58 minutes ago, 2009GMC said:
Thanks, Did you reference order number when having shipped to WAMS? Calling Specmo today to see if they will price match GMPartsDirect for $386.26 (2018 Denali cluster 84385167) .....
Yes, I verified part number with WAMS then paid for programming then had Specmo include WAMS order number in shipping address to WAMS.
Specmo was great to deal with and had best price and cluster was in stock.
Edited by Davidj98
Just received my new Denali cluster. Before I ship to Chris at WAMS I opened box to verify part number.
ordered new Denali cluster 84385167.
However, I received cluster 84505079.
I reached out to WAMS to see if this part number will work with my 2018.
Edited by 2009GMC
  • Thanks 1
If not, I get to start the return / exchange process with Specmo.
Therr is multiple part numbers that will work. They might have just referenced it to that
You are correct. WAMS got back to me and said it would work.
FYI - Check your junk mail filter if you are waiting on a response from WAMS!
I have a 2016 Sierra Denali cluster for sale if anyone is interested. PM me.
Used in great condition. $300.00 shipped.
Does anyone know the part number or where to find the clear cover lenses as a replacement part? I believe I found a cluster but it's supposed to be missing the lenses.
Search item # 372041942938 on ebay.   The last time I checked, GM doesn't sell the lens separately.
So whomever sent in a 84201627 with no information or an order you might want to let us know ASAP otherwise its going back to the (eBay?) vendor you bought it from. Again if you order this service you need to have the order number written on the box and a copy of your receipt inside (if possible!) thank you!
I’m new to the forum. Will this work in my 2018? If so I’m interested
They are model year specific so this one will not work.  Scan back through the thread and look for Chris White's list of applicable part numbers for each year.
  • Haha 1
According to GtpPrix is has to be the same year of your truck.
Page 29 of this thread for part numbers.
Itll be the first mod. Buying tomorrow so I’ll need help installing. Can I ship strait to Chris ? I’ll trade fantasy advice
Listen to your mentor carefully....
Call Specmo to order and they will ship straight to Chris.  You have to go to his website first and place an order and pay to get an order number.  Specmo will need to know that number to put it on the package.
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 207 Guests (See full list)
