5 minutes ago, lapoolboy said:
Listen to your mentor carefully....
Call Specmo to order and they will ship straight to Chris.  You have to go to his website first and place an order and pay to get an order number.  Specmo will need to know that number to put it on the package.
Excellent. It’s first on my agenda tomorrow !
So once the  2017 denali cluster is programmed and installed in a 2017 silverado, will I have a gmc splash screen or a Chevy screen. Or does the cluster even have a splash screen like the Z71 cluster?
Chevrolet.
Excellent, that's what I was hoping to hear!
12 hours ago, GTPprix said:
Chevrolet.
My new Denali dash I had programmed last fall came with a GMC Intellink splash screen.  Its in my 2017 High Country.  Not really a big deal..but thats how mine arrived.  It was a new cluster.
Anyone have a picture of where the posted speed limit is displayed on the denali cluster? Is it next the speed display like the z71 cluster?
That's a bummer. Did WAMS program it?
Do you happen to remember the part number of your new cluster?
Yes, WAMS did program it.  I don't remember the part number but WAMS provided it.  It shows Intellink on start up vs. My link Chevrolet that forms up on the radio screen.  After the boot up you'd never know. I just assumed that's the way it was supposed to work.
By the way the speed limit shows up on the lower left .
I would prefer the Chevy My Link splash screen. Based on GTPprix's  response, it seems he will program it to display the Chevy screen. If not I'll need to research part numbers for a cluster out of a Tahoe Premier, Thanks for the response
Ill post one later. I think i have that option
Good thought on finding one from a Chevy.  I didn’t have that option since my truck is a diesel and the only option was a Denali diesel swap..Not sure if he is able to program the Chevy startup on a GMC dash but based on his earlier response, looke like he is.
Been in contact with him all week. Just ordered my cluster which will be here Monday. Then I'll send it off to be programmed.
How your Denali cluster worked out I have a 2014 and have not been able to find one
    Are yall just calling Specmo on the 800.545.7910  number? are you asking for a specific person to get the price match and drop shipping to White ? Going to get with white to do this soon on my 17 so just gonna give them to part number of page 29 after of course confirming with chris. Just didn't know if there was a specific person at Specmo to talk with
Thaks
Thaks
Talk to whoever answers
    d.lowrey
    d.lowrey
  • Who's Online   1 Member, 0 Anonymous, 2,944 Guests (See full list)
    • Just did an injector/HPFP replacement on Pepper at 192,400 miles; close enough to 200K, RIGHT? (If 200K is considered life end and to me it isn't). But hey, to each his own.    Have never run a catch can on this vehicle. Back side of every valve looked like a new valve spray painted semigloss black. Port walls looked 'neat' (all a normal result of passive EGR via VVT) Zero build up even in AFM cylinders. Just color. It uses no measurable oil and never has.    At 155,000 I put her on E-85 and a borescope of the cylinders at plug change showed very clean pistons and valve faces. The replaced injector tips looked new. (It was the pump piston seal that was leaking). Oh well, have six good backups.    Still gets 28 mpg on gas (highway average) and over 20 (highway) on alky. UOA's look good and runs as good now as it did when I bought it. Better in fact.    What improvement would a Catch Can provide this motor?     And given all this I expect that IF I installed one I'd see some water/gas/oil vapor accumulation. Byproducts of normal combustion.   Having said that, IF my motor used an appreciable amount of oil I'd consider it a useful 'crutch' until I had the situation corrected OR if bore polished, until I junked it or rebuilt it to stave off repeated plug fouling.    I'm not telling you what I THINK. But what its DONE.
    • Love the look. I'm a SCSB lover myself.    Two items. 1.) A spacer changes scrub radius but this also changes when we use wheels of different offsets. A little isn't a big deal. 2.) Steel wheels, alloy wheels all have different thickness. Same effect on the stud and lug nut as a spacer. When hub centric the wheel isn't supported by the stud. It's supported by the hub. The stud just keeps it all together.
    • I had a evap sol go bad a couple weeks ago. . I replaced it.  While watching live data at the time I saw I had some cylinder 1 misfires. No MIL but on live data I could see ~50 at startup and about 70 more after an hour a drive all on cyl 1.  I also noticed that the LTFT were -5% to -15% always.  And that bank 2 is always -3% richer than bank 1. Even across all driving modes, city, highway, etc it’s always 3% richer than bank 1. So I start with the misfire. Swapped coil, plug, and plug wires from 1 to 3. No follow. I got an Injector reseal kit, pulled the D/s injector rail, swapped #1 and #3 injectors, resealed them, reinstalled and retested.  The misfire followed to 3. So I ordered and replaced all 8 injectors, spark plugs, and plug wires. Also replaced the 1 time use fuel pipes under the intake manifold.  Injectors that were in the truck since new were  Part # 12668390.  I replaced them with # 12742701 Got from RockAuto. Pretty certain they’re genuine and the correct ones. I called a friend at a parts store who told me “the 12742701 were the correct superseded part # for the originals I was replacing”. So started truck after replacing all that and it’s running -15 - -30 LTFTs. I reset the fuel trims with GDS2 and drove it for a 60 miles trip each way. There have been no changes in the LTFTs.  I checked if the HPFP was leaking into the crankcase. I removed the pvc and watched the trims. No difference.  I checked the alcohol content and it was at 10%  I’m out of ideas here. Truck seems to run great. Just always rich on the fuel trims.  Anyone with any help or ideas would be greatly appreciated.  I ran an injector balance test just for the heck of it and it came back this. I’m confused.  I have gds2 and some other diag tools if anyone knows of anything I should test next.
    • Definitely needs to go back to the dealer.
