Nice, whish I could find a good used 2016 cluster....been watching eBay but nothing yet
Sent from my SM-G935V using Tapatalk
Anyone have a picture of the 2016 Tahoe LTZ gauge cluster? I made be interested to do the swap in my LTZ Silverado but wanted to make sure they arent the same thing
Sent from my iPhone 7 Plus using Tapatalk
They are not the same, VERY close but one has different lighting around the gauge portions.
I have a 2015 sierra slt all terrain. If I find a 2015 sierra denali cluster will it need to programmed or is it plug and play? Thanks.
Sent from my SM-G928V using Tapatalk
We will need to program it.
PS that picture above of a "New" cluster has a cracked lens, missing the right upper tab etc... very likely NOT new LOL
Edited by GTPprix
Just be aware they MUST be the same year (I went through this with Chris already). I wanted to put the 2016 Tahoe cluster into my 2015 and he told me it can't be done since they are not the same year (it wasn't offered in the 2015 Tahoe).
Correct. The only caveat to this would be if you wanted to swap over the rest of the MOST bus to 2016 spec and pay more for programming to make everything work. IE for 2016 the Tahoe that would have that cluster would have lane keep assist not lane departure warning. To make all of that type of stuff work backwards is a considerable amount of work and a little bit short of a nightmare. Best to either go all in and change it all or keep everything the same model year.
I will assume the 2015 escalade cluster, which is all digital, will not fit in the 2015 Silverado? As best as I can tell from searching the 2015 Suburban and the 2015 Tahoe LTZ have the same cluster as my Silverado LTZ.
physically no it won't fit :(
Hi Guys
I am brand new to this and am based in the UK.
I have just purchased a 2017 Silverado LTZ Z71 And love the look of the Denali console. Is it possible to have this fitted to the Silverado? And if so how would you recommend I go about it.
Thanks in advance
Barry
Edited by Bazno1
Console or cluster?
I meant cluster sorry! I would love to have the Denali Cluster in my Chevy but not sure if this is possible?
If you have a 2017 yes we could retrofit program a 2017 Tahoe/Suburban LTZ cluster to work in that application.
    • Your safety is of utmost importance, @joshua1221, and we understand the importance of having all your lights working in your truck. If you have not already, we highly encourage you to bring your concerns to the attention of your local GM dealer. They are in the best position to diagnose your concerns as well as confirm the compatibility of the mirrors with your truck. Additionally, we would like the opportunity to explore any way we may be of assistance. When you have a moment, please visit: https://s.gm.com/support-request and fill out the support request form with all pertinent details. This form helps our team gather the right information and ensures your request is routed appropriately.
    • - I like the outside but not as much as the Chevrolet.  They ICE'd the EV styling and it works, but I think exterior goes to Chevy on this one.     - SLE and SLT dead = Not.  Surprising.  Fits into the rest of the GMC lineup like this which (aside from Pro) matches the rest of the family.  Elevation, AT4, Denali.     - Interior.  Sophisticated Malaise era.  Why do I say Malaise?  Drawn with a ruler.  Rectangles everywhere.  Looks very premium though.
