I appreciate that there are people who like vent air blowing directly at them. I don't like HVAC vents blowing at me in my home or vehicle. I have no difficulty maintaining a comfortable temperature throughout the cab with the existing layout of the vents. I regularly transport passengers of all ages and only receive compliments as to their comfort. There is no argument that many people like roof top or mid height vents in the back. However, the current system is designed to heat and cool the entire cab and in my opinion works well.
You live in BC. Is AC even needed in BC?
Not as often as as some places, but yes, I rely on AC in my home and vehicles for parts of the year. We do have a son who lives in Houston, Texas and my wife and I are frequently transported in the back seat of his '14 High Country during our summer visits.
I live in Texas and have three kids that ride in the back every day. The AC in these trucks cools the cab just fine. I have the Tstat set to Auto 69 Bi-Level and it cools down within just a few minutes and everybody is happy. The middle vents send plenty of air into the back of the cab. There's plenty of circulation.
Same here. I set it at 70deg and my kids are just fine in the back. Even after a baseball game when my oldest is hot and sweaty, it cools quick enough that my son never complains about it being too hot.
  • 5 years later...
  • 8 months later...
It's really difficult to believe this is real, what about the front? As for the AC vent, I got it replaced for my 19 Silverado, because it's difficult for the people who sit in the rear to feel the cold air, last week I just bought the vent deflectors from AUXITO,  the ventilation inside the car is improved a lot, they direct the cool air flow upwards the rear seat by their 45° degree. Very pleased with the results these vents bring.
2014-2018-silverado-and-sierra-rear-ac-air-vent-deflectors-37534435606772_x700.webp.3881eae5dcf3241d10edafac3cfb913f.webp
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
