824 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Just had my 2015 sierra 6.2 8 speed at the dealer today there's a new bulletin that came out 1/20/17 16-NA-411 for hard shifts, clunks , v4 to v8 banging noise in trans so far so good we'll see.
Do you know what was done? Reprogramming? Something done physically to the trans?
I think that TSB is only for 15 and 16 model years. I wasn't able to find anything matching for 17 model years. That being said, I did notice that the loaner 2017 6.2 8 speed I had for a short time had a defined kick when downshifting to gear 1. My new 2017 5.3 8 speed is smooth like butter.....although I only have 900 miles on it, time will tell.
my 8 speed works good, only thing is if you stop real fast it will kick you in the butt when it shifts fron 2nd to first. i just learned how to keep it moving till it shifts all the way down.
I fixed this by driving 5 miles in m6 between 1100-1500 rpm
C1 relearn outlined here.
http://gm.oemdtc.com/492/transmission-adaptive-functions-and-correcting-low-mileage-harsh-shifts-2015-cadillac-chevrolet-gmc
-tapa
Edited by m3n00b
After an extended drive on Sunday and about 250 miles since getting the AT back from dealer all seems good. No more shudder felt between 62-72 miles per hour under light load. Will keep everyone updated.
Wife said today: if your transmission can't be fixed, at about 35k miles you need to trade this truck in...
I just bought a 2016 GMC Sierra SLE used with 2,800. My previous truck was a 1999 Chevy LS Z71. 4 transmissions at 280,000. I bought the new one thinking there is no way GM has not fixed that problem...My biggest complaint about the Sierra is electronics. The throttle response is horrible. Sometimes snappy other times it falls on its face. Seems to do exactly what you don't want it to do. Also, when going up a small incline if you're not careful the shift to 1st is horrific. Huge clunk shakes the whole truck. Most shops say it because of modern transmissions. Blaming computers on shifting timing. If you pull the fuse to the stabiltrack it helps. Frustrating, I know it's just a truck but my 99 would smoke my new one 7 out of 10 times. I tried a hyper tech programmer. Didn't change any of the unpredictable lag. Is there a clean way to remove all electronics with a switch on the dash? I know you can pull the fuse (or interrupt the circuit with a switch) to the stabiltrack but it flashes errors on the dash. I'm an electrician so I understand basic circuitry. Is it possible?
PS
If we are adding switches, what about a switch to lock the locker on the dash?
Will be taking mine in next week for the trans shudder. Mine does it at occasionally in any speed. They want to do a flush and something else first to see if that fixes it. If that doesn't fix it, then they will replace the torque converter. Luckily, I know the mechanic that will be doing the work, so I know exactly what will be done.
I have a 16 5.3 8 speed and have the same Trans issues. I had the Torque Converter replaced a few months ago and it did get better. I tow a 9k pound RV and am generally happy with the truck. What does piss me off is the Catch Can issue.... Someone else said it but after paying 53k for a new truck we should not have to do anything to it! If they know there is a Catch Can issue they should address it, AFM address it.... I am not rich but like most am a hard working man who has looked forward to having a truck like this and have no problem paying 6 hundred bucks a month for the privilege.... But GM should be embarrassed!
But hey, this is the new world we live in..... On a side note going in to get the Bow-Tie illumination option installed this morning.
Great Site here...
Kudo's
Keith
I have the 6.2 8spd in a 2016 and it shift like butter. You literally have to watch the tach in order to tell the shiftpoints above 2nd gear. In fact- this is the best motor/tranny combo I have ever owned, including one CVT in a Toyota.
CVT? Really? I can't even describe how much those things want to make me kill somebody! Maybe they are better now.....
CVT's and hybrids are pretty well paired. Very linear torque curve.
Had my truck in for the second time for the hard shifts and clunking. The first time they did a relearn. The second time the tech acknowledged the shifting behavior, but said that they discussed with GM and said it was completely normal.
Cool.....
