the mpg seems like it is actually more efficient then normal mode. I'm finding it stays longer in 4 with far less switching between 8 and 4.
5) Feels like I have more direct access to the engines available power, making for the impression of faster acceleration.
I thought there was a big difference between auto and 2wd drive regarding how responsive and consistent the transmission felt.... The difference between tow/haul and normal makes the auto/2wd difference seem completely insignificant by comparison. So far I've only tested it in 2wd.
Ok... so, what's the downside to driving in this mode full time? I know there's gotta be one... If not, I see myself always running in tow mode.
Edited by bertiman
No downside, the motor and trans actually run cooler as you are spinning the water pump and trans pumps faster moving more liquids.
I always say the motor being bogged down uses more fuel to move the same load vs less fuel and more rpm, let that motor spin so it can do its job!
I don't think it changes any of the engine tuning, but only holds gears longer instead of quickly shifting. So it is more sporty, but it will use slightly more gas. Probably nothing very noticeable.
I've only used tow/haul mode to tow or haul. I love the "S" sport mode in my wife's jetta. way better shift points, although it locks out 6th gear so once on the highway I shift it back to "D".
I don't think the GMC does this. You have all 6 gears available in Tow/haul unless you use the "M" manual shift. Then you can hold whatever gear your in.
I didn't like how long it held shifts in tow/haul mode.
Recently I have been driving in M6 mode a lot vs regular drive. I have AFM turned off. So it never goes into V4 anymore. But driving in M6 just seems all around better. Not sure why.
At first I found it a little strange. But it quickly became very predictable and welcome.
I don't like the downshifting that the truck does in tow mode. Other than that, it drives much better.
I like the downshifting... If I don't want to downshift, I just feather the gas. I also noticed when doing this, the mpg go through the roof!
I was using M5 and tow haul mode since day one. Now my TCM tune is based on the tow haul mode and is great. And the tow haul mode is like an old turbo 400 with a shift kit. If your on an old paved road or smooth concrete this little 5.3 with a tune on E85 will chirp the tires like in the '80s. It scares the shit out of Mustang and Camaro fanboys haha. Is it any faster? No, but it shure is funny.
:driving:
Edited by scott19677
Gave her a try today and hell yeah! Drives way better, seems to shift better (quicker and cleaner like a shift kit) and doesn't hunt for gears nearly as much. My favorite new "free" mod!
This is what I'm say'n! It's raining today so I plan on testing it with auto/4wd.
You guys didn't know? The Haul in Tow/Haul Mode stands for Haul @ss!! I've noticed with the xfer case in AUTO and the Tow/Haul Mode on the truck moves out pretty nicely.
    DM22
    DM22
  • Who's Online   7 Members, 0 Anonymous, 1,646 Guests (See full list)
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
    • I went to the county a few years back to dispute my property taxes. To do that I hired an appraiser and a lawyer. The County Assessor wished to argue that the homes in my neighborhood the appraiser used were all 'distressed properties" and not representative of the "Market Average".    My response was," Of the 50 homes in our subdivision 43 of them were "distressed properties" under bank foreclosure and as such "Distressed IS the market". Lawyer about choked on his coffee and handed the Assessor the 'receipts'.    I won that case on the evidence provided by the Lawyer and the Appraiser.    We have the same thing going on here. My statements were based on the GOVERNMENTS NATIONAL DATA and yours on local markets in areas of your interest. They are both correct....   Thing is, this divergence was based on NATIONAL and not on LOCAL. I think you even understand that. But like you said, we are both stubborn and hardheaded.    I do not see any advantage to disengagement.  But that said we can step back to compose ourselves.
    • Trust me I appreciate the comments and concerns. It's what I was looking for to help me evaluate the situation and what I want to do. I have decided to move forward with the BORA hubcentric slip on 3/8" (.375") with the extended lugs nuts. Fedex says they should be here Monday :). Meanwhile, the dealer got the remote start and Patriot spray in bed liner done over the last couple of days. Also, I installed an inline stop/start eliminator today. Starts back up in what whatever mode you shut it off in, so you don't have to hit the button every time you fire up.
