Starting this thread in search of people that have added heat to their rear seats.. wondering what the best options are for something like this or just if anyone else has even looked into it. I want to do something that is fully integrated into the stock leather with a button probably by the window button or somewhere around there. Just looking for some ideas to sort of build a plan off..
I saw this on amazon https://www.amazon.com/Dorman-628-040-Universal-Seat-Heater/dp/B002U6IL9O/ref=sr_1_1?s=automotive&ie=UTF8&qid=1324943932&sr=1-1&tag=vs-auto-convert-amazon-20
And theres plenty of sites like heatedseatkits.com
I would look to the back side of the center console for mounting switches. When i get to my truck at the end of my shift ill get a good look back there and see what other ideas i have. You would need to either run wire from the fuse box or find a suitable line to tap into. Personally id run its own wire. Mostly because i dont know what would be okay to tap into.
I think Block8head did this a while back in his 14. I believe he put the switch on the pillars below the seat belts for the front seats.
Does your console look like this? Id make a small plate to fit in this spot and delete the tray. Mount them there. The pillar under the deat belt is a good idea too. Let me just say ive fished wires the the door boot before, while the rears were easier than the fronts, it was still not fun.
That's where my a/c vents are. I'd have to pick another location.
Wait What????? How do you have rear AC??
I'm confused... a/c vents!?
    • The curb weight on a 1 ton crew cab long bed is around 7k lbs.  Now, I don't know where you went to school but 9k is not more than 2x 7k lbs. More than 2x 7k lbs would be 14k+.   With that said, obviously yes you're going to feel a 9k lb trailer when slowing down.  I already said, when accelerating.  When changing lanes?  No.  But if you look at the context of what was quoted, the original person said, "after a mile or two..." which means that would be after the accelerating portion and you're driving a generally steady pace.  Please do learn to read and comprehend.
    • "Life is getting back to normal."    I'm driving again and all new joints are operating as expected for this stage of recovery.   My most recent joint replacement still requires a lot of attention but experience has taught me that time will quiet the remaining pain.  I joked with my surgeon that another joint replacement would take my mind off my most recent surgery and he responded by saying the next will be a hip!  There are no plans for another surgery but, unlike me, I don't think he was joking!  I certainly wouldn't refuse further replacement  if required but hope to spend time out of the "post-op"  period.  I can't stress enough that if you have been recommended for total hip, knee or shoulder replacement that you welcome the offer.  Post-op "recovery" may sound daunting and painful, however, this is far better than the insidious erosion of mobility you are currently experiencing.  Imagine what it would feel like to wake up most mornings feeling better and more mobile than you did the previous day!  Prior to my first surgery in June 2025, even getting out of bed was becoming a formidable task.  Since the day after my first surgery, I get out of bed everyday easily and unassisted.  Making the switch to feeling a little better each day rather than a little worse, is hugely motivating!