At 4000 miles now 2016 6.2 8spd. Smooth as silk loving it. Somewhere earlier in the is thread someone mentioned that there is no longer a transmission dip stick i will have to check on that. Sounds weird LOL
Update at slightly over 14,000 miles now. 8spd shifts very hard, getting a tire chirp in 2nd 3rd and 4th and 5th sometimes. That is the way i have set the programmer LOL. I may set it back for girly shifts in a few days...... too bad GM did not have the marketing sense to provide owners with driver selectable driving modes. The 6.2 8spd combo dang sure deserves
i have an appointment for saturday morning to address the hard shifting. for the 3rd time... i will keep everybody posted. i am going to bring up the printout from another memeber that identified my problem exactly and they replaced the Torque converter to fix
    • Did have to make 1 modification because of the WeatherTech rear mud flaps and that was needing 3 longer screws than what came with the install package. 😄
    • Picked up the liners yesterday. Installed passenger side WITHOUT any modifications. All mounting holes lined up perfectly. Rain is interfering today with drivers side. Very Happy! Will add pics when finished
    • That is a fair point, and I agree that trying to log “everything in the truck” would be the wrong direction.   There are a lot of modules and a lot of traffic. If the product became a full-truck datalogger, the amount of data would get huge very quickly, and most owners would never use it.   I think the first useful version would need to be narrow: - powertrain-side event evidence - selected high-value parameters - communication / voltage / reset events - pre/post event window - short report first, raw log only as backup   One distinction I should make is between active OBD/PID polling and passive bus capture. If you are polling PIDs through OBD, then yes: the more parameters you request, the lower the effective sample rate becomes, and you are adding diagnostic traffic to a vehicle that is already busy running itself. With passive CAN capture, the recorder is not asking all the modules for data. It is listening to traffic that is already on the bus. So it does not consume vehicle bus bandwidth in the same way that a scan tool polling hundreds of PIDs would. But your point still applies in a different way.   Even if passive capture does not add bus traffic, the recorder still has limits: - processing rate - storage rate - timestamp accuracy - decoder workload - event filtering - report size - user attention span   So the answer cannot be “log everything and let the user figure it out.” The product would need to store enough raw evidence to be useful, but only decode, graph, and present the important parts around the event.   A practical report should probably show: - what triggered the capture - how much pre/post data was preserved - which selected parameters changed - how those values compared to baseline - whether the same pattern happened before - whether any voltage, reset, bus-off, lost-message, or communication fault occurred - selected graphs around the event - raw data only as supporting evidence   So I agree with you. More data is not automatically better. The real product is the reduction from raw data into a useful event report.
    • That makes sense, and I agree with most of that.   I think the product would need both: 1. a default powertrain template, so it is useful out of the box; 2. user-selected priority parameters, so the owner or shop can choose what they want to see first.   Different users are going to care about different things. One owner may care about oil pressure and voltage. Another may care about misfire trend, AFM/DFM behavior, or U-codes. A shop may want communication events and repeatability first. Your baseline point is probably the most important one. Raw data is not very useful unless the report can show what normal looked like for that vehicle under similar conditions.   The way I would think about it is: - start with a basic known-good baseline - learn normal behavior for that specific vehicle over time - allow the event to be overlaid against baseline - show whether the event was a one-time spike or a repeatable pattern - provide a simple severity level, but with clear limits on what that severity means   For example, early severity could be something like: - Info: event captured, no obvious abnormal pattern - Watch: value moved outside baseline, but not repeated - Warning: repeatable abnormal pattern under similar conditions - Critical: communication loss, voltage drop, bus-off, reset, or severe repeated event   I would not want the first version to say “replace this part.” That would be overclaiming unless there is repair-confirmed data behind it. It would be more honest to say “this pattern deserves inspection.”   On the OBD port question, I think OBD absolutely has a role. OBD is probably the right place for: - DTCs - freeze frame - VIN - calibration information - normal scan-tool parameters - Mode 6 / enhanced diagnostic data if available The reason I am still looking at an ECM-side recorder is that the failure may happen before anyone connects a scan tool. If the owner plugs in a scanner after the event, the pre-event evidence may already be gone unless the ECU happened to save it. So I do not see this as “OBD versus ECM-side.” I see it more like: - ECM-side recorder: always armed, rolling buffer, event evidence - OBD/DLC companion: DTCs, freeze frame, VIN, calibration, normal scan data - phone/cloud: status, notes, upload, report generation, notifications   I agree that phone connection and push notifications would be useful. I just would not want the phone or cloud connection to be required for capture. The recorder should save the event locally even if the phone is not connected. The phone should help with event marking, download, notes, upload, alerts, and report viewing.   For a default GM V8 event report, would this list make sense? - RPM - calculated load / MAP - throttle position - vehicle speed - gear / torque converter state if available - coolant temperature - oil pressure - oil temperature if available - battery voltage - commanded AFM/DFM state if available - actual AFM/DFM state if available - misfire counters / roughness by cylinder if available - fuel trims - relevant U-codes / communication events - bus-off / lost periodic message / module reset / voltage drop events Which of those would you remove, and what would you add?
