Even on the '17's they are still using both. Depends on trim, cab and engine.
Edited by redwngr
According to the '17 Silverado HD brochure:
Standard on Crew Cab models and 4-door Double Cab models with available Duramax6.6L Turbo-Diesel V8 engine. Not available on Regular Cab models
Shown as "available" on LT, LTZ trims, standard on High Country trim.
Edited by revrnd
I'm currently looking at bypassing the digital steering and going with a non-digital type. Studying the wiring schematics to fix this problem. My truck is not covered under warranty for this specific problem anyway.
I don't know about GMC but on a 2016 LTZ chev, speed sensitive steering is standard. At least it as with the way my truck was built. Crew cab 4x4 with gas engine.
Edited by Dirtbiker
The dmax was the best I'd driven as well - right up until it started leaking terribly and the dealer worked on it. The gas 2500 was seriously no bueno. Its amazing though- I sent GM service here a message with my VIN and posted my issue here and a few other forums- it's a miracle- the part showed up! Yay! Dropping my baby off at 7 am and they said they will have her done by the afternoon. We are leaving to go camping Thursday AM so must have it back or a loaner dmax. Lol.
I will keep you all posted.
Did your truck finally get fixed?
Bro's truck went in the shop today. New box & pitman arm. Tech said arm was damaged.
The salesman that shuttled the truck to dealership (lives in same city as bro & dealership is out of town) said, "That was scary".
I got #84224694 installed in my truck finally after waiting since Dec 1st. Got the truck back today... Steering is looser than stock, and the truck pulls terribly to the right. They have it again and are working on it again.
see attachment.
So as mentioned I received my truck back yesterday and I can't tell if its worse now or before I took it in.
I just did a 100 mile drive on the highway and its the strangest thing. It goes from LOOSE 4-5 inches of play to HARD almost DIFFICULT to turn and then back to LOOSE.
Should we start filling complaints to the NHTSA?
https://www-odi.nhtsa.dot.gov/VehicleComplaint/
My truck isn't that bad yet, but it's not good and doesn't feel like a new truck should, maybe one with 150k and no maintenance.
Theres no point of even taking it in, there is no solution to the problem
EVERYONE with an issue must report it for a recall to be issued or all we'll get is bandaid's.
Currently I'm waiting for a Field Tech to look at my truck.
I have had this issue since about 1600 miles, and still no resolve. Currently I have 16940 miles.
This issue was brought to the attention of GM Corp. on December 07 via BBB since I was unable to get a permanent fix from multiple dealerships. I received a voicemail today explaining that we are still waiting to receive the scheduled for the Field Tech.
Edited by lmdnmmw
Is the play changed by your speed? Mine is fine until I hit 45 then becomes loose. Once I hit 76 it becomes normal.
Prior to the first failure, it was good at all speeds. After the new gear box was installed it acts similar to yours.
Yesterday I was driving on the highway, and there was a curve, I had to give it quite a bit of pressure to stay in the turn, and it abruptly got loose and almost sent me into the wall before I corrected for the change in firmness.
Yeah, we seem to be having the same problem.
Does yours clunk when you rock the steering wheel back and forth?
Mine gets loose around 45 mph also
Are all the trucks having this issue or just an unlucky few?
Edited by howdiy
    • The truck is a 1995 Chevrolet S10 Blazer, 4.3 VIN "W" engine. :cracks knuckles:   On a whim - because I needed a headache - this truck was for sale so I stopped to take a look. Doesn't run. Well, it does, but barely. Long crank, choppy idle, bad misfire(s), it REEKS of fuel. I can DO this..I'm thinking. Diamond in the rough. One owner until last year. A young guy is selling it, he bought it 6 months ago. It stranded him more than once, he's got a newborn. It was in the shop 10 days ago and he "thinks" they said it needs a new fuel injection system. He can't put any more money into it, needs it gone. I was thinking of upgrading my Macbook, which is a total want, not a need. For less than the price of a new laptop I can have fun for months tinkering on this truck and enjoying it. I'm taking this truck home. The guy was beyond thrilled, his wife was there, she thanked me profusely, I could tell they were hurting. They seemed like good people in a bind.   Some parts, a wash, maybe a set of tires, and I can have a few months of fun and then turn it for beer money (or the next project).   Sure enough, there's a work order from a shop last week in the INCHES of paperwork on this truck dating back to when the first owner bought it. They put a new distributor in it, fuel injection work describes basically opening the plenum and putting it back together. He said he couldn't afford any more work so he had them button it up and that's when he put it up for sale.   I'm not well versed in 4.3. I did discover 1995 uses the 1992-1995 SCPI "Spider" injector which is riddled with issues from splitting lines, clogged or cracked poppet valves and plastic spider legs that crumble over time. Cool. I'll just order me a ne---. Oh, the auto parts store doesn't have it? Rock Auto doesn't have it. eBay? $$$$$$ for used. These are UNAVAILABLE period end of story unless you know "a guy" who's still got one in a box somewhere.   Can't upgrade to the '96-'04 injector, it's a different plenum, wiring/pinout and sensor config.   There are a few kinda "know a guy" -guy rebuild services for these injectors out there for about $350. Okay, Okay... I'd like to know if anyone has used them? Anyone got a lead on these crappy 92-95 spiders?   I also don't want to send MY spider to Narnia and back without knowing if that's truly the problem. I guess I'll need to pull apart the plenum and do some digging.   I was also thrown for a loop. This 1995 model year truck has an OBD-II connector. The interface is decidedly not OBD-II. I can read and reset trouble codes and view live data, but there's not a lot of data. Like misfire count and on what cylinder, that's not there. It's OBD-1.5.   Nothing is ever easy. Now it makes sense why this guy wanted to disappear this thing for cheap. I'm guessing the shop told him the injector is toast, the part is unobtainable and they're not going to sort sending the thing to a rando offering rebuild service on craigslist, and the kid likely can't be without a working car for 3 weeks even if they'd facilitate that.   Experience with these early SCPI's? Stories? Things to check? Sympathy? (..Nah...)   This can sit until I sort it. But I haven't had a problem with a vehicle I couldn't easily solve in a long time.
    • I have four that read by the dash 8 to 10% better than miles/pump calculations and I have one that is spot on.
    • The average lifespan of automobiles on the road is increasing - here's why
    • Typically it is the Torque Converter, I have a 2.7L Trail Boss and between 25-65 MPH at 1300-1500 rpms under light throttle it has a shudder which I almost consider and bobble or a gargle sound. They replaced my TC but it did not help any, others say it has fixed their issues. It has been back twice now with no fix after.
    • Still $3.01 with even more places at this price
