Better Than New
Just got Bilstein 4600's and BFG KO2's (275/55R20) on all four corners. The Silverado rides and handles better than it did off the showroom floor and it only has 15,000 miles on it. Seriously, worth every penny. If it wasn't for y'all on this site I never would have gone in this direction. Thanks.
What are the specs on your truck Mark? I have been thinking it may be time for new shocks on my 14 double cab.
K2 factory shocks were speced out by an 80 year old grandma with no teeth left to rattle out of her mouth. A good pair of shocks such as Bilsteins are worth every penny when it comes to tame the rough riding beast.
Do you find the ride a lot stiffer? I am considering the same setup, but somewhat concerned about stiffness as going from p rated tire to load range e and a firmer shock with bilstein.
I was also thinking of going with them. I have the z71 with the rancho's, it rides really stiff. My buddy has the regular 4x4 and his rides super nice compared too mine.
I was just thinking about this while hunting this weekend. I have a 15 z71 and its not fun hitting the rough spots, rattles and kicks the back end out. Would go to a stiffer or softer shock be better?
Thanks
2014 crew cab LT 4x4.
It is absolutely stiffer. When going over a speed bump at like 10mph I no longer hit my head on the ceiling. Washboard dirt roads are not as painful as they used to be. This combo might not be for everyone, but I really dig it.
    • Thanks @newdude, guess I'll keep looking.  Test driving so many trucks that have obvious things broken, I'm thinking "if they couldn't even be bothered to fix the power seat," what else is broken".   Just drove a 2021 where the power seat motor was grinding/binding and wouldn't do anything but make a terrible sound.   An owner that puts dents on the bumper, doesn't fix a seat motor, and had spotty service intervals (along with missing major services) doesn't give me the best of confidence.   Amazed at the number of people that will finance a $60k+ truck, run it into the ground, then trade with a loan balance (every single one had "loan/lien reported" on the CARFAX at the last year of registration).
    • Not true! I have been runing them since 2006 F250! suspension component that works as a sway bar, a traction bar, and a helper spring points directly to the RoadActive Suspension (RAS) kit. Works as a sway bar, a traction bar, and a helper spring.
    • Here's a starter kit:    CC Jensen, a Danish oil testing Concern gives us the following guidelines:   ISO 14/12/10 Very Clean Oil ISO 16/14/11 Clean Oil ISO 17/15/12 Lightly Contaminated ISO 19/17/14 New Oil ISO 22/20/17 Very Contaminated and not suitable for any service.   In addition CC Jensen gives a table showing how engine life is increased by cleaning up the oil. For example cleaning the oil from 19/17/14 to 13/11/8 will extend motor life by a factor of 6X.   But even cleaning it two “Life Extension Classes” will double motor life. So perhaps giving those classes would be useful:   21/19/16 20/18/15 19/17/14 18/16/13 17/15/12 16/14/11 15/13/10 14/12/9 13/11/8   *************************************   https://testoil.com/program-management/setting-iso-cleanliness-targets/   Third paragraph from the bottom will give a starting point.    Your next question should be, okay 10um at what Beta ratio and the answer is in the graph Beta 75.   Then the next question is what is your chosen filters profile? (Purolator PL series below) The red dot is Beta 75. This was the information I obtained from MANN a few years ago. So the best filters, Purolator One, AMSOIL EA, FRAM Ultra, Royal Purple, Bosch Premium should get a doubling engine life over filters like Purolator L, any service filter from any quick lube, WIX, NAPA, STP, Mobil 1, Purolator BOSS.    And as noted by CC Jensen a 2-5 micron @ Beta 200 bypass system has the capability of a six fold improvement. AMSOIL has such a system as does Donaldson.       Now having said all that testing is the touchstone. Test the oil NEW and test it with your chosen filter. Then test over milage. Do the work, get the result. But understand this in NOT absolute BECAUSE this is one factor in isolation.   Example:    A valve spring supplier can state that with cam X and a valve train of Y grams the valves will not float to 7K rpm. is that true if the builder choose a system 20 grams over limit? Common sense must be used and limits understood.
    • This doesn't look like a GM truck. Not needed on a HD truck
    • It varies a ton around me. Some places are still at $5.00 or higher and others are way down into the $4's.   Offroad diesel was $4.02 at the one station I passed today.
